Re: WITH HOLDING
Re: WITH HOLDING
This is a little bit of a rabbit hole. You disassemble a banebox or vex planetary gear box, grease it, put it back together, Is it no longer COTs item? Attach a cots motor to it. That makes it an assembly? What if the same assembly is available for purchase (COTS)? While most inspectors will pass small violations (pinion pressed on a motor) obviously there is a limit IE assembling a COTs chassis is for beyond this.
This is an area I wish the GDC would clarify in future years. |
Re: WITH HOLDING
My 2 cents is that I don't care if a team pre-assembles a kit chassis before build season because I think the kit chassis is a disadvantage anyway. |
Re: WITH HOLDING
I've never hassled a team for having a pre-assembled gear box before. Teams that have come in overweight I've often had take off motors and/or gear boxes (including separating the motor and gear box) in order to make weight with everything else. The time a team invests in making weight for their withholding is a good lesson for them moving forward (while instituting a "time penalty" to make things fair with respect to everyone else at the event), and it's rare I see the same team make the mistake two seasons in a row.
That said, when it comes to my own team, I don't let them just use an old gearbox that was assembled in a previous season as-is. They need to take the gearbox apart, clean it up (old grease isn't necessarily a good thing, it can get full of contaminants and other stuff!), check to make sure none of the gears are worn down significantly, and then finally re-grease and re-assemble. There's a lot a student can learn about how a gearbox works doing this that they otherwise wouldn't see! |
Re: WITH HOLDING
Re: WITH HOLDING
Of course it does. AndyMarks sells am-0914, a gearmotor which is the assembly of their motor am-2161 and their gearbox am-0939. You can purchase the motor and gearbox separately, assemble them, and have an am-0914 gearmotor, which is a single COTS item on your BOM. Banebots sells PG60 gearboxes assembled, but ungreased. They also sell RS550 motors, which you can assemble to the PG60 gearbox. They do NOT sell a COTS gearmotor that is the assembly of the two. So, if you buy these seperately, and assemble them, you have not created a COTS item, you have created a non-COTS assembly of three (including grease) COTS items. Quote:
We wouldn't need to wait for future years if someone would submit a question to QA. (I can't do this myself.) Believe me, I will be delighted if pre-assembly of COTS kits becomes legal. You can bet we will leverage this to the max, if it becomes legal. What troubles me is that it sounds like some teams have already decided the rule isn't to their liking and have chosen to sidestep it. If I ordered a heathkit shortwave radio, and assembled it per the manufacturers instructions, could I return the fully assembled radio to heathkit and expect a refund? Of course not. I have changed the kit from the state it was in when I purchased it. Could I purchase a VEXpro gearbox, assemble it, use it for a year, then return it? Of course not. It's no longer in the COTS state. Could I purchase a VEXpro gearbox as a spare, and return it to VEX, unassembled, after competition season ended, if I didn't need it? That wouldn't be kind to VEX, but if I returned it in its COTS state, they would probably accept the return. Last edited by ToddF : 25-03-2015 at 11:55. |
#7
Re: WITH HOLDING
Yes that is why I call it a small violation. Falls under the intention of the rule rather than lawyering the letter of the rule. I can see the logic of both ways.
Q&A would only apply to this years game anyway. It is a mute question for my team. The only gear box it would apply to for us is a nano tuffbox that comes assembled.Quote:
#8
Re: WITH HOLDING
Also, having a scope older than I am should be worth something. |
#9
Re: WITH HOLDING
What is the definition of a "non-COTS assembly" according the the 2015 game manual. I don't see it in there.
#10
Re: WITH HOLDING
Section 4.1: "Many rules in this section reference Commercial-Off-The-Shelf (COTS) items. A COTS item must be a standard (i.e. not custom order) part commonly available from a VENDOR for all Teams for purchase. To be a COTS item, the COMPONENT or MECHANISM must be in an unaltered, unmodified state." The key words in the definition being UNALTERED and UNMODIFIED. From the Glossary: "COTS – a “Commercial, Off-The-Shelf” COMPONENT or MECHANISM, in its unaltered, unmodified state. A COTS item must be a standard (i.e. not custom order) part commonly available from the VENDOR, available from a non-Team source, and available to all Teams for purchase. Items that are no longer commercially available but are functionally equivalent to the original condition as delivered from the VENDOR are considered COTS and may be used." Last edited by ToddF : 25-03-2015 at 13:22. |
#11
Re: WITH HOLDING
Applying simple logic: anything that does not meet the definition of "COTS" is "NON-COTS" |
#12
Re: WITH HOLDING
I agree that it could fall under the category of "Fabricated". However, I'm still stuck on the fact that if I buy items "A" and "B" separately and put them together myself, it's called "Fabricated", but if I purchased the exact same 2 items pre-assembled it would be "COTs". That doesn't seem like the intent of the rule.
