Go to Post This easy world of friends, of people that you can talk to for hours on end without knowing one another? That's FIRST. - Keith Chester [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 25-03-2015, 11:13
Math Quiz 7
Determine whether this series converges or diverges using any one or a combination of the following tests/rules/theorems:
Comparison Test
Limit Comparison Test
Squeeze Theorem
Divergence Test
Ratio Test
Root Test
Harmonic Series
Geometric Series
Integral Test
L'Hopital's Rule
Show your reasoning.
Unread 25-03-2015, 12:38
Rachel Lim Rachel Lim is offline
FRC #1868 (Space Cookies)
Team Role: Student
Rachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond repute
Re: Math Quiz 7
Using the Divergence Test and l'Hopital's Rule (and the rule that lets me take the exponent outside the limit), I got that the series diverged: http://goo.gl/KVYEKZ
Edited to add:
Graph of the series (to confirm my working):
Name:	Graph of Series.png
After thinking about this problem a bit more, I was wondering if this logic would work: as x→∞, the sum will resemble Σ1^(2x), which is just Σ1^(x), which diverges by the Geometric Series test (since it's just 1+1+1+1 infinite times). I get the same result, but I feel like I'm messing up something by applying l'Hopital's rule like that...
Unread 25-03-2015, 15:51
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Re: Math Quiz 7
This is not a valid approach. As a counterexample, consider the following:
sum((x/(x+3))^(x^2))
By your reasoning, as x goes to infinity, this sum will also resemble sum(1^(x^2))=sum(1^x), so it should also diverge. However, this series does not diverge.
Unread 25-03-2015, 17:13
Jared's Avatar
Jared Jared is offline
Re: Math Quiz 7
It doesn't converge because the limit as k goes to infinity of your function is equal to e^-6. This is the divergence test.
Here's my work. The -6 I got as my limit is the exponent for e^-6, which means that the function is always changing, and the sum cannot converge.
Unread 25-03-2015, 19:43
Re: Math Quiz 7
Nice work everybody !
Originally Posted by Caleb Sykes View Post
...consider the following:
...this series does not diverge.
Somebody check my work. Is there a shorter way?
Unread 27-03-2015, 19:28
iRobot_ iRobot_ is offline
iRobot_ is an unknown quantity at this point
Re: Math Quiz 7
I'm not familiar with your root test method Ether. When I used the root test, it was inconclusive. ie the limit for the kth root of (k/(k+3))^2k = 1
Unread 27-03-2015, 20:14
Re: Math Quiz 7
You're confusing two different series being discussed in this thread.
In the post you are referring to, I quoted and was referring to the series that Caleb mentioned in post#3:
The Root Test can be used to show that Caleb's series converges.
The Root Test, however, is inconclusive for the series I posted in post#1.
Unread 27-03-2015, 21:12
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Math Quiz 7
For all k>2, 0 < k/(k+3) < 1
For all k>2, k[sup]2 > 2k
Therefore, for all k>2, (k/(k+3))k2 < (k/(k+3))2k.
Already proven: Sk=1OO (k/(k+3))2k converges
Therefore, Sk=1OO (k/(k+3))k2 converges by the Direct Comparison Test.
Unread 27-03-2015, 21:28
Re: Math Quiz 7
This statement is false. It has been proven that Sk=1OO (k/(k+3))2k diverges.
Unread 27-03-2015, 22:11
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: Math Quiz 7
Oops, that's what I get for not going back and refreshing my memory.
How about this one:
  • JaredRachel has shown that (k/(k+3))2k (the terms, not the series sum) converges to e-6 ~ .00248 ~ 1/403.
  • This means that for every k sufficiently large, (k/(k+3))2k < 1/4 (actually I believe this is true for all of them)
  • As k/(k+3) is positive, (k/(k+3))k < 1/2 for sufficiently large k.
  • Therefore, for every k sufficiently large, (k/(k+3))k2 < 1/2k
  • We know Sk=1OO 1/2k, converges at 1.0.
  • By the comparison test, Sk=1OO (k/(k+3))k2 converges.
Unread 27-03-2015, 22:25
Re: Math Quiz 7
Jared has shown that (k/(k+3))2k (the terms, not the series sum) converges to e-6
Give credit where credit is due: Rachel was the first to post that proof (4 hours earlier).
Unread 27-03-2015, 22:34
Re: Math Quiz 7
How about this one:
  • [as shown earlier] (k/(k+3))2k (the terms, not the series sum) converges to e-6 ~ .00248 ~ 1/403.
  • By the comparison test, Sk=1OO (k/(k+3))[sup]k2[/sup converges.
Unless I'm missing something, I see no flaw there. Nice.
Unread 29-03-2015, 14:05
Strants Strants is offline
AKA: Gavin Stewart
FRC #1977
Strants is an unknown quantity at this point
Re: Math Quiz 7
I'm perhaps a little late, but it's not actually necessary to use l'Hospital's: we can just use the limit definition of the exponential function.
We have that (1 - a/n)n converges to e-a. Thus, the sequence
a_k = (1-3/(k+3))2k+6 = ((1-3/(k+3))k+3)2
will converge to (e-3)2 = e-6. The sequence of terms we have is
b_k= a_k / (1-3/(k+3))6
and (1-3/(k+3))6 goes to 1 as k becomes large, so in the limit b_k converges to e-6/1 = e-6.
Unread 29-03-2015, 15:06
Re: Math Quiz 7
Most sources call that a property rather than a definition.
See for example
http://mathworld.wolfram.com/ExponentialFunction.html
But let's call it a definition. Then since it's a definition you can use it even though it's not in the list of allowable list of test/rules/theorems specified in the original problem statement
I like your answer, nice work.
Unread 31-03-2015, 12:03
M1KRONAUT M1KRONAUT is offline
FRC #2823 (The Automatons)
M1KRONAUT will become famous soon enoughM1KRONAUT will become famous soon enough
Re: Math Quiz 7
I went into a really intricate solution, and got a quadratic: the limit as k goes to infinity of (k/(k+3))^k = 0, 1. Very helpful. So now I know that the series either converges or diverges. My previous attempts at a solution have had logical errors, unfortunately.
