Go to Post Silly, Silly, don't you realize there are no borders in FIRST:) - HW [more]
Unread 25-03-2015, 19:36
Team3844's Avatar
Team3844 Team3844 is offline
AKA: Arthur Canada
FRC #3844 (Kentucky Wildbots)
Team3844 has a spectacular aura aboutTeam3844 has a spectacular aura about
compressor is heating up to the point it blows hose
Last year our compressor ran nonstop during matches but we had no problems with blown hoses.
We just started having this problem after weeks of problem free pnematics on our practice bot.
Does anyone have an idea how to dissipate the heat?
Unread 25-03-2015, 19:38
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Re: compressor is heating up to the point it blows hose
What do you mean by blown hoses? Did the hose physically fail, or did it disconnect from the compressor?
Unread 25-03-2015, 19:43
Knufire Knufire is offline
I've seen this problem several times. Easiest fix is simply putting a fan on the compressor. The extra airflow does wonders.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 25-03-2015, 19:46
Do you have the plastic hose connected directly to the fitting on the compressor?
Unread 25-03-2015, 19:50
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Adding additional metal fittings between the compressor and the plastic tubing has been known to help cool the air as it exits the compressor.
Unread 25-03-2015, 19:56
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
Are you running the VIAIR 90 C? We too had this issue, for the practice bot we switched the compressor to a Thomas 215 which is rated for 100% duty. We retained the 90C for the competition bot because it only needs to run in short bursts.
(2015-?): 973
(2012-2015): 955
Unread 25-03-2015, 19:57
Chris_Ely's Avatar
Chris_Ely Chris_Ely is online now
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Add more metal fittings between the compressor and the plastic tubing. You can also place one of the large fans from the kit of parts to blow on the compressor to help cool it.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 25-03-2015, 19:59
tickspe15's Avatar
tickspe15 tickspe15 is online now
Purdue University
AKA: Spencer Tickman
FRC #1747 (Harrison Boiler Robotics)
tickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant future
We use a different type of tube coming off the compressor that is rated for higher temperature operation. I believe the tube we use is rated for 200+ degrees Fahrenheit compared to the KOP tubing which is rated for 120ish degrees. We have also experimented with a metal sheathed tube coming off the compressor but higher rated tube seems to work just as well and be much lighter.
Last year in competition we ran our compressor at %100 duty and burnt out 2 compressors over the course of our 100 match season and replaced the tube from the compressor at every event. This year after three events the tubing we use with the higher temperature rating has no visible deformation anywhere on the tube(even in the fitting).
Team 1318: 2011-2015
Team 1747: 2015-Present
NAR (VEX U): 2015-Present
Unread 25-03-2015, 20:17
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Yes, we had this problem for Ultimate Ascent (our climber was primarily pneumatically powered). We had several hoses aneurism and rupture at the compressor output. By the time we got to the hose, the outrushing air had cooled the hose, so it took us several times (and changing hose batches) before we figured out that the heat was softening the tubing.
As hinted above, the key is dissipating that heat before reaching the first rubber tubing. In our case, we simply moved the pressure switch, stored pressure gauge, and vent plug onto an all-brass "christmas tree" leading away from the compressor, and put the first fitting to rubber tubing at the far end of all this brass. If this hadn't been enough, we probably would have heat-sinked this mass of metal to radiator fins or the robot chassis, and only then gone to a more active (fan) cooling mechanism.
Unread 25-03-2015, 21:12
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Basic Chemistry / Gas Laws
PV = nRT
It isn't the compressor. compressing air makes it hot, so you have a lot of hot air coming out. The Thomas had a large surface area on the compressor so it dissapated some heat.
put a metal heat exchange on the output of the compressor - put a length of metal tubing on the output of the compressor, then change over to plastic.
It would be nice if someone made an off the shelf radiator with about a foot length of copper tube with fins, with 1/8 NPT fittings.
Ed Barker
Unread 25-03-2015, 21:31
AKA: Alan Wells
FRC #1350 (Rambots)
PV = nRT
That sounds like overkill. Given that most teams can handle the issue with parts that are already in the system; a 3" fitting with fins should be more than enough to dissipate heat to acceptable levels for the tubing we are using.
Unread 25-03-2015, 22:00
ebarker's Avatar
AKA: Ed Barker
Not overkill for us. We keep most of our robots for years serving as showbots. Sometimes they run 8 or 9 hours a day, with small breaks.
We have two arial assist bots and they use a lot of compressed air, and we blow tubes all the time from heat fatigue. I'd pay money for a good heat exchanger.
Most teams don't need that much cooling but there are enough around that could probably use it.
if anyone see one, please post it.
Ed Barker
Unread 25-03-2015, 22:37
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
My team, in 2013, found the same problem with the Viair compressor (Yes, I know the compressor in the picture is the Thompson. Midseason, after burning out a compressor, that was what we had left.) , which we solved by using copper tubing off of the compressor. Might have been excessive overkill, but it solved the problem and worked throughout the season.
Academic Student (Forever)
Unread 25-03-2015, 23:08
AKA: Alan Wells
FRC #1350 (Rambots)
I forgot to account for that scenario .
They do make them, but they are rather heavy duty for what we are doing, and are not an allowed part under R66, not that that matters for demonstration purposes.
Unread 26-03-2015, 00:13
snoman's Avatar
snoman snoman is online now
FRC #3275 (Accelerators 3134 & Regulators 3275)
snoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to behold
+1 put a fan on it. also the Tomas seems to be a better compressor. contrary to listed stats it put out more air in a given amount of time for us. but it is bigger.
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
