Go to Post This only gets awkward when the girl knows more digits of pi than you do... - Walter Deitzler [more]
Unread 25-03-2015, 19:59
tickspe15's Avatar
tickspe15 tickspe15 is offline
Purdue University
AKA: Spencer Tickman
FRC #1747 (Harrison Boiler Robotics)
tickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant future
Re: compressor is heating up to the point it blows hose
We use a different type of tube coming off the compressor that is rated for higher temperature operation. I believe the tube we use is rated for 200+ degrees Fahrenheit compared to the KOP tubing which is rated for 120ish degrees. We have also experimented with a metal sheathed tube coming off the compressor but higher rated tube seems to work just as well and be much lighter.
Last year in competition we ran our compressor at %100 duty and burnt out 2 compressors over the course of our 100 match season and replaced the tube from the compressor at every event. This year after three events the tubing we use with the higher temperature rating has no visible deformation anywhere on the tube(even in the fitting).
Team 1318: 2011-2015
Team 1747: 2015-Present
NAR (VEX U): 2015-Present
