| Thread Tools |
Rating:
Display Modes |
#46
Re: Canburglar Mechanisms
Add 1736. We consistently took at least 1 off the step during auto at Central Illinois. Video here of a 'race' to the step. Here's a playlist if you would like to see how consistent we were. We took at least one off in autonomous in all but our first qualification match. |
#47
1918 and 1718 have them as well.
#49
16's reveal video showed a 2 container auto, and this video you can see them aiming for two and getting one. At Alamo, 4063 had a 4 container auto that hooked onto the handles, and 2415 had a 2 container one (I believe 2415 only had it in elims though). I'm not sure if there are videos of Alamo recorded as they're not on TBA. 2848 got 3 out of 4 (and knocked the 4th over onto their side) here This video shows 1986 getting 2 An updated list (adding every team that has been mentioned so far): 16 27 33 118 610 971 987 1114 1339 1678 1718 1736 1918 1986 2056 2137 2415 3310 3322 4063 |
#50
From the match videos that I have seen teams 118 and 1678 seem to be the fastest. Both robots do not need to move before releasing their can grabbers. In order to reach the 2 cans their arms extend out as/or after they are released.(required to stay below the 78" height limit) Most other robots must drive to the totes before releasing their arms.
Does anyone that has seen these robots in person know how the arms are extended? Thanks Also, 558 and 329 can be seen grabbing cans here http://www.chiefdelphi.com/forums/sh...light=waterloo Last edited by Mr. B : 03-26-2015 at 07:12 PM. |
#51
Team 144 - regularly at Pitt and next week at QCR - seen here about 7:04 of this video
#53
365. They're grab is actually pretty quick, though I think they're still working on how long it takes to back up. Example match. (This is just the first match I clicked on; I only watched the first few seconds.)
#54
I wonder how long this list is going to get...
Here's an example of 180's mechanism in Orlando: https://www.youtube.com/watch?v=Ei0p...K9Fgt&index=96 |
#55
Add 548 to the list
#56
#57
It really doesn't matter who is fastest at getting to the bins... it matters who comes away with them
, I'm excited to see these mechanisms go head to head. |
#58
We inadvertently had our getaway in "delay" mode, so we both had hold of the same can - 141 by the handle and 1918 by the lid. We took the can and also part of their "hand". Later, they stopped by our pit and "gave us the finger", decorated with a fingernail and knuckle. We all had a good laugh. |
#59
http://www.chiefdelphi.com/forums/sh...d.php?t=136071 Last edited by Matt_Boehm_329 : 03-26-2015 at 10:01 PM. |
#60
We both have round tubing held inside of square tubing. We used a bearing block on the outside of the square tubing, and an internal bearing block on the end of the round tubing inside to keep it constrained at two points while it slid. We both extended our mechanisms by just running a string from our elevator frame down the end of the square tubing to the bottom of the round tubing. As the arm traveled through it's range of motion the string would pull the round tubing up through the square tubing the exact same amount every time it fired. I can also tell you though that 3310's mechanism was faster than ours when we were running it with two motors (decided we didn't need all 6 for sac since it's getting scrapped anyways). Hope that answers your question. |
