Go to Post Antimatter.. It will help us in the never ending quest to build the bot under the weight limit. - Elgin Clock [more]
Unread 27-03-2015, 11:49
Team371All Team371All is offline
AKA: This account is for the whole team
#0371 (Curtis Cyber Warriors)
Team371All is an unknown quantity at this point
Ramp Legal?
We were watching the finger lakes regional and saw that team 5030 had a cool detached ramp right next to the bin chute. We just want to know if this is legal? Could we do this?
Team 371
2000 Mid Atlantic Regional Rookie All Stars
2001 New York Regional Finalist
2006 Monty Madness Champions, Thanks teams 1089 and 25
Unread 27-03-2015, 11:51
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Re: Ramp Legal?
Yes, provided it is tethered to your robot using a rope or string *or something attaching it long distance*. You'll find MANY of the top teams have done this, as it allows you to get full control of how totes fall in.
Unread 27-03-2015, 11:54
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
Re: Ramp Legal?
It is illegal to leave a piece on the field intentionally. You must be connected to all pieces of the robot at any time. I haven't seen the ramp you are talking about, but they are probably tethered somehow, through fishing line or something. Keep in mind that your tether must be visible or it may be ruled a safety hazard (happened to 148 with Alfred).
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 27-03-2015, 13:19
Re: Ramp Legal?
You may do this provided it does not violate any other rule. Some of these are that it must be able to fit inside the transport configuration, must fit in the 120 lbs. or less, have team numbers on it and must be continuous with a robot that meets the previous rules. As it is part of the robot, it must be inspected each time the robot configuration is changed (i.e. it is added or removed from the robot to allow an additional attachment to be used.)
Unread 29-03-2015, 11:02
Dominick Ferone's Avatar
Dominick Ferone Dominick Ferone is offline
FRC #5030 (The Second Mouse)
Dominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really nice
Re: Ramp Legal?
If you weren't able to notice our tether we had it always run along the back wall and then curled it up near our wheel.
We have 1/4 inch inside diameter rubberized pvc air hose ( one used for compressors) its about an inch outside diameter. It has proved to be the best option compared to anything else because we can drive over it easy since it compresses being rubber and can't make small coils in our wheel having pvc in it.
If anyone on our alliance ever drove over it they just had to spin their wheel backwards for half a second and it spit it back out.
I know 5254 later picked up something similar after seeing what we had I'm not sure what material.
this is a link to it on amazon
http://www.amazon.com/BOSTITCH-PRO-1...words=prozhoze
2010-2013 Team 353 The POBots - Student, 2014-present Alumni.
2014- present Team 5030 The Second Mouse - Mentor and Founder.
Unread 29-03-2015, 11:13
Re: Ramp Legal?
Also with the adding and detaching you actually don't have to get reinspected. We had two different ramps which we could switch between and we weighed them both and were still under 120 so we could switch between either or and still be legal.
Unread 29-03-2015, 12:52
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Re: Ramp Legal?
at sbpli we were cheesecaked and they didnt make us get reinspected after we removed it.
Unread 29-03-2015, 21:35
Re: Ramp Legal?
Unread 29-03-2015, 21:49
Sperkowsky's Avatar
Re: Ramp Legal?
ahh
the act of chesecaking is when another team gives an alliance partner a part in this case a ramp for purposes of making the alliance partner more useful.
Everyone love cheescake. everyone loves when a team helps them.
Therefore the term Cheesecaking was made.
I have a feeling its going to last.
Unread 30-03-2015, 07:24
Re: Ramp Legal?
Sam,
You might want to rethink that term, if you research the definitions.
Unread 30-03-2015, 09:46
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
Re: Ramp Legal?
Sam,
Al, dunno if you read through the thread, but in the Q&A 461 thread a few weeks back, Michael Corsetto coined the cheesecake term.
You did, however, teach me today that cheesecake has a second, slightly disturbing definition.
Academic Student (Forever)
