Go to Post The bleachers at a FIRST competition should be full of people blasting energy out of every pore of their bodies. - dlavery [more]
Unread 27-03-2015, 14:09
SciBorg Dave SciBorg Dave is offline
AKA: Dave Tharp
FRC #5920 (VIKotics)
SciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to behold
Plastic Chain
Were are a 42 point stacking robot and can do 1 1/2 to 2 per match. We were picked by the #1 alliance in both of our districts. At this point we weight 119.5 pounds and use a elevator to raise the 6 totes , can and litter.
One of our mentors wants to add a can puller from the step. To do this we must lose weight and he wants to install plastic chain where we use metal chain now (lifting approx. 75 pounds). I feel that being a very high scoring robot it is not worth the risk of installing plastic chain. What are other teams experience using plastic chain ?
Unread 27-03-2015, 14:11
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Re: Plastic Chain
Have you done the math on the stress on your chain, to see if the proposed chain is adequate?
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 27-03-2015, 14:27
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Plastic Chain
No. Unless you have access to something special, plastic 35 chain usually isn't meant for more than 60 lbs of working load. It won't hold up under the rigors of competition.
Risk versus rewards. You are risking your primary scoring mechanism while trying to make something that is not going to contribute to your score in every match.
Unread 27-03-2015, 14:30
AKA: Dave Tharp
Re: Plastic Chain
I will ask for that to be calculated.
ThePancakeMan's Avatar
ThePancakeMan ThePancakeMan is offline
AKA: Andrew Panek
FRC #2338 (Gear It Forward)
Team Role: Electrical
ThePancakeMan will become famous soon enoughThePancakeMan will become famous soon enough
Re: Plastic Chain
Im not that familiar with plastic chain. But are you sure that you will even have enough weight to make a decent can grabber. Our bots can grabbers are rather heavy as we have 2 of them and they each have 2 pneumatic pistons. Just something to think about. How effective a can grabber can you make with the limit you are placing on weight?
Unread 27-03-2015, 14:32
AKA: Dave Tharp
Re: Plastic Chain
The canburglar will not be used during Qualification only eliminations if used at all.
Unread 27-03-2015, 14:34
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Re: Plastic Chain
Instead of plastic chain consider switch to timing belt. It should be a decent reduction in weight if you are currently running #35 chain.
Unread 27-03-2015, 14:41
AKA: Dave Tharp
Re: Plastic Chain
We are running 35# chain 4 of them approx. 12 feet long each so timing belt out of the question. Only 6 feet of each chain will be changed over to plastic. I see problems. What is that old line "Do not change horses in mid stream". PNW championships are in 5 days.
Unread 27-03-2015, 14:43
Re: Plastic Chain
Do you have photos of your current robot anywhere? That would help us identify places you can lose weight by swapping out materials.
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
Re: Plastic Chain
Our robot has two chains, each nearly six foot tall--pretty hard to find timing belts that long.
But that adds up to like 23 feet of chain. Heavy.
I know little about plastic chains, but if you're using #35 chain, you can switch to #25. Or even bicycle chain. Or lose the weight elsewhere. Switch to mini-cims. Canburgulars are very valuable and will make people want you.
We designed one that weighed in at about 4 lbs.
I think you can find four pounds.
Unread 27-03-2015, 14:44
AdamHeard's Avatar
Lead Mentor
Re: Plastic Chain
So you're running 4 12' lengths of #35 chain?
It requires new sprockets, but switching to #25 chain would provide HUGE weight savings and still be plenty strong.
Unread 27-03-2015, 14:51
AKA: Steve Peterson
Re: Plastic Chain
IIRC #25 chain is less than 1/4 the weight of #35 chain.
Unread 27-03-2015, 16:52
AKA: Dave Tharp
Re: Plastic Chain
We installed Minn-cims and found out with the weight of the bot we had problems doing zero point turns. We did a lot of drilling larger holes to reduce weight to return to regular cims.
Unread 27-03-2015, 17:07
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Plastic Chain
A little more than half, according to these guys. Still, at 0.23#/ft for 35 and 0.10#/ft for 25, that's 6# less of chain by switching to 25.
Also, you actually could switch to belts, you'd just have to use open length belting with a clamp to close it up. As long as you're running your lift a short enough distance that you don't have to run the clamp over a pulley, it'd be fine.
Unread 27-03-2015, 17:42
RoboChair's Avatar
AKA: Devin Castellucci
Re: Plastic Chain
#25 chain is the way to go. It's great stuff. #35 chain is OVERKILL on all mechanisms except chain driven arm pivots in my opinion.
McMaster lists a working load of 88 lbs for #25 chain and 200! for #35. Acetal #35 chain is listed as 45 lbs working load.
