Go to Post The less we talk about the game hints the faster they will come. - BrendanB [more]
Unread 27-03-2015, 23:56
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
World's Lightest Ramps
So half way through the first day of our district event today, I went with one of our mentors to buy supplies for a ramp. The requirements we had for this ramp were simple, it had endure constant usage for two days minimum, it had to quickly move totes to a flat position, and finally it had to be quickly built with only a pits worth of tools. Here is the kicker it had to weigh in at less than 1.25lb.
I am happy to say that we successfully built such a ramp. Its final weight is 1.1lb and works fast. It is made out of packing tape and pink shop foam from "Home Depot". This ultra light ramp is saving our team and has helped us up our performance.
This exprince has lead me to wonder, what is the lightest ramp you have seen and what was it made of?
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 28-03-2015, 00:14
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Re: World's Lightest Ramps
How about 0 lbs? There are dozens of ramps available on the field...
"A genius is just a talented person who does his homework" T. Edison
Unread 28-03-2015, 00:21
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
But you get a foul for cutting a tote in half on the field!
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 28-03-2015, 00:28
Munchskull's Avatar
Team Role: CAD
I understand the strategy of using a tote as a ramp. However I have yet to see my team keep the base tote from moving.
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 28-03-2015, 00:35
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Those ramps dont weight Zero though.
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 28-03-2015, 01:02
MikLast's Avatar
MikLast MikLast is online now
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
MikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to behold
however much a gym floor weighs, or maybe a tote, since we use that too.
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
Unread 28-03-2015, 01:24
The other Gabe's Avatar
The other Gabe The other Gabe is offline
Too many events, not enough time
AKA: I'm a volunteer now!
no team (2046 Bear Metal Alumn)
The other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud of
would the foam from your 2013 robot have worked similarly?
Do the best you can with what you are given
FRC 2046 2012-2015
Field Scout lead 2014-2015
Unread 28-03-2015, 01:34
Munchskull's Avatar
Team Role: CAD
Most likely not. That was more of a packing foam we used on the bottom. What we made today was an actual constructed assembely that needs to be ridged but light. That is why pink shop isolation foam works well. It is way more brittle than the our 2013 cushion, that was like a giant pool noddle.
Just a clarification for others, our teams 2013 robot was just a climber so it had no wheels to drive with. Instead we opted to put a giant block of closed cell foam on the bottom just incase it fell. Lucky for us it only fell twice, both before season.
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 28-03-2015, 02:05
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
There have been lots of lightweight ramp designs posted over the season, a simple search would yield most of them.
(2015-?): 973
(2012-2015): 955
Unread 28-03-2015, 02:24
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
For $10, you can go to Home Depot and buy materials for a ramp, have it weigh 2.8lbs, build it in 1/2 hour, help you score up to 5 totes more, and run your robot on 1 CIM per side on the drive motors (to make weight) and work.
Our driver said on Wed he wanted to build a ramp and I literally laughed.
I stand corrected.
Unread 28-03-2015, 03:44
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
1551 was weighing a carboard box to use as a ramp. They had a pound of weight to spare and it was under a pound, I'm not sure if they actually used it in a match.
Unread 28-03-2015, 06:40
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
4mm thick corrugated 'twinwall' polypropylene sheets can be purchased from Home Depot. One 3' x 6' sheet weighs ~3.5 lb per HD website, and I don't think you'd use more than a third of it to make one ramp.
Ask 469 if you see them -- I think their ramp is made of something similar. It worked well at St. Joe.
Richard Wallace
since 2003
Unread 28-03-2015, 13:29
Nyxyxylyth Nyxyxylyth is offline
AKA: Neal Manson
FRC #1481 (The Riveters)
Nyxyxylyth is just really niceNyxyxylyth is just really niceNyxyxylyth is just really niceNyxyxylyth is just really niceNyxyxylyth is just really nice
It was almost a "FOR SALE" sign for added comedy. But that ramp was retired - the next one will be different.
Unread 28-03-2015, 14:15
wasayanwer97's Avatar
wasayanwer97 wasayanwer97 is offline
Take from the best, invent the rest
AKA: Wasay Anwer
FRC #0668 (The Apes of Wrath)
wasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant future
Depends how loosely you define a ramp.
If your goal is to just get the totes to land correctly, all it takes is a sheet of some slick material in front of the chute to get the totes to land properly. The reduced friction against the edge allows the tote to just slide forward and land on its bottom rather than rotate about its edge and land on its front.
A 1/16 sheet of polycarb works really well. The only issue is that it'll slide around, so attaching some high grip material/tread to the bottom prevents it from moving too easily.
"Coming together is a beginning; keeping together is progress; working together is success."- Henry Ford
FRC Team 668: The Apes of Wrath
Pioneer High School, San Jose CA
http://www.theapesofwrath.org
Talking to other FIRSTers is great. Add me on Facebook!
My Page
Unread 28-03-2015, 17:35
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Our ramp weighs in at 0.4 pounds...pretty light I would say.
-Ronnie
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
