Go to Post It is proper to have a disagreement, but it is improper to be disrespectful. - Bill Moore [more]
Unread 27-03-2015, 17:43
Paul Richardson Paul Richardson is offline
Strategy/Mechanical/Drive Coach
no team (1477/3320)
Paul Richardson has a spectacular aura aboutPaul Richardson has a spectacular aura about
Re: Plastic Chain
Consider also that you can allow yourself to use weaker material by decreasing the load applied. Adding a spring will add some weight, but it may allow you to save some weight elsewhere (chain weight, motors, and gearbox for example).
Also, if you are having trouble with belts as an alternative to chain, you can also try a simple string winch. You can find cord and wire in long lengths for cheap that are very strong for their weight.
Unread 27-03-2015, 18:25
RoboChair's Avatar
AKA: Devin Castellucci
Re: Plastic Chain
Alternatively you could use a Constant Force Spring such at what McMaster sells.
http://www.mcmaster.com/#constant-force-springs/=whvq22
Unread 28-03-2015, 16:10
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
Re: Plastic Chain
This is what we are doing. with the spring our lift has a maximum load of about 35 pounds up and 20 pounds down.
Unread 29-03-2015, 14:40
Vespasian's Avatar
Vespasian Vespasian is offline
AKA: Elliot Dowd
FRC #1511 (Rolling Thunder)
Team Role: CAD
Vespasian is an unknown quantity at this point
Re: Plastic Chain
Speaking of lightweight RC Pullers, our team recently built and implemented one with only about four pounds of weight left to spare at the end of bag day. The entire subsystem weighs in at about three pounds (motor controller and wiring included), and uses a spool to retract. It can pull two RC's in auto within about five seconds, and could probably be sped up to pull within three seconds. I'm happy to provide further details if anyone is interested.
Here's a very preliminary video of the system in use at the Montreal Regional. It has become much faster since, and we now use it in autonomous mode. Skip to 1:15 to see it in action.
https://www.youtube.com/watch?v=pnUju-lFhRE
