Go to Post robots like to give you troubles... its like they have a mind of their own. - hayleybayley217 [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Thread Tools Rating: Thread Rating: 41 votes, 5.00 average. Display Modes
Unread 28-03-2015, 12:19
dakaufma dakaufma is offline
AKA: David Kaufman
FRC #0449 (Blair Robot Project)
dakaufma is an unknown quantity at this point
Analysis of team ranking
This year's game is unusual in that there is no defense and for the most part robots work on their own in parallel to score points. As a result I figured it's reasonable (even more than usual!) to try to compute the average number of points a robot contributes to its alliance. I wrote a quick python3 script that takes as input match data (tested on the DC regional, where my former team 449 is currently playing) and outputs my ranking of teams and the number of points I think they contribute to their alliance. Apologies for the variable names, but hopefully I made up for it in with the comments.
Rankings:
1 (3419, 73.704492305515487)
2 (1731, 46.312538656273205)
3 (1418, 39.472531653896525)
4 (1895, 38.799337600450862)
5 (3490, 36.294428293019763)
6 (1599, 34.28821369481841)
7 (1885, 32.629205449774474)
8 (1033, 32.348123760832848)
9 (1421, 30.478697284154272)
10 (5338, 29.040436495747031)
11 (623, 27.745489727319374)
12 (5549, 27.121269236479719)
13 (1389, 26.60584843249497)
14 (383, 23.671855927551672)
15 (4099, 22.375266604669307)
16 (449, 21.912210928023729)
17 (116, 21.449547070425396)
18 (5243, 19.808177358212305)
19 (612, 17.344396301222865)
20 (4456, 16.61331712295609)
21 (5569, 16.37413112815706)
22 (122, 15.839607260787915)
23 (2377, 15.709065445693666)
24 (3941, 14.395635096324398)
25 (614, 13.631250573400411)
26 (2537, 11.955265914302434)
27 (686, 11.401428768949312)
28 (4541, 9.7651476520334057)
29 (4242, 8.7906915069887415)
30 (5587, 8.488917324654544)
31 (2068, 8.4789566363119739)
32 (3373, 8.3192241916003127)
33 (4821, 7.4396295708618432)
34 (2186, 6.5217325036723395)
35 (3650, 6.196980101798685)
36 (2912, 5.8563204263368132)
37 (620, 5.783804197530789)
38 (53, 5.3467216070143158)
39 (4472, 4.7981247189600955)
40 (2421, 4.7603990054157492)
41 (4464, 4.6403121971023475)
42 (2964, 4.075077317496544)
43 (1123, 3.2348248124167291)
44 (1915, -0.067152495721547467)
45 (4949, -1.8884154681926013)
46 (5520, -2.1497370184179658)
47 (3748, -2.471672298659696)
48 (611, -3.0598363988393888)
Source code:
import numpy as np
# load scores, copied from http://frc-events.usfirst.org/2015/DCWA/qualifications
f = open("score")
lines = f.readlines()
data = [l.split() for l in lines]
# these are the columns red teams, blue teams, red scores, and blue scores
# end up in when I copy/paste
redcols = [6,7,8]
bluecols = [9,10,11]
redscorecol = 12
bluescorecol = 13
# get list of teams
teams = set()
for d in data:
    for tcol in (redcols + bluecols):
        teams.add(int(d[tcol]))
teams = list(teams)
teams.sort()
# get a mapping from team number to index for efficient lookup
teamindex = {}
for i in range(len(teams)):
    teamindex[teams[i]] = i
# enter each "match", where match = [red or blue teams, score]
# (i.e. 2 "matches" per actual match played, I'm assuming that
#  the two sides are independent because there is no defense
#  and that cooperatition points are on average the same score
#  a team would have accumulated with normal socring in the same time)
# each row of match data has an entry for each team, 1 if it
# played or 0 if it didn't
# each entry of matchscores is the score
matchdata = []
matchscores = []
for d in data:
    for (tc,tcs) in [(redcols, redscorecol), (bluecols, bluescorecol)]:
        md = np.zeros(len(teams))
        for tcol in tc:
            md[teamindex[int(d[tcol])]] = 1
        matchdata.append(md)
        matchscores.append(int(d[tcs]))
matchdata = np.array(matchdata)
matchscores = np.array(matchscores)
# compute the amount of the score contributed by each team on average
teamscores = np.linalg.lstsq(matchdata, matchscores)
# print results, sorted in order of contribution
tcs = [(t, teamscores[0][teamindex[t]]) for t in teams]
tcs.sort(key=lambda x: x[1], reverse=True)
for i in range(len(tcs)):
    print(i+1, tcs[i])
Unread 28-03-2015, 12:24
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: Analysis of team ranking
It would appear you've independently discovered what is commonly called OPR Although it works very well this year, it can also work well in more defense-heavy years. The main breakage for OPR is exponential scoring (2007) or piece-limited scoring (2011), or when it _really_ matters how resistant you are to scoring (2009).
As a guy that once wrote a OPR scraper way back in the day, I gotta say that's a fantasticly concise implementation
Unread 28-03-2015, 12:25
AKA: David Kaufman
Additional comments:
- obviously there variance in team performance, so this won't be a perfect predictor
- these results list a couple teams as providing negative points on average -- this is fairly clearly not true. These teams probably contribute about 0 points on average. This actually gives a pretty good rough estimate of the precision of these numbers (error of ~3 should be expected on all numbers)
- if teams have strategies that involve working together in some way, this model does not account for that.
- if teams have strategies that interfere with each other (i.e. all 3 teams need to be fed at the feeding station to reach their full potential), this model does not account for that
Unread 28-03-2015, 12:28
AKA: David Kaufman
@Bongle I was actually thinking of Moneyball as I wrote this. But I actually think this game is _even better_ than baseball for such analysis because robots aren't playing dramatically different positions in these matches --> all robots have equal opportunity to score points
Unread 28-03-2015, 12:30
Bongle's Avatar
That's not entirely true - the way the math works out, you end up solving for "the number of points added by that team being in an alliance". If a team tends to take fouls, gets in the way, blocks visibility, or breaks their alliance partners, they may end up with a negative value.
Similarly, it is possible for a team to have a positive value without ever scoring a single piece: if the team facilitates scoring in some way (good strategy, supplying parts, bringing a ramp, etc), they may still have a positive effect on the alliance's score.
Your other points about limitations are correct.
Unread 28-03-2015, 14:02
Originally Posted by dakaufma View Post
I wrote a quick python3 script that takes as input match data ... and outputs my ranking of teams and the number of points I think they contribute to their alliance.
Would you please run a short experiment?
Attached is a ZIP file containing Qual Match data for all 67 events in 2015 weeks 1 through 4, in the column format described in your code (I included both tab-delimited and comma-delimited).
Please run your script on that data and tell us how long it takes the script to do the computation.
Unread 28-03-2015, 14:15
Note: all the data is in one big file; you only need run the script once on that file (not 67 separate runs)
Unread 28-03-2015, 14:52
AKA: David Kaufman
It runs out of memory after a few seconds computing least squares. I guess my script was too quick and dirty to handle that much data
Ok, closed out of my memory-hog browser and reran it. It finished in 68 seconds. It's single threaded --> only using 1 core. I don't know the exact specs but I'm using an old laptop. If you want it to run faster you could get a reasonable estimate running the script for each regional and averaging the results for teams that competed in multiple regionals. My script basically ran instantly on the DC regional alone, it just didn't scale well.
Results:
1 (1114, 119.53710628381191)
2 (2056, 107.52392526361433)
3 (1730, 98.937520154912633)
4 (2481, 85.411141027422389)
5 (1678, 83.604692998775761)
6 (987, 81.614933990522147)
7 (118, 80.969024034928296)
8 (4488, 80.539400149979258)
9 (254, 79.885031034931174)
10 (148, 79.432991922526838)
11 (5406, 78.607729049050903)
12 (1519, 78.606114913994432)
13 (1619, 77.525461715196158)
14 (1658, 72.769643357190205)
15 (3130, 71.271318091324432)
16 (1671, 70.02262062115436)
17 (2338, 68.377599976884255)
18 (1280, 68.31086262054076)
19 (3683, 68.046518730572274)
20 (314, 67.063058451290729)
21 (4143, 66.197146406242695)
22 (2085, 65.826088138212199)
23 (1756, 65.300090499752486)
24 (225, 64.935706448058212)
25 (1538, 64.559840785724475)
26 (330, 64.541264057923442)
27 (2852, 64.483030815000632)
28 (1986, 62.974425411332938)
29 (2451, 62.637597604073804)
30 (2974, 60.564349115146001)
31 (1023, 60.560211511217332)
32 (1983, 59.916674128430934)
33 (744, 59.594728708265407)
34 (1657, 59.279400181300687)
35 (67, 58.964359968912603)
36 (2122, 58.817777660610751)
37 (2342, 57.489327516287716)
38 (1640, 57.464812178955)
39 (2826, 56.916928984985773)
40 (234, 56.858881704686439)
41 (3339, 56.533409767618949)
42 (4655, 56.39313720643888)
43 (3230, 56.122255030023631)
44 (1574, 55.625450146975965)
45 (624, 55.340768974856552)
46 (2077, 55.213700500454443)
47 (525, 55.123176093827624)
48 (2783, 54.867531033295869)
49 (303, 54.677252325474406)
50 (2512, 54.663228166283453)
51 (1156, 53.95917064433668)
52 (701, 53.489926552157726)
53 (135, 53.310632416341505)
54 (3824, 52.981920713390842)
55 (4678, 52.90258841628895)
56 (2137, 52.82827564039772)
57 (1806, 52.545135953520244)
58 (4201, 52.100455606412289)
59 (4967, 51.976661185189229)
60 (58, 51.708557689346009)
61 (1569, 50.999721751403754)
62 (2587, 50.879055731499093)
63 (3663, 50.352150843306362)
64 (3360, 50.32364073573774)
65 (70, 50.212423608681007)
66 (456, 49.514397347218271)
67 (226, 49.421619066877071)
68 (3419, 49.291886530691805)
69 (4613, 49.182337568239383)
70 (2383, 48.952668799007341)
71 (4451, 48.461565771037783)
72 (4039, 48.428887067643302)
73 (60, 48.304027027456911)
74 (3452, 48.237009235381947)
75 (694, 48.146194119499853)
76 (2643, 47.617699872486028)
77 (85, 47.524384916070105)
78 (1403, 47.469950277471035)
79 (494, 47.374147160288466)
80 (1918, 47.291935686802972)
81 (287, 47.257974979802917)
82 (2386, 46.953430407180903)
83 (203, 46.861955923046182)
84 (1024, 46.697459369030227)
85 (876, 46.137245094936418)
86 (3646, 46.13325578237896)
87 (340, 46.084590782880028)
88 (3132, 45.713812619738299)
89 (4564, 45.704005687502573)
90 (71, 45.592449645849975)
91 (2337, 45.302005071186898)
92 (3200, 45.067571065424303)
93 (379, 44.960948960140477)
94 (2054, 44.735136796993629)
95 (1208, 44.698482053595882)
96 (78, 44.46540330346042)
97 (2767, 44.397595621836118)
98 (1676, 44.241945432579165)
99 (2231, 44.074739609953014)
100 (1876, 44.059135373758906)
101 (5188, 44.006924999206518)
102 (33, 43.991463573919681)
103 (662, 43.937410242633831)
104 (107, 43.844215107033079)
105 (2883, 43.838433292634448)
106 (126, 43.680710097846031)
107 (4522, 43.658797513513953)
108 (125, 43.554274627035511)
109 (4539, 43.541714417941485)
110 (2457, 43.313197516131233)
111 (1768, 43.202978983685014)
112 (2062, 42.91184275827608)
113 (3996, 42.878462653349217)
114 (1218, 42.221423588184592)
115 (4947, 42.21385679919382)
116 (4028, 42.184039856147834)
117 (4003, 42.058582095894693)
118 (230, 41.974917059019731)
119 (610, 41.906402824077851)
120 (2607, 41.670540732672599)
121 (4917, 41.384462943129392)
122 (3688, 41.147751248112812)
123 (3930, 41.033422854244797)
124 (1493, 40.986924808173157)
125 (4500, 40.741418876306227)
126 (4118, 40.695131685614619)
127 (971, 40.523141542947506)
128 (3238, 40.466262103026601)
129 (359, 40.422448697174524)
130 (61, 40.330053037398599)
131 (3418, 40.150604856512359)
132 (48, 40.137305510265087)
133 (2996, 40.028508239671567)
134 (2619, 39.968708976433774)
135 (5030, 39.877431370188553)
136 (263, 39.839439286180657)
137 (4048, 39.825826430840849)
138 (1296, 39.808174436676225)
139 (56, 39.662074105094518)
140 (4049, 39.655310597148734)
141 (4946, 39.601027916048579)
142 (3604, 39.539475208943301)
143 (348, 39.481859806964366)
144 (1318, 39.370452934396013)
145 (3467, 39.295360485121932)
146 (4911, 39.224358414364175)
147 (3616, 39.110279455887301)
148 (5618, 39.086526813133673)
149 (2635, 38.980266823053611)
150 (2930, 38.840601375514616)
151 (3374, 38.81788764505211)
152 (4256, 38.784719563512631)
153 (973, 38.463844062433054)
154 (51, 38.334314781676767)
155 (384, 38.201138768628411)
156 (2590, 38.147515826742477)
157 (4096, 38.116308218237869)
158 (4623, 38.092545615566564)
159 (4952, 37.86114845595975)
160 (133, 37.828067879761136)
161 (1718, 37.787600674391747)
162 (2474, 37.692730385543939)
163 (3743, 37.59312775479782)
164 (1816, 37.542280174166791)
165 (2410, 37.496877654564656)
166 (1501, 37.104342080915757)
167 (3620, 37.037606938363133)
168 (5122, 36.982541576210828)
169 (4481, 36.865262298598083)
170 (3937, 36.841636721001414)
171 (1647, 36.751313815118657)
172 (3284, 36.74635714111696)
173 (1310, 36.716915159692995)
174 (3711, 36.708942403153074)
175 (2168, 36.657044244067841)
176 (219, 36.622331677278126)
177 (4618, 36.592685886997145)
178 (4009, 36.541388801745121)
179 (179, 36.46999930280974)
180 (192, 36.428357257530422)
181 (1511, 36.412379877666389)
182 (2468, 36.411558461182182)
183 (1466, 36.410653763267597)
184 (176, 36.341368086411364)
185 (3954, 36.106465544323413)
186 (236, 36.030241466107022)
187 (1065, 35.866091693146807)
188 (217, 35.739433335936802)
189 (293, 35.714822450042767)
190 (3171, 35.700953362598391)
191 (4450, 35.675245209103132)
192 (3478, 35.497911882995631)
193 (1025, 35.33059600491984)
194 (2067, 35.302384982157086)
195 (858, 35.220534346307758)
196 (20, 35.213858881906404)
197 (3787, 35.200316831586413)
198 (3245, 35.154820267538746)
199 (3947, 34.936457120925624)
200 (5124, 34.900427199797058)
201 (1690, 34.843920361381095)
202 (2605, 34.842650608275285)
203 (469, 34.826502670309935)
204 (88, 34.781860065335088)
205 (4471, 34.776523328229906)
206 (3055, 34.772009951076569)
207 (1629, 34.734579749225233)
208 (492, 34.62041348642861)
209 (4859, 34.584359681765029)
210 (2470, 34.584346687341977)
211 (188, 34.462145048031729)
212 (5155, 34.435692705316441)
213 (2522, 34.35816391473486)
214 (34, 34.173866945917425)
215 (5415, 34.146785509913705)
216 (1502, 34.067087880802461)
217 (4001, 34.064597422588839)
218 (4055, 33.916169496312733)
219 (1094, 33.883434363608139)
220 (1523, 33.871609512708311)
221 (5479, 33.849391237999257)
222 (3528, 33.828080185259267)
223 (5069, 33.77734334023711)
224 (3574, 33.690314713091702)
225 (1572, 33.650008671190953)
226 (2170, 33.575593261620348)
227 (3015, 33.547013037090167)
228 (3959, 33.523300871264311)
229 (3044, 33.406171382153723)
230 (904, 33.342751678172135)
231 (846, 33.327700541596251)
232 (4377, 33.305432679592052)
233 (670, 33.259397175471463)
234 (3309, 33.247368517097016)
235 (5753, 33.236142903316946)
236 (2169, 33.094046510981954)
237 (5492, 33.046067910839866)
238 (4061, 33.01891123496646)
239 (280, 32.985235881445348)
240 (1937, 32.945294053227798)
241 (4330, 32.895140642192821)
242 (2959, 32.807809147273616)
243 (4381, 32.793946338233482)
244 (245, 32.711707797251968)
245 (292, 32.579249817782227)
246 (4914, 32.53912196307197)
247 (246, 32.470985984479007)
248 (2471, 32.404626971136231)
249 (4646, 32.384273327934203)
250 (1225, 32.374217436032403)
251 (1261, 32.345344589914419)
252 (3618, 32.319420811573949)
253 (706, 32.087559612208366)
254 (2489, 32.080162945238371)
255 (5674, 32.068028144346975)
256 (365, 32.063866801911502)
257 (2550, 31.968333087158392)
258 (2907, 31.963996692538135)
259 (4543, 31.937642440156992)
260 (2344, 31.883372165807916)
261 (5172, 31.746782970946477)
262 (3968, 31.738032978366853)
263 (4004, 31.660944083506916)
264 (5603, 31.656178443794023)
265 (3547, 31.624098353856535)
266 (27, 31.615954801848815)
267 (5511, 31.59945800797674)
268 (4485, 31.588001091120738)
269 (1595, 31.558596969881869)
270 (3539, 31.556723877535198)
271 (2478, 31.435819566154908)
272 (3039, 31.41599321476928)
273 (447, 31.408100879172181)
274 (3955, 31.397208810781596)
275 (2040, 31.396818339564696)
276 (4384, 31.36827170756532)
277 (5112, 31.338720289318339)
278 (1712, 31.225301368796138)
279 (1763, 31.219614687869981)
280 (1319, 31.027832060889921)
281 (5053, 31.026096768004098)
282 (316, 31.004945681413208)
283 (195, 31.002772387355328)
284 (138, 30.978073568382566)
285 (5502, 30.96655526350947)
286 (1477, 30.854716412418391)
287 (5776, 30.833279403898562)
288 (45, 30.771497026266104)
289 (3588, 30.730249883028147)
290 (222, 30.661345061396982)
291 (2081, 30.585445374235022)
292 (5554, 30.579978307945261)
293 (1720, 30.573435485801873)
294 (4624, 30.501204083289633)
295 (4498, 30.421878762510477)
296 (2526, 30.412593900599504)
297 (5758, 30.403677283741686)
298 (3003, 30.289741529784614)
299 (383, 30.274427792634622)
300 (1723, 30.218861857075929)
301 (811, 30.192776246588522)
302 (342, 30.168485860212456)
303 (4189, 30.13965943188408)
304 (171, 30.111080057728859)
305 (1885, 30.08157855417863)
306 (3501, 30.056119432123456)
307 (885, 30.042265795522237)
308 (4325, 29.978999286032156)
309 (3612, 29.972457662016737)
310 (433, 29.965135411743013)
311 (343, 29.815721870600417)
312 (4550, 29.783543177508189)
313 (5735, 29.760366282137795)
314 (3451, 29.623168415939425)
315 (193, 29.597381522938797)
316 (1665, 29.477226112588852)
317 (5038, 29.371603785511478)
318 (5013, 29.367568082295421)
319 (1577, 29.351057855544511)
320 (1522, 29.329602508326648)
321 (3623, 29.319629407542678)
322 (3944, 29.165672846015873)
323 (5254, 29.152950147461201)
324 (3570, 29.146301900278111)
325 (308, 29.108891367260316)
326 (2867, 29.07047844203802)
327 (4905, 29.050359447749955)
328 (4103, 29.008081199277097)
329 (93, 29.002439064178919)
330 (269, 28.990050531142835)
331 (3357, 28.987813199246801)
332 (4906, 28.987217737312413)
333 (1492, 28.931717575968353)
334 (1735, 28.843015541771116)
335 (5442, 28.724169408312502)
336 (3336, 28.712610544003628)
337 (5413, 28.696880079236056)
338 (4364, 28.611574275852828)
339 (1775, 28.584899036665753)
340 (3065, 28.525796636906136)
341 (2612, 28.469954244499142)
342 (2052, 28.430475381231936)
343 (157, 28.411865437907171)
344 (4586, 28.402948306541667)
345 (418, 28.385761801791819)
346 (1706, 28.370790285515668)
347 (538, 28.361433414481329)
348 (166, 28.36103280869056)
349 (2834, 28.349114945963684)
350 (862, 28.341719529492536)
351 (339, 28.312336861693979)
352 (2501, 28.291988136942045)
353 (5332, 28.221843780634114)
354 (3546, 28.219951278962149)
355 (1089, 28.179779922305691)
356 (74, 28.170630647060285)
357 (16, 28.153537909491376)
358 (3970, 28.068452679409923)
359 (2016, 28.054055944982938)
360 (4909, 28.046294197793365)
361 (1732, 28.004259847789143)
362 (5722, 28.000893562008127)
363 (5470, 27.964602396088338)
364 (4505, 27.957193742959475)
365 (1507, 27.918932823151927)
366 (2609, 27.881283715612394)
367 (3735, 27.842927062337381)
368 (1325, 27.83399855612867)
369 (2771, 27.805249600837143)
370 (3234, 27.777086187904139)
371 (364, 27.773516882454661)
372 (1287, 27.695541678956054)
373 (868, 27.686820418135625)
374 (4343, 27.674281064913401)
375 (1099, 27.628699640049589)
376 (4991, 27.614565128957356)
377 (4681, 27.606551378589774)
378 (2655, 27.585967703038538)
379 (967, 27.543757884969985)
380 (1209, 27.49029315446089)
381 (2075, 27.489002477372793)
382 (4546, 27.487066617423164)
383 (3635, 27.48356561968173)
384 (3250, 27.477190342232095)
385 (2506, 27.464706103391794)
386 (2228, 27.460322730350228)
387 (5638, 27.427765735683632)
388 (4499, 27.40789367631136)
389 (1421, 27.404206618353694)
390 (1592, 27.386817099943038)
391 (3260, 27.365005454713454)
392 (854, 27.359701627787871)
393 (488, 27.357071384709442)
394 (283, 27.340562809508832)
395 (4196, 27.251498552372244)
396 (4075, 27.247775472572336)
397 (3883, 27.212920975158571)
398 (5031, 27.198910831670158)
399 (3166, 27.196904723704534)
400 (1737, 27.169193486402385)
401 (5533, 27.158765140173511)
402 (4179, 27.121111391478998)
403 (3753, 27.089296419821817)
404 (3556, 27.083479235450824)
405 (229, 27.079429415775564)
406 (5440, 27.010685856862828)
407 (829, 27.001233828525692)
408 (3512, 26.930904261815289)
409 (2877, 26.881231135426113)
410 (25, 26.874956272980398)
411 (5457, 26.866288001868522)
412 (816, 26.855177040462138)
413 (3242, 26.817236552652037)
414 (3999, 26.768375771352677)
415 (2637, 26.754207885873239)
416 (2556, 26.722268324369626)
417 (2164, 26.714139546461933)
418 (5416, 26.712108158331368)
419 (3117, 26.689489008313181)
420 (5509, 26.625666975877792)
421 (5102, 26.524853029673466)
422 (1596, 26.515223320474583)
423 (1249, 26.493278542675782)
424 (1726, 26.489644927212183)
425 (3005, 26.419255081805929)
426 (5653, 26.400498089799498)
427 (237, 26.35761010854295)
428 (2102, 26.347818573916165)
429 (743, 26.342390803045571)
430 (857, 26.315470606750107)
431 (1458, 26.247934551821654)
432 (2149, 26.246563656766824)
433 (4183, 26.202643599250163)
434 (354, 26.199852232691846)
435 (5489, 26.192861587438728)
436 (581, 26.152928799044968)
437 (4130, 26.132089695198701)
438 (5176, 26.114821763716343)
439 (3322, 26.053936588046433)
440 (386, 26.049864401551556)
441 (1165, 26.045173350642266)
442 (1785, 25.985391083201186)
443 (3201, 25.868153944012217)
444 (3990, 25.856933670324047)
445 (5506, 25.824466384694141)
446 (5494, 25.736525498289623)
447 (3146, 25.648217719441675)
448 (5478, 25.640319574953956)
449 (5046, 25.581618109196217)
450 (4253, 25.578438118943854)
451 (1285, 25.573906488215286)
452 (1746, 25.558401756436641)
453 (558, 25.535460634011994)
454 (931, 25.520646102671648)
455 (4011, 25.488524319439261)
456 (540, 25.477007289536935)
457 (1351, 25.444354065912695)
458 (2614, 25.428661236815)
459 (1, 25.408471248651491)
460 (1339, 25.403370133527815)
461 (4269, 25.402571237541043)
462 (4362, 25.335001467891367)
463 (4215, 25.321098874192337)
464 (4158, 25.265544852318435)
465 (156, 25.250893811560466)
466 (1736, 25.231376918344381)
467 (5534, 25.198997131282795)
468 (4977, 25.170821198415698)
469 (233, 25.120302841637574)
470 (5584, 25.077052317020517)
471 (5160, 25.042113801447705)
472 (461, 25.032494768182929)
473 (1410, 25.013531264680662)
474 (1831, 24.974062121555651)
475 (2531, 24.925176248962295)
476 (2202, 24.917813178518919)
477 (2990, 24.90985975858867)
478 (5559, 24.907175327856649)
479 (2551, 24.8970475069233)
480 (571, 24.893484720289351)
481 (5431, 24.870041892738069)
482 (2648, 24.831917013848315)
483 (5229, 24.83067765659808)
484 (3310, 24.824415490377742)
485 (1757, 24.796343961599742)
486 (4237, 24.795618934831069)
487 (3928, 24.769246278838935)
488 (2213, 24.672852947668602)
489 (3151, 24.655530284233262)
490 (2443, 24.616749722793838)
491 (155, 24.568328214519163)
492 (4007, 24.562668016305732)
493 (3602, 24.478349870794311)
494 (207, 24.46932756768506)
495 (5260, 24.468588847777415)
496 (3971, 24.352750741095846)
497 (3276, 24.351690661211929)
498 (3770, 24.342387931921142)
499 (4308, 24.33326050289104)
500 (2791, 24.292334210032177)
501 (1943, 24.256609575817777)
502 (3277, 24.139806278879938)
503 (597, 24.087137762573075)
504 (1329, 24.051146287478094)
505 (2705, 23.988572780254273)
506 (2405, 23.96604908177919)
507 (3072, 23.942123315723901)
508 (319, 23.914647345917004)
509 (696, 23.898129454412086)
510 (1944, 23.859773682099213)
511 (5291, 23.845895217715078)
512 (1946, 23.839903123590258)
513 (1985, 23.792378603220055)
514 (3314, 23.774708888486369)
515 (2035, 23.77027236158327)
516 (5283, 23.768924491405429)
517 (4205, 23.76820722281661)
518 (527, 23.764300900932476)
519 (4761, 23.762705729626795)
520 (3081, 23.759466090955936)
521 (4127, 23.741830191797586)
522 (3974, 23.610476007878777)
523 (4391, 23.501703005002078)
524 (5308, 23.468675514945382)
525 (1197, 23.460492419928674)
526 (3329, 23.423165403867699)
527 (1677, 23.413867182628856)
528 (1102, 23.410399988048219)
529 (66, 23.3580020695439)
530 (2437, 23.33438482972258)
531 (5588, 23.326526737211335)
532 (2053, 23.286258420904929)
533 (1902, 23.216979961068233)
534 (1895, 23.210737186908329)
535 (1649, 23.194970035323269)
536 (1884, 23.18561336047128)
537 (4988, 23.16059120553939)
538 (1262, 23.149282487776187)
539 (4154, 23.145789535504626)
540 (4796, 23.134497357904614)
541 (5505, 23.131600667563504)
542 (5216, 23.116968444676235)
543 (1189, 23.111097805183935)
544 (2212, 23.065242967893951)
545 (5204, 23.037899349629139)
546 (1731, 23.014867379084713)
547 (3489, 23.010709508006872)
548 (3241, 23.009760680035722)
549 (294, 22.992170326613579)
550 (1817, 22.988340596623264)
551 (3393, 22.967535389348555)
552 (3504, 22.930810388359046)
553 (2503, 22.892101032170096)
554 (3305, 22.871323882874165)
555 (1825, 22.85354717665523)
556 (568, 22.819026088705687)
557 (5325, 22.771882991617289)
558 (5022, 22.74395096045043)
559 (2204, 22.740354782726605)
560 (86, 22.723993042025114)
561 (948, 22.69974907875239)
562 (1073, 22.699475734579735)
563 (4915, 22.675237851735353)
564 (2234, 22.626742380844288)
565 (175, 22.622326590617071)
566 (1622, 22.573939387584964)
567 (3760, 22.550251396840942)
568 (4728, 22.522485324954719)
569 (178, 22.494734676069559)
570 (5585, 22.490287813383752)
571 (1714, 22.477216357374804)
572 (3719, 22.476376241201358)
573 (5437, 22.462969760388496)
574 (3600, 22.450562221367431)
575 (3243, 22.441758175955083)
576 (5684, 22.441245923010403)
577 (1927, 22.398009040701957)
578 (3875, 22.36318731824155)
579 (501, 22.346881506760241)
580 (3019, 22.336711792350414)
581 (3812, 22.336190029744166)
582 (2851, 22.291987828450502)
583 (279, 22.284161744099237)
584 (2079, 22.256111931630898)
585 (111, 22.255412690913264)
586 (2191, 22.243994326616296)
587 (11, 22.236303063159539)
588 (3382, 22.22489546579655)
589 (2813, 22.224351680612681)
590 (1533, 22.201334455103492)
591 (3786, 22.192927794211169)
592 (5403, 22.172564133152999)
593 (1137, 22.166796827673675)
594 (498, 22.050655019947428)
595 (3522, 22.039310116135201)
596 (3656, 22.036479578419232)
597 (2197, 22.022906686496285)
598 (3122, 22.02245086679854)
599 (4585, 22.003943019534713)
600 (4950, 21.999012154733705)
601 (1071, 21.991271288301149)
602 (4453, 21.984544244316115)
603 (2972, 21.981884692632978)
604 (4513, 21.923903970514139)
605 (4592, 21.903251302181051)
606 (1250, 21.885124547775021)
607 (5773, 21.8050033836167)
608 (2496, 21.763213345896471)
609 (2141, 21.757556863088009)
610 (5279, 21.728573656090738)
611 (1598, 21.683974511186651)
612 (5471, 21.681957414106087)
613 (334, 21.673906948701951)
614 (3495, 21.666175129040173)
615 (4401, 21.656006334874323)
616 (1711, 21.64756907413269)
617 (4021, 21.617023181537292)
618 (2412, 21.607659824446625)
619 (5057, 21.576230546121593)
620 (4174, 21.575292429727281)
621 (806, 21.556058712361626)
622 (5290, 21.501114519232758)
623 (1124, 21.472873010563454)
624 (834, 21.466525435637557)
625 (2425, 21.463733359972053)
626 (955, 21.460952140695788)
627 (3957, 21.444110458879557)
628 (3986, 21.433621217860285)
629 (123, 21.418294860597729)
630 (842, 21.411612648719053)
631 (2632, 21.392425871993144)
632 (1717, 21.382014873587586)
633 (5572, 21.381270290174221)
634 (2642, 21.361105455870035)
635 (4031, 21.296528087592495)
636 (57, 21.253852214120684)
637 (5501, 21.250369856104228)
638 (2509, 21.239646628731972)
639 (1635, 21.223152180785203)
640 (613, 21.221352547706225)
641 (103, 21.208393062949973)
642 (2521, 21.20046280854822)
643 (3103, 21.137734484783916)
644 (3102, 21.120964518264067)
645 (5111, 21.115219853275239)
646 (1796, 21.055097834040431)
647 (4608, 21.027430725215346)
648 (5265, 20.996555357255229)
649 (3566, 20.976517783716741)
650 (4397, 20.972076338688751)
651 (5148, 20.950365655527509)
652 (533, 20.946818400739033)
653 (573, 20.946223795891861)
654 (3767, 20.933057539827956)
655 (3615, 20.91404677156023)
656 (272, 20.90741982869395)
657 (1517, 20.885307059082365)
658 (5703, 20.875837188860928)
659 (1382, 20.869661914616767)
660 (4368, 20.863981737918461)
661 (2175, 20.846496496895064)
662 (698, 20.832769525206366)
663 (1100, 20.830644779313904)
664 (4726, 20.82975599567628)
665 (3606, 20.821212300912279)
666 (3939, 20.78408953739287)
667 (3882, 20.773326818961106)
668 (2039, 20.75195459336086)
669 (1700, 20.745976388516869)
670 (2415, 20.712627303502025)
671 (5194, 20.69982992193961)
672 (4711, 20.685695643827021)
673 (2135, 20.674763059664784)
674 (3598, 20.671487024040264)
675 (59, 20.67082615115234)
676 (5253, 20.627455125451668)
677 (4087, 20.621834467806096)
678 (5504, 20.613410280776371)
679 (295, 20.609970139894745)
680 (3515, 20.605327460501627)
681 (3859, 20.599679140345003)
682 (2358, 20.599517920085155)
683 (4907, 20.560408601315125)
684 (4216, 20.538345428694534)
685 (3759, 20.534310914724205)
686 (3668, 20.524474379715105)
687 (3965, 20.519829196678579)
688 (1644, 20.517058083695609)
689 (1143, 20.51364883545704)
690 (3669, 20.50621730191164)
691 (4994, 20.496239306192347)
692 (2395, 20.484554422013325)
693 (399, 20.478784350342771)
694 (5153, 20.477097852191111)
695 (1807, 20.443420545302324)
696 (639, 20.424124879689508)
697 (1425, 20.418613585610931)
698 (5232, 20.372615284547333)
699 (1811, 20.358042526797519)
700 (4132, 20.348361227175065)
701 (75, 20.312434113078222)
702 (3352, 20.294342421637019)
703 (4774, 20.271964716485833)
704 (2252, 20.269281221312745)
705 (999, 20.257448452243953)
706 (5472, 20.233109807202627)
707 (5098, 20.206652133972479)
708 (3294, 20.199088499237295)
709 (4300, 20.196824037553895)
710 (4819, 20.142772033172811)
711 (5697, 20.135191081913579)
712 (4027, 20.128945097523612)
713 (4786, 20.112769676877193)
714 (3525, 20.074066373266447)
715 (3750, 20.003349185821698)
716 (3164, 20.00318695127693)
717 (1290, 19.998429305792037)
718 (3402, 19.963452320746779)
719 (4320, 19.934394320002692)
720 (3969, 19.934020793689331)
721 (3043, 19.929164341279854)
722 (2046, 19.927736407391333)
723 (5152, 19.921093956890672)
724 (1388, 19.919786511157774)
725 (3653, 19.900408922982155)
726 (121, 19.870447217185774)
727 (204, 19.870172433024365)
728 (3494, 19.867707794654315)
729 (1506, 19.85427544783245)
730 (1793, 19.851499394493729)
731 (4484, 19.836532798491461)
732 (5782, 19.734754867749025)
733 (3627, 19.656964887436551)
734 (5498, 19.64400006093015)
735 (1002, 19.578437567657723)
736 (5257, 19.568797566534709)
737 (663, 19.55985605338244)
738 (223, 19.556192348679261)
739 (3476, 19.532778663217034)
740 (835, 19.486856422127591)
741 (3940, 19.454566710180305)
742 (4398, 19.443773566177452)
743 (3933, 19.431109610432713)
744 (5006, 19.424768833019421)
745 (781, 19.394640549751543)
746 (4561, 19.376356523281775)
747 (5562, 19.354058271289801)
748 (3572, 19.298784738372561)
749 (5786, 19.275559207280764)
750 (2626, 19.266820056465637)
751 (2523, 19.24339813692086)
752 (1058, 19.208219861093184)
753 (4361, 19.203293453128811)
754 (3624, 19.193219253970724)
755 (4135, 19.17003097999223)
756 (703, 19.137382894726191)
757 (1747, 19.131570507443527)
758 (5159, 19.129308323590461)
759 (4476, 19.127694510286311)
760 (5224, 19.11794310698221)
761 (3863, 19.108176940904585)
762 (2363, 19.09762928436373)
763 (5616, 19.092580661464389)
764 (145, 19.070928637117422)
765 (3466, 19.045890971307642)
766 (1778, 19.014774034027209)
767 (2013, 19.009283821379334)
768 (5745, 18.958538515658219)
769 (4167, 18.895338865366586)
770 (5535, 18.810140729397169)
771 (3239, 18.775152281261015)
772 (5316, 18.766065768949531)
773 (1396, 18.755852133075027)
774 (5748, 18.741491633925129)
775 (4352, 18.739111351242332)
776 (4779, 18.738941051604932)
777 (4568, 18.729133674728729)
778 (1802, 18.727751875716713)
779 (2944, 18.713871659599715)
780 (716, 18.704078007850036)
781 (2662, 18.676354348035918)
782 (2484, 18.640488825155728)
783 (5595, 18.618142009229086)
784 (4089, 18.581765094391962)
785 (4856, 18.525602201389578)
786 (2876, 18.517233388967099)
787 (3173, 18.504386227156978)
788 (1648, 18.422214075604217)
789 (116, 18.421045728294644)
790 (4057, 18.380339251548243)
791 (1072, 18.379497442483864)
792 (949, 18.370295133302829)
793 (5473, 18.359935496087463)
794 (3958, 18.356126478663448)
795 (5610, 18.354535033988721)
796 (151, 18.333925908157642)
797 (2183, 18.322072929617125)
798 (4160, 18.281576736122421)
799 (122, 18.214607404187337)
800 (5223, 18.151735994285332)
801 (4074, 18.118648113724085)
802 (4983, 18.093660465622044)
803 (870, 18.086343943364643)
804 (5402, 18.059580017368077)
805 (4276, 18.04969943920538)
806 (1178, 18.049257595300457)
807 (3718, 18.028418757281401)
808 (4511, 18.008724421990181)
809 (4469, 18.002453518223891)
810 (3236, 17.99097918418579)
811 (1662, 17.980949334331488)
812 (172, 17.954077908971584)
813 (2147, 17.947042394494247)
814 (1529, 17.900406629924753)
815 (5614, 17.887939973749319)
816 (4281, 17.871742299847789)
817 (4744, 17.856367668561557)
818 (5167, 17.834360080988073)
819 (2180, 17.832224662809928)
820 (2976, 17.82424809093397)
821 (3158, 17.807651815793751)
822 (5047, 17.790119884719516)
823 (704, 17.784954830923017)
824 (5712, 17.778939960252252)
825 (5460, 17.75714626160628)
826 (691, 17.756519531277682)
827 (2555, 17.749170428707604)
828 (3506, 17.720795334880698)
829 (5669, 17.720697582882611)
830 (3822, 17.650689785071062)
831 (4784, 17.650338102306527)
832 (4528, 17.626033466267149)
833 (2998, 17.622566538624)
834 (3674, 17.622172298717889)
835 (4547, 17.602431879719401)
836 (213, 17.580180770481423)
837 (5687, 17.574190750185984)
838 (2486, 17.56590545601799)
839 (3386, 17.552891375204727)
840 (3218, 17.542533317110582)
841 (1557, 17.534562029374232)
842 (3098, 17.52540740181589)
843 (5475, 17.479240344191396)
844 (3388, 17.466891304704074)
845 (5114, 17.45725893834593)
846 (4980, 17.447831833771133)
847 (2534, 17.418364044152817)
848 (3083, 17.409166983389035)
849 (3853, 17.407922151194114)
850 (4930, 17.385910716224167)
851 (1322, 17.370197162857977)
852 (1836, 17.361554739289296)
853 (839, 17.351915439827515)
854 (2682, 17.341308243825424)
855 (1683, 17.313541058385653)
856 (231, 17.227112636493821)
857 (4073, 17.214985918333539)
858 (4473, 17.160841977085987)
859 (4587, 17.143260828505692)
860 (4082, 17.083426875060535)
861 (4674, 17.033176041232668)
862 (3794, 17.029097891029597)
863 (5710, 17.019588891840602)
864 (4956, 17.017962168069211)
865 (5158, 17.014127941546995)
866 (5484, 17.008313823361469)
867 (3561, 16.98532270499992)
868 (2192, 16.936130181382751)
869 (4060, 16.896279181327685)
870 (3176, 16.858687819220545)
871 (1018, 16.845939143909106)
872 (2594, 16.845775500024565)
873 (1777, 16.821511849403883)
874 (2493, 16.807659758576104)
875 (2194, 16.805341432522869)
876 (5326, 16.779318409345954)
877 (5525, 16.728882137431771)
878 (4238, 16.704161483148152)
879 (41, 16.701352712131822)
880 (1660, 16.688200688045555)
881 (3009, 16.681873022195916)
882 (1255, 16.679846731127377)
883 (4342, 16.67322367549454)
884 (5526, 16.650175118139295)
885 (3603, 16.626682838075919)
886 (5538, 16.617416870335468)
887 (810, 16.61387780311648)
888 (5563, 16.587885074167652)
889 (2403, 16.584760208561192)
890 (1051, 16.582749263313875)
891 (2423, 16.58082916824111)
892 (5529, 16.576196619723461)
893 (5724, 16.574886232546113)
894 (1241, 16.570859403990205)
895 (4181, 16.57042155478662)
896 (2914, 16.567878082951328)
897 (4995, 16.520169048889493)
898 (2574, 16.496256533559922)
899 (2836, 16.450461622947401)
900 (4670, 16.429266016333393)
901 (5420, 16.383853838111349)
902 (5126, 16.368483825734785)
903 (3034, 16.357789432634039)
904 (5754, 16.352755365075019)
905 (3133, 16.301818674214612)
906 (2838, 16.300815698868327)
907 (1923, 16.292174979580583)
908 (3295, 16.288037728321932)
909 (5129, 16.285769376144756)
910 (2335, 16.281976523734276)
911 (4735, 16.28097274592303)
912 (321, 16.245780394971334)
913 (5634, 16.240412035485541)
914 (3256, 16.22464139376121)
915 (2823, 16.183172073596655)
916 (1254, 16.182400676351676)
917 (3410, 16.161424203585611)
918 (5411, 16.159694593012638)
919 (3459, 16.158664891872494)
920 (5679, 16.110601433084422)
921 (4319, 16.10232159222387)
922 (4231, 16.080306640569411)
923 (484, 16.075271455357871)
924 (3298, 16.074006308460017)
925 (3140, 16.06386882437479)
926 (2935, 16.06261407259549)
927 (2559, 16.052871876840946)
928 (5109, 16.042955129287336)
929 (3455, 16.033986604486945)
930 (5692, 16.030842710620277)
931 (3802, 16.023699669108854)
932 (5524, 16.020433266738245)
933 (4285, 15.997355092676656)
934 (329, 15.996037602203984)
935 (1160, 15.969691834170664)
936 (869, 15.957610516276912)
937 (5166, 15.940930308898858)
938 (3658, 15.940068296862869)
939 (2374, 15.938502726872795)
940 (4069, 15.935786098449423)
941 (5071, 15.923425296895171)
942 (5428, 15.914504889935639)
943 (3225, 15.882068358965819)
944 (4122, 15.873784164428654)
945 (2679, 15.859215089295322)
946 (5410, 15.858316673680834)
947 (1257, 15.854299582618129)
948 (5087, 15.835015120603313)
949 (907, 15.797689292293251)
950 (2495, 15.784956882911064)
951 (3381, 15.775396045595087)
952 (5496, 15.761913479521732)
953 (3527, 15.761312376458788)
954 (5665, 15.750904780019425)
955 (4304, 15.744863050433903)
956 (2797, 15.73870245207198)
957 (4580, 15.733393906187164)
958 (3773, 15.729103610518131)
959 (4929, 15.72288967151707)
960 (2230, 15.7019649406421)
961 (3366, 15.701699789391272)
962 (4619, 15.688948559637689)
963 (3876, 15.677555074006134)
964 (5222, 15.676224375859089)
965 (3237, 15.674497639982375)
966 (2465, 15.667785156613796)
967 (4537, 15.64781041910884)
968 (3223, 15.641330600523242)
969 (5444, 15.620280446003674)
970 (4480, 15.602095220542362)
971 (3021, 15.581985649705832)
972 (2357, 15.569228692234539)
973 (5523, 15.567383939295258)
974 (5346, 15.56692613897928)
975 (4741, 15.557969650816279)
976 (3379, 15.542724262165413)
977 (5286, 15.538702780602378)
978 (3128, 15.537141881120411)
979 (2905, 15.500378082522444)
980 (4413, 15.473162034629256)
981 (2220, 15.47296155472022)
982 (5544, 15.470498881929554)
983 (3288, 15.466526296393861)
984 (3290, 15.46361373758285)
985 (5706, 15.422533344362883)
986 (5683, 15.41351914230364)
987 (5243, 15.406725483475206)
988 (4329, 15.4005035128376)
989 (1432, 15.398015817702632)
990 (4600, 15.395365498397442)
991 (5441, 15.394573507114679)
992 (3161, 15.391624130244905)
993 (3532, 15.387554857271995)
994 (5446, 15.381520599167887)
995 (2283, 15.378687670850011)
996 (5417, 15.341077440686991)
997 (4576, 15.32714471226525)
998 (4083, 15.324843112125926)
999 (1991, 15.309122716699338)
1000 (131, 15.288625881921458)
1001 (1011, 15.262392737821656)
1002 (2262, 15.252890923905614)
1003 (296, 15.245726477241382)
1004 (5063, 15.232259204499778)
1005 (4526, 15.228963710346356)
1006 (4461, 15.211716996949564)
1007 (4309, 15.197758039226256)
1008 (648, 15.192324791658343)
1009 (2158, 15.181465861587215)
1010 (1091, 15.178617463758423)
1011 (1168, 15.144649954624946)
1012 (5738, 15.136791171179389)
1013 (5000, 15.119826650205955)
1014 (3559, 15.100377678596759)
1015 (4180, 15.088639099238218)
1016 (3070, 15.062209696792557)
1017 (4693, 15.032208011720098)
1018 (5196, 15.029722813901076)
1019 (5575, 15.023734524671635)
1020 (3826, 14.965260519702548)
1021 (4512, 14.96074075037804)
1022 (5528, 14.960234275576667)
1023 (2928, 14.957118630762489)
1024 (2815, 14.936359187540234)
1025 (1973, 14.932503697805316)
1026 (346, 14.923762295884668)
1027 (5289, 14.917896451073599)
1028 (5518, 14.912033532986415)
1029 (5631, 14.904318353842427)
1030 (1781, 14.901511998830898)
1031 (3354, 14.894592694757691)
1032 (1515, 14.893778870120389)
1033 (5512, 14.880655071780266)
1034 (5537, 14.847360754474133)
1035 (4239, 14.84649013223571)
1036 (2187, 14.843466014875478)
1037 (4996, 14.832481226879029)
1038 (63, 14.827536261267042)
1039 (537, 14.825947857780982)
1040 (5230, 14.824749442490697)
1041 (1967, 14.815416101738279)
1042 (4219, 14.784739249095562)
1043 (1729, 14.762365358238963)
1044 (3931, 14.747522319508064)
1045 (1539, 14.745654019523762)
1046 (5517, 14.720198709396445)
1047 (5676, 14.675386245145576)
1048 (4918, 14.665378547911114)
1049 (1741, 14.653749535355942)
1050 (4169, 14.633949159145402)
1051 (3490, 14.633923453844115)
1052 (1661, 14.620136588116802)
1053 (95, 14.581287367027297)
1054 (4392, 14.562928335120791)
1055 (3211, 14.539361555471395)
1056 (4723, 14.53512939864839)
1057 (3470, 14.529456294460449)
1058 (2993, 14.500026941607786)
1059 (5680, 14.499322252561415)
1060 (4714, 14.460707313434963)
1061 (1739, 14.455460985159744)
1062 (2733, 14.453025980005568)
1063 (5675, 14.451339768472266)
1064 (5110, 14.451241429420971)
1065 (589, 14.415542799397628)
1066 (5688, 14.399305425394509)
1067 (3267, 14.372036799424535)
1068 (1791, 14.361195890744753)
1069 (4400, 14.32059205645646)
1070 (486, 14.268928666419468)
1071 (1546, 14.26595550150105)
1072 (4376, 14.25202463070994)
1073 (3205, 14.234785171141723)
1074 (3692, 14.203152108109922)
1075 (2028, 14.198935674954003)
1076 (2583, 14.174831174156035)
1077 (3289, 14.146461747815106)
1078 (4203, 14.130060732212831)
1079 (1675, 14.100163253817675)
1080 (5784, 14.04056074742531)
1081 (5251, 14.013155122331428)
1082 (612, 14.01088400368095)
1083 (5193, 14.001258463846426)
1084 (5017, 13.966677426617011)
1085 (1334, 13.953128892188136)
1086 (4241, 13.933713279068046)
1087 (1246, 13.925097223396296)
1088 (5461, 13.911185199417073)
1089 (3734, 13.875084148284747)
1090 (3526, 13.874168167452567)
1091 (288, 13.869050436388505)
1092 (4056, 13.850059602762947)
1093 (1512, 13.811153787416362)
1094 (1860, 13.809362619966898)
1095 (1126, 13.804885739408208)
1096 (100, 13.802858432790256)
1097 (378, 13.802730024104591)
1098 (1982, 13.781400442538724)
1099 (5476, 13.779970653075351)
1100 (2915, 13.748286278948655)
1101 (956, 13.73625414937805)
1102 (766, 13.729319147856115)
1103 (4845, 13.724510148577341)
1104 (1302, 13.713444952634708)
1105 (5144, 13.707931760472274)
1106 (5564, 13.695643699734433)
1107 (3693, 13.693161421525463)
1108 (3196, 13.677930663735719)
1109 (4255, 13.67548475539647)
1110 (5623, 13.669496878479896)
1111 (753, 13.667210682001979)
1112 (3597, 13.662951416938878)
1113 (3785, 13.64633787646159)
1114 (2073, 13.641328257172029)
1115 (4041, 13.633424264809683)
1116 (4063, 13.633413910980989)
1117 (5213, 13.609728287582016)
1118 (5685, 13.590941264052148)
1119 (4641, 13.573864505016155)
1120 (1452, 13.564265185382622)
1121 (4617, 13.561759703232232)
1122 (865, 13.56044856176203)
1123 (3868, 13.531670000425242)
1124 (1987, 13.52561463710108)
1125 (2960, 13.512298555554917)
1126 (4212, 13.460135693381012)
1127 (5246, 13.445006340092711)
1128 (5203, 13.44073061889771)
1129 (5556, 13.440384791814045)
1130 (2881, 13.426547001922478)
1131 (5076, 13.425720628501416)
1132 (3828, 13.404809845879507)
1133 (1699, 13.389235479627811)
1134 (201, 13.387843643221553)
1135 (1014, 13.337017344379746)
1136 (441, 13.332838004836415)
1137 (2064, 13.328783505666383)
1138 (5761, 13.324592476898907)
1139 (1332, 13.315493863759452)
1140 (4750, 13.309661125044984)
1141 (2167, 13.298719020847832)
1142 (3700, 13.281903861194248)
1143 (5181, 13.27256063711229)
1144 (4782, 13.261708114728961)
1145 (1942, 13.216161634262818)
1146 (5145, 13.213664147474265)
1147 (980, 13.199918905336794)
1148 (2375, 13.199065567412431)
1149 (4150, 13.193795224636627)
1150 (4908, 13.193563007472459)
1151 (4355, 13.125591095167227)
1152 (1504, 13.122550286008837)
1153 (4653, 13.120934562873485)
1154 (4290, 13.112937983791262)
1155 (2839, 13.106928851340806)
1156 (4491, 13.104758987014554)
1157 (5162, 13.066325265892296)
1158 (4597, 13.065839662511095)
1159 (2408, 13.048126885537204)
1160 (5468, 13.039728312168991)
1161 (4311, 13.035634664837376)
1162 (995, 13.023815908151182)
1163 (3694, 13.013267661397995)
1164 (5681, 13.002785477435985)
1165 (1111, 12.978052971415824)
1166 (5541, 12.974994448258323)
1167 (649, 12.973092748323772)
1168 (1815, 12.963286386418527)
1169 (304, 12.949609414537289)
1170 (4958, 12.922094577087391)
1171 (3681, 12.919569321075128)
1172 (5443, 12.912529605878369)
1173 (2729, 12.90538464677908)
1174 (2576, 12.85940139743148)
1175 (297, 12.85756485998219)
1176 (1075, 12.854005772378812)
1177 (5268, 12.838902874913202)
1178 (4959, 12.838108353790307)
1179 (4159, 12.826074730422967)
1180 (2502, 12.82250077546079)
1181 (2713, 12.80452156484003)
1182 (919, 12.804390155204501)
1183 (5750, 12.798637073520338)
1184 (1758, 12.794886654099287)
1185 (1369, 12.793086436764135)
1186 (4322, 12.79125046422563)
1187 (4925, 12.789850341673333)
1188 (5432, 12.786560739650465)
1189 (5048, 12.728029201400517)
1190 (5128, 12.727837261092795)
1191 (2200, 12.727130032406308)
1192 (3998, 12.722780190315765)
1193 (238, 12.720764983333606)
1194 (1288, 12.719010593402183)
1195 (4182, 12.713443681734166)
1196 (1153, 12.705713461092657)
1197 (2647, 12.683550608032373)
1198 (395, 12.678228611025103)
1199 (5487, 12.659122456459247)
1200 (957, 12.652028191286281)
1201 (3550, 12.63516759423198)
1202 (1912, 12.623450737589785)
1203 (3182, 12.613980027656039)
1204 (1952, 12.598160604549973)
1205 (5647, 12.587100934033437)
1206 (4982, 12.576900182774938)
1207 (3763, 12.568739226221645)
1208 (3926, 12.567643675991377)
1209 (4416, 12.530462983615873)
1210 (3330, 12.525567841630942)
1211 (3511, 12.514051133269344)
1212 (4622, 12.511319321529085)
1213 (2640, 12.498749487287558)
1214 (5056, 12.486498420894346)
1215 (5236, 12.479048049636898)
1216 (2472, 12.475165225589629)
1217 (5348, 12.459934049295082)
1218 (5052, 12.434546619691538)
1219 (4403, 12.412462732870056)
1220 (3562, 12.407001290935455)
1221 (1510, 12.401544274619745)
1222 (3251, 12.386586256565845)
1223 (1251, 12.380766374909594)
1224 (1033, 12.377100438792432)
1225 (5543, 12.356609232590102)
1226 (5779, 12.340428426114721)
1227 (141, 12.320855406353498)
1228 (115, 12.306735714335494)
1229 (4846, 12.294751561810964)
1230 (5113, 12.270823675718589)
1231 (3268, 12.237364775778515)
1232 (1939, 12.223422786206973)
1233 (1277, 12.222416493562314)
1234 (2528, 12.200233105407385)
1235 (4828, 12.190431556507766)
1236 (4252, 12.18946884252399)
1237 (2604, 12.179493406237754)
1238 (5447, 12.163701896214395)
1239 (3142, 12.16065084384762)
1240 (938, 12.154380515283073)
1241 (4637, 12.142446030014174)
1242 (5173, 12.140380679255166)
1243 (509, 12.139709041556182)
1244 (5465, 12.127504265157306)
1245 (4415, 12.12211453230462)
1246 (5032, 12.120377687880868)
1247 (4851, 12.11606654503283)
1248 (3992, 12.113464265886263)
1249 (1540, 12.097707997423173)
1250 (2557, 12.091867709248344)
1251 (1279, 12.08241734845695)
1252 (423, 12.068547137833885)
1253 (2785, 12.057685149396452)
1254 (371, 12.057160851686238)
1255 (5156, 12.053887875172945)
1256 (1305, 12.051849965908993)
1257 (3350, 12.039538457252434)
1258 (4131, 12.037361662594305)
1259 (2603, 12.016633050818243)
1260 (5282, 11.977808854508218)
1261 (5547, 11.963698985690863)
1262 (2630, 11.954913826969443)
1263 (1258, 11.930114395593742)
1264 (4409, 11.922179781495981)
1265 (2923, 11.897209272225012)
1266 (5577, 11.890417431400657)
1267 (3328, 11.881849690867725)
1268 (4146, 11.878505478268952)
1269 (3637, 11.852778909535465)
1270 (3011, 11.846890382740552)
1271 (159, 11.841608618397228)
1272 (3472, 11.838148876429935)
1273 (1294, 11.823836004794908)
1274 (4804, 11.815756945862189)
1275 (247, 11.785195097880356)
1276 (1576, 11.76576922213483)
1277 (4809, 11.764667044934688)
1278 (5568, 11.735181863435693)
1279 (2903, 11.734163038580947)
1280 (3179, 11.731485694987708)
1281 (5085, 11.728584133731275)
1282 (2246, 11.71512725444695)
1283 (2704, 11.698272652359053)
1284 (2910, 11.696683668980628)
1285 (2811, 11.686089945966788)
1286 (3206, 11.680022255924335)
1287 (3227, 11.672556437514757)
1288 (3266, 11.650635215594717)
1289 (1311, 11.636387118331578)
1290 (5127, 11.633873076410721)
1291 (1359, 11.625566691915585)
1292 (4669, 11.603316369936621)
1293 (3257, 11.586976807789421)
1294 (4107, 11.583451890351045)
1295 (4114, 11.562277909867174)
1296 (2702, 11.550111043894775)
1297 (190, 11.544743928558388)
1298 (1760, 11.544285106766665)
1299 (2641, 11.523559408562155)
1300 (1872, 11.501529194256364)
1301 (3373, 11.445330154797981)
1302 (1413, 11.436231717850374)
1303 (4331, 11.426154930704911)
1304 (1891, 11.394997660920575)
1305 (3936, 11.363011232967647)
1306 (4610, 11.353660696226479)
1307 (87, 11.348999136685622)
1308 (470, 11.336376497914863)
1309 (4715, 11.334760615222255)
1310 (3397, 11.329278573364975)
1311 (3835, 11.316624919428435)
1312 (5602, 11.303501503010063)
1313 (4584, 11.284189005981718)
1314 (4474, 11.284171104235966)
1315 (2500, 11.277702039867217)
1316 (3752, 11.246991323303842)
1317 (5567, 11.244057457160128)
1318 (3487, 11.237772073817627)
1319 (2499, 11.23422327918318)
1320 (4640, 11.222988987264001)
1321 (3585, 11.214950757225981)
1322 (996, 11.213099365575548)
1323 (1610, 11.192271924322039)
1324 (3361, 11.1893623531614)
1325 (3258, 11.178579563505904)
1326 (4939, 11.16282104525699)
1327 (4496, 11.158874404892568)
1328 (4973, 11.138031962877657)
1329 (4957, 11.135446348923313)
1330 (4734, 11.116988210369376)
1331 (3008, 11.116752257922117)
1332 (4802, 11.106183360390128)
1333 (5536, 11.103280357473544)
1334 (128, 11.089180782227491)
1335 (1896, 11.081408779561627)
1336 (250, 11.078794351570499)
1337 (894, 11.074838998891993)
1338 (4534, 11.071368681143028)
1339 (1547, 11.048406399886092)
1340 (2185, 11.045178148525981)
1341 (3481, 11.045049879827104)
1342 (1474, 11.044133332636875)
1343 (2059, 11.024366049746071)
1344 (801, 11.013105211856367)
1345 (358, 11.008603233839034)
1346 (5490, 10.992929994646923)
1347 (120, 10.992453693512706)
1348 (4823, 10.947359595022476)
1349 (3754, 10.94250239645657)
1350 (847, 10.90663795045386)
1351 (1764, 10.903447685100092)
1352 (2080, 10.896404848882943)
1353 (5089, 10.889709865983976)
1354 (5734, 10.878229725224525)
1355 (2078, 10.872974992774697)
1356 (3387, 10.867263881490604)
1357 (4575, 10.832238473440935)
1358 (3737, 10.826096885670264)
1359 (1289, 10.805099736478933)
1360 (1323, 10.750783183986783)
1361 (3534, 10.736777460892743)
1362 (2601, 10.723499806499085)
1363 (3946, 10.697920495734863)
1364 (503, 10.681213563746553)
1365 (3538, 10.675767080130997)
1366 (3755, 10.629115030603234)
1367 (5640, 10.606095730015245)
1368 (2611, 10.603069020624066)
1369 (5202, 10.579256095130384)
1370 (4110, 10.560754616507515)
1371 (4824, 10.557616345462161)
1372 (5664, 10.523768460441961)
1373 (4187, 10.515654270131346)
1374 (4043, 10.50889632506262)
1375 (5705, 10.502549775049738)
1376 (3189, 10.487889547370861)
1377 (5495, 10.480208127020635)
1378 (5593, 10.478353452572376)
1379 (4395, 10.459661205801744)
1380 (3502, 10.437857713842137)
1381 (4941, 10.427753236029265)
1382 (3458, 10.424322248771539)
1383 (3575, 10.388519411872714)
1384 (3609, 10.355365455494585)
1385 (2530, 10.341981982520666)
1386 (3985, 10.340024819116499)
1387 (1701, 10.306298256979773)
1388 (5462, 10.294879376279606)
1389 (5190, 10.292110090108798)
1390 (3555, 10.2903618090847)
1391 (4533, 10.256882507858521)
1392 (708, 10.238174799428345)
1393 (3061, 10.237226889131529)
1394 (180, 10.230478868437963)
1395 (3507, 10.214118344192876)
1396 (2198, 10.17580603588091)
1397 (2950, 10.170910233882028)
1398 (900, 10.169088112301377)
1399 (3537, 10.147304822065408)
1400 (3216, 10.141783161528267)
1401 (4807, 10.13916177799782)
1402 (3929, 10.11608664506549)
1403 (173, 10.098787040640364)
1404 (369, 10.084882910693322)
1405 (2620, 10.078380603465495)
1406 (313, 10.077075593640346)
1407 (1076, 10.067530964228544)
1408 (5298, 10.047826357829113)
1409 (3316, 10.041239580836455)
1410 (1672, 10.028245779379317)
1411 (3335, 10.014622871063569)
1412 (5314, 10.010155332615319)
1413 (94, 9.9716362293170082)
1414 (4266, 9.9204225486219588)
1415 (2773, 9.9146957304329923)
1416 (4230, 9.8884977288492273)
1417 (5628, 9.8865584519360965)
1418 (4718, 9.8637744747138125)
1419 (5276, 9.8542649768472632)
1420 (4635, 9.7942747412050846)
1421 (3229, 9.7688388668465791)
1422 (5530, 9.7504578190519613)
1423 (5226, 9.7432929065130498)
1424 (4272, 9.6939594637518045)
1425 (4209, 9.6937431410971175)
1426 (2789, 9.6818069815932439)
1427 (1541, 9.628623781625091)
1428 (4246, 9.6090884664784308)
1429 (5163, 9.5495145956336671)
1430 (3576, 9.5404030620617615)
1431 (2221, 9.5402657787980569)
1432 (5448, 9.5369608589893957)
1433 (5299, 9.5240919594083682)
1434 (1684, 9.5082990367539963)
1435 (3796, 9.4923852552409365)
1436 (5086, 9.4922102713988643)
1437 (4268, 9.4803334677267834)
1438 (5090, 9.4148131003099174)
1439 (3278, 9.4134919669496142)
1440 (5409, 9.4077140521528282)
1441 (5531, 9.4036873934747351)
1442 (5596, 9.402229635957795)
1443 (3233, 9.3816997218050666)
1444 (4555, 9.3717918490818963)
1445 (4064, 9.3659064771314071)
1446 (3885, 9.31898193391633)
1447 (3783, 9.3097659915186366)
1448 (5263, 9.3058229805620574)
1449 (2353, 9.2680399417399943)
1450 (2190, 9.2443729627612274)
1451 (5539, 9.235747245447735)
1452 (910, 9.2248701590040767)
1453 (4390, 9.22434584284888)
1454 (4010, 9.1861620287151649)
1455 (935, 9.1586239131052309)
1456 (2676, 9.1582701731073328)
1457 (1810, 9.1426759592612683)
1458 (5720, 9.1342966945529209)
1459 (5581, 9.1215155219381892)
1460 (4508, 9.1004201711130008)
1461 (606, 9.0935791143645517)
1462 (5227, 9.0793597593643121)
1463 (4026, 9.0629992624170264)
1464 (5580, 9.0257453848653864)
1465 (5740, 9.021047873140672)
1466 (3240, 8.9998365831960232)
1467 (5285, 8.9977323073189108)
1468 (1828, 8.9946138110180271)
1469 (4827, 8.9940534512586883)
1470 (2665, 8.9912889751162144)
1471 (2848, 8.986191043713438)
1472 (3979, 8.9725561216239882)
1473 (4051, 8.9658826370734985)
1474 (692, 8.9627699745538418)
1475 (4998, 8.9602807232961617)
1476 (5400, 8.9485042060374838)
1477 (5255, 8.9445112690215574)
1478 (388, 8.9403729670259828)
1479 (4077, 8.9320055105536209)
1480 (3673, 8.9263432456462528)
1481 (3542, 8.9261639347021173)
1482 (4054, 8.8977785617838698)
1483 (181, 8.8952034263230679)
1484 (1795, 8.8912471817930392)
1485 (4572, 8.8528803504931375)
1486 (1908, 8.823252288045575)
1487 (4791, 8.805005301849425)
1488 (4682, 8.7845930784384088)
1489 (5404, 8.7797878848542226)
1490 (3197, 8.7592781821525918)
1491 (2145, 8.7579709187924237)
1492 (4206, 8.7422701554569375)
1493 (587, 8.7341547779292465)
1494 (3067, 8.7308645152349982)
1495 (69, 8.7227738577277307)
1496 (1633, 8.7101297108282836)
1497 (3535, 8.7088297374793981)
1498 (539, 8.705811828620309)
1499 (578, 8.7012048520655902)
1500 (3533, 8.6955033634735805)
1501 (4098, 8.6864848950993565)
1502 (3865, 8.6733924979814212)
1503 (5739, 8.6611075277038001)
1504 (2980, 8.6604884453921045)
1505 (5652, 8.635145906260572)
1506 (2144, 8.6137068175510105)
1507 (5103, 8.6084100910396621)
1508 (3679, 8.5787183811863095)
1509 (4769, 8.5699440812379262)
1510 (4775, 8.5458069835739092)
1511 (5752, 8.5313790824374252)
1512 (5573, 8.5249166300328181)
1513 (3847, 8.5120449177487352)
1514 (5023, 8.5117754814366258)
1515 (2171, 8.499686162236225)
1516 (2916, 8.4868317452692477)
1517 (2906, 8.4826846227418109)
1518 (3636, 8.4793110750883347)
1519 (4805, 8.4713803820149494)
1520 (5147, 8.4704365124719203)
1521 (3991, 8.4580077313437787)
1522 (4654, 8.4450051301722091)
1523 (3988, 8.4387341043795132)
1524 (5642, 8.4207825941600536)
1525 (3751, 8.4143519341391375)
1526 (2216, 8.4126071757659346)
1527 (4712, 8.4066945449141279)
1528 (1553, 8.4006013721415247)
1529 (5040, 8.3952031544725916)
1530 (3220, 8.3787376857731388)
1531 (4913, 8.3753031853665352)
1532 (3707, 8.3661972582364079)
1533 (4598, 8.351082455319796)
1534 (291, 8.3496694222107575)
1535 (5026, 8.3491590691431465)
1536 (3075, 8.339723570142576)
1537 (5248, 8.3360346410498884)
1538 (5570, 8.3305898547054049)
1539 (4334, 8.3283657834837062)
1540 (2673, 8.3250587532115805)
1541 (937, 8.3053473786340284)
1542 (5650, 8.2932718823749951)
1543 (5168, 8.286767279745261)
1544 (5333, 8.2802314195263769)
1545 (4931, 8.2775489304272192)
1546 (467, 8.2389626403221463)
1547 (5407, 8.2295961251314296)
1548 (1761, 8.2024940139088773)
1549 (4969, 8.1846088742344723)
1550 (244, 8.1755646044648813)
1551 (79, 8.1691270018184738)
1552 (5096, 8.1681622638310483)
1553 (687, 8.1598346957605958)
1554 (1721, 8.1569284903388954)
1555 (4732, 8.083891348381238)
1556 (2656, 8.0775128246773722)
1557 (5424, 8.0670377936296234)
1558 (97, 8.0582289952343249)
1559 (1155, 8.0569586374356721)
1560 (1370, 8.0556447290188835)
1561 (5010, 8.0537519796203956)
1562 (102, 8.049646510688369)
1563 (5317, 8.0407534498940816)
1564 (3045, 8.0259658929131383)
1565 (4211, 8.0224499206941005)
1566 (4030, 8.0016938904540176)
1567 (2022, 7.9977651923506361)
1568 (5331, 7.9798294853098346)
1569 (2411, 7.9729226901221892)
1570 (2660, 7.9617234823318634)
1571 (2846, 7.9517385969372105)
1572 (4161, 7.9477593864442131)
1573 (5259, 7.9383065719428378)
1574 (3053, 7.9219054469697436)
1575 (1940, 7.8890504793990957)
1576 (3324, 7.8888679671022546)
1577 (5658, 7.8474180534967051)
1578 (815, 7.8372376839995734)
1579 (590, 7.837118315118615)
1580 (2805, 7.832773162044588)
1581 (4232, 7.8265081490869424)
1582 (3013, 7.8250934086656727)
1583 (1719, 7.7973653690479043)
1584 (4213, 7.7757418134905851)
1585 (4792, 7.7557352824558397)
1586 (1880, 7.7509165792774084)
1587 (5179, 7.7504828927246283)
1588 (3710, 7.7490842788275627)
1589 (4191, 7.6946909341481842)
1590 (4685, 7.6742019659273808)
1591 (4192, 7.6651946894442613)
1592 (240, 7.6632468058032046)
1593 (2977, 7.6489390851584993)
1594 (5100, 7.6439258957325311)
1595 (1228, 7.6248210135568808)
1596 (2560, 7.6057483406878239)
1597 (3331, 7.597820706629439)
1598 (2992, 7.5843263202367881)
1599 (4125, 7.5771798305044777)
1600 (3499, 7.5758028800624579)
1601 (548, 7.5703420229093847)
1602 (5450, 7.5398415004248482)
1603 (357, 7.4844086982880951)
1604 (4332, 7.4767040228518553)
1605 (4091, 7.429739662364387)
1606 (4286, 7.4099037524464881)
1607 (341, 7.3837719587806561)
1608 (2833, 7.3687379827514903)
1609 (2874, 7.3567801958710808)
1610 (5661, 7.3539333364811839)
1611 (2929, 7.3251422375652959)
1612 (4079, 7.3248234724843044)
1613 (3282, 7.3208370180205984)
1614 (5635, 7.3003343327161714)
1615 (3633, 7.2979024443276206)
1616 (4729, 7.2781637222804791)
1617 (457, 7.2761037095262591)
1618 (4013, 7.2722979427596046)
1619 (302, 7.2656881732126504)
1620 (3881, 7.26343471622571)
1621 (5682, 7.2294608514827976)
1622 (4412, 7.1917984704791262)
1623 (4348, 7.1689618913745115)
1624 (435, 7.1672600169842466)
1625 (5050, 7.1539912939400914)
1626 (4042, 7.1270501838655953)
1627 (2544, 7.1112538978168311)
1628 (3120, 7.1050447640091745)
1629 (1646, 7.0840326230964372)
1630 (3270, 7.0838484455808288)
1631 (5586, 7.0817424350872251)
1632 (4615, 7.066590315148507)
1633 (2479, 7.0534646282325308)
1634 (1350, 7.0033695804105065)
1635 (5719, 7.0009573189773988)
1636 (5746, 7.000787434906881)
1637 (4336, 6.9987353893028219)
1638 (4683, 6.9969478756027801)
1639 (2002, 6.9166402280729233)
1640 (1307, 6.8968381437287398)
1641 (1922, 6.8961419426192592)
1642 (4173, 6.8938625699296825)
1643 (3840, 6.8809865902891261)
1644 (5180, 6.8761008759983007)
1645 (4557, 6.8573099852984196)
1646 (4034, 6.8529052481442365)
1647 (2359, 6.8320708385221529)
1648 (4737, 6.7756669097484918)
1649 (3303, 6.7710881550905473)
1650 (401, 6.756403748447636)
1651 (4176, 6.7015550135066881)
1652 (5002, 6.6819511957546514)
1653 (4594, 6.671596085236791)
1654 (3789, 6.6665580467366645)
1655 (4529, 6.6484992927930637)
1656 (1095, 6.6431330225195531)
1657 (3180, 6.6274698327493802)
1658 (5215, 6.6066961849948349)
1659 (2969, 6.6066138137361889)
1660 (640, 6.60096378657577)
1661 (5182, 6.5966075388651673)
1662 (5201, 6.5935517123836682)
1663 (5051, 6.5547845013914143)
1664 (2370, 6.5482018857289397)
1665 (4097, 6.5431343822072394)
1666 (2988, 6.5244627043322252)
1667 (5141, 6.5216714096980892)
1668 (2856, 6.4813799389731193)
1669 (1188, 6.4588702301801648)
1670 (3337, 6.4550938952585373)
1671 (4495, 6.4457678930151348)
1672 (5731, 6.4104775463938504)
1673 (3147, 6.3969582952545583)
1674 (4288, 6.3708899531039815)
1675 (5513, 6.3647846719675423)
1676 (2817, 6.363458173110959)
1677 (144, 6.357146424840872)
1678 (5721, 6.353894855807094)
1679 (2832, 6.3496689634175496)
1680 (3024, 6.3477791332905982)
1681 (4582, 6.334544425459173)
1682 (3037, 6.3326610496927884)
1683 (337, 6.32593010140467)
1684 (604, 6.3252522694191766)
1685 (4829, 6.3196448167319303)
1686 (3221, 6.3169022810573381)
1687 (2367, 6.3103273922692065)
1688 (3175, 6.2698994677602906)
1689 (4986, 6.2563700076998483)
1690 (5084, 6.25074136718706)
1691 (3634, 6.2463331806330959)
1692 (4373, 6.2419603388348079)
1693 (3723, 6.2396685558219644)
1694 (4314, 6.238159614192142)
1695 (4855, 6.2358359080838248)
1696 (335, 6.2316439323947188)
1697 (3709, 6.2286680146995126)
1698 (2890, 6.2143166143214739)
1699 (4847, 6.199049541989603)
1700 (2897, 6.1937304692045219)
1701 (3408, 6.1893132162521587)
1702 (4935, 6.1710178029086489)
1703 (3872, 6.1697576853997909)
1704 (1740, 6.1550227149874059)
1705 (4731, 6.1513056974996774)
1706 (3659, 6.1423648860098092)
1707 (1243, 6.1420369849159702)
1708 (5715, 6.1400191774708155)
1709 (2439, 6.1368454358077829)
1710 (4356, 6.1014287031394856)
1711 (2095, 6.0969698851294005)
1712 (5660, 6.0936381345419077)
1713 (4337, 6.0816940614267132)
1714 (5036, 6.0477276279620984)
1715 (4849, 6.0332857480005631)
1716 (5241, 6.0007661448549543)
1717 (5014, 5.9982991815629623)
1718 (68, 5.9966498577731429)
1719 (5198, 5.9518138035725734)
1720 (3548, 5.9322218423659603)
1721 (1293, 5.9308293883469236)
1722 (117, 5.9291340739968144)
1723 (4151, 5.9130199056867525)
1724 (2148, 5.9062700032396567)
1725 (3925, 5.900259738027728)
1726 (4562, 5.8673592955902958)
1727 (5785, 5.8290473726473131)
1728 (1086, 5.8235309370155681)
1729 (5060, 5.8065994709451907)
1730 (1710, 5.7992745220750397)
1731 (1230, 5.7703770339451275)
1732 (4656, 5.7529245025618403)
1733 (1148, 5.7429588768898787)
1734 (3654, 5.7177054734001471)
1735 (4375, 5.7080617581786992)
1736 (4235, 5.6865215925276624)
1737 (5540, 5.67290785835928)
1738 (4783, 5.6422661415966049)
1739 (5312, 5.6319524548928772)
1740 (1528, 5.6071827590495582)
1741 (4207, 5.5970158479708871)
1742 (4175, 5.5778283672763251)
1743 (4310, 5.5745388468290553)
1744 (3740, 5.544014920597041)
1745 (360, 5.5343280928965459)
1746 (1444, 5.5197070434905724)
1747 (108, 5.5102448163084476)
1748 (4664, 5.501469567834274)
1749 (5401, 5.4792985813645183)
1750 (3187, 5.4397164232120705)
1751 (3274, 5.4262440479439427)
1752 (422, 5.4185462830814854)
1753 (3167, 5.4105433219242087)
1754 (4553, 5.4049763863912297)
1755 (930, 5.4006273687083199)
1756 (709, 5.3894531980154259)
1757 (167, 5.3829379438531468)
1758 (4951, 5.3734497787398681)
1759 (4970, 5.3621955905768104)
1760 (3961, 5.3515863594768831)
1761 (3586, 5.3506517728768213)
1762 (3473, 5.3360336629920022)
1763 (968, 5.3347822315912348)
1764 (5012, 5.3265292136039948)
1765 (8, 5.311442689562142)
1766 (5704, 5.2808603071147431)
1767 (2577, 5.2777587746337735)
1768 (877, 5.2585519112029964)
1769 (4260, 5.2416998664638852)
1770 (1989, 5.2298684685555514)
1771 (2579, 5.224462111212965)
1772 (848, 5.2141149205755477)
1773 (841, 5.210463264960957)
1774 (4475, 5.206711267217214)
1775 (4262, 5.1820754838850069)
1776 (4801, 5.1488209456378291)
1777 (4662, 5.1258701625327454)
1778 (4788, 5.1221119584356378)
1779 (333, 5.1179635462727191)
1780 (1247, 5.0822905061873485)
1781 (4684, 5.0638269181331266)
1782 (4902, 5.0420791911275931)
1783 (5619, 5.0383925755998682)
1784 (997, 5.0158631660671009)
1785 (4406, 5.003540709339374)
1786 (5256, 4.9849301730876192)
1787 (4354, 4.9743836756952513)
1788 (5552, 4.9556689527649667)
1789 (5231, 4.9491621567029558)
1790 (2840, 4.9224338799434317)
1791 (281, 4.9058204455527621)
1792 (5094, 4.9019514519391203)
1793 (21, 4.8982818183125119)
1794 (3138, 4.8407583577146474)
1795 (5072, 4.8304934116492992)
1796 (4603, 4.8231640753087097)
1797 (5235, 4.7832849050961368)
1798 (4926, 4.7782763488840008)
1799 (830, 4.7681465927246851)
1800 (3461, 4.7611275038664651)
1801 (4542, 4.7513050725804051)
1802 (4721, 4.7443439919358079)
1803 (2152, 4.6877105755554833)
1804 (4571, 4.677383871814043)
1805 (5696, 4.6740825769663594)
1806 (451, 4.6416556245945344)
1807 (4024, 4.6216384804092216)
1808 (5695, 4.619314593057176)
1809 (5565, 4.6122209915649046)
1810 (5119, 4.6009075530401029)
1811 (5599, 4.583150801987137)
1812 (5507, 4.5729591149605904)
1813 (5459, 4.541810839635728)
1814 (1259, 4.5314680701605017)
1815 (5690, 4.5044162743410476)
1816 (1422, 4.4920241852217329)
1817 (253, 4.4505027542034572)
1818 (3344, 4.4259194499292871)
1819 (81, 4.4209866337051658)
1820 (5655, 4.4172185010213649)
1821 (5274, 4.4057461331566428)
1822 (2429, 4.3955240992215678)
1823 (1495, 4.3833733947811391)
1824 (2538, 4.3351333963167216)
1825 (4104, 4.3306281172318073)
1826 (4120, 4.319311053549546)
1827 (3632, 4.3033551150268119)
1828 (4704, 4.2872652603265919)
1829 (3042, 4.2813555091932685)
1830 (4984, 4.2752428604789703)
1831 (4680, 4.2634831111303821)
1832 (5774, 4.2574661380413694)
1833 (5605, 4.2477925912215566)
1834 (3359, 4.237853797634541)
1835 (5425, 4.2280746460884755)
1836 (5453, 4.2161463245678386)
1837 (4008, 4.2077075075858854)
1838 (5694, 4.194941273861291)
1839 (5469, 4.1886449224715596)
1840 (1600, 4.1879537141043306)
1841 (585, 4.1861948591840115)
1842 (5067, 4.1429590202727358)
1843 (4452, 4.1125741031099619)
1844 (3323, 4.1011105614983556)
1845 (3048, 4.1009069558993394)
1846 (3054, 4.0990005563139569)
1847 (4590, 4.0600588835154836)
1848 (3886, 4.0588527085732231)
1849 (4243, 4.0149746078445316)
1850 (3062, 3.9717848854800604)
1851 (3661, 3.9452144259580169)
1852 (4263, 3.9402240155780355)
1853 (4773, 3.9359734805510995)
1854 (5521, 3.9347914626073672)
1855 (3485, 3.923953141829629)
1856 (5716, 3.9074583348503311)
1857 (772, 3.8816506692247112)
1858 (746, 3.8714988048276808)
1859 (4454, 3.8552342953650562)
1860 (3340, 3.853186260650737)
1861 (3845, 3.8251440011559361)
1862 (5607, 3.7964315194901492)
1863 (4018, 3.7916357444153523)
1864 (4817, 3.7582764303694716)
1865 (3596, 3.7302172074644586)
1866 (5727, 3.7242141000673734)
1867 (4777, 3.7214326236867801)
1868 (5574, 3.7144721073330835)
1869 (5612, 3.697747104259967)
1870 (1743, 3.677152927122636)
1871 (5422, 3.5615577092048305)
1872 (5436, 3.5281599971456687)
1873 (4327, 3.5189827110870873)
1874 (3035, 3.5014655126433314)
1875 (5344, 3.4940028789562829)
1876 (2709, 3.4927437741695582)
1877 (4467, 3.4577594860774252)
1878 (3136, 3.4217556761503465)
1879 (1997, 3.4093698146936289)
1880 (4954, 3.3610993784038357)
1881 (5107, 3.3091847647032919)
1882 (4825, 3.3035995938742726)
1883 (4234, 3.2546656991739376)
1884 (5709, 3.2372389381887201)
1885 (1573, 3.2278211585066701)
1886 (4371, 3.2156150880483416)
1887 (4408, 3.2097694148798954)
1888 (2107, 3.2059665980783976)
1889 (5123, 3.1638825430477722)
1890 (2942, 3.1376734506719277)
1891 (5702, 3.0826224460911158)
1892 (5557, 3.0782488703184092)
1893 (3641, 3.0539430719745049)
1894 (375, 3.0447455028039685)
1895 (228, 3.0248987126785849)
1896 (2895, 3.0201637965632813)
1897 (3219, 2.9908778463455934)
1898 (4579, 2.9684316943848907)
1899 (3036, 2.9612691747071236)
1900 (4166, 2.9519303789271882)
1901 (2761, 2.9480273338101632)
1902 (4482, 2.9392244580621814)
1903 (3510, 2.9383022378535646)
1904 (1599, 2.9229477473576164)
1905 (5238, 2.9032900501673931)
1906 (5510, 2.9017346247120299)
1907 (453, 2.8936774233301268)
1908 (3414, 2.8725325779196353)
1909 (5497, 2.8689213120959494)
1910 (1306, 2.8609418189857192)
1911 (3536, 2.809543421079149)
1912 (4745, 2.7648953954673474)
1913 (2404, 2.7400860966631884)
1914 (1626, 2.7350489113513881)
1915 (5454, 2.726327943186738)
1916 (4156, 2.7252904129182349)
1917 (4657, 2.7241621721413471)
1918 (3530, 2.7226127210775388)
1919 (5662, 2.6952116893627291)
1920 (5025, 2.6828801168430694)
1921 (599, 2.6796512550051825)
1922 (3059, 2.6675529539365068)
1923 (945, 2.6522391381731527)
1924 (3684, 2.5523943005276162)
1925 (5008, 2.5459715726480763)
1926 (2847, 2.5392353858783903)
1927 (1481, 2.5266522809240675)
1928 (4012, 2.453443680536088)
1929 (5019, 2.4399550296330146)
1930 (468, 2.4249445253495452)
1931 (4316, 2.4154190312528234)
1932 (832, 2.3896951461772367)
1933 (4739, 2.3758433078076675)
1934 (271, 2.3528768331460421)
1935 (4053, 2.3459907616074194)
1936 (4335, 2.3193747406024383)
1937 (4378, 2.2885253893875186)
1938 (1716, 2.2460283070541793)
1939 (2532, 2.2245476691802972)
1940 (177, 2.2197710483159767)
1941 (4649, 2.2164849427276887)
1942 (1786, 2.1785390447517301)
1943 (5329, 2.1784256537000424)
1944 (2106, 2.1731576587137034)
1945 (1899, 2.155975627210895)
1946 (4291, 2.1382759946007894)
1947 (3297, 2.1373810849653285)
1948 (514, 2.1104002392788916)
1949 (4776, 2.10752549999936)
1950 (3160, 2.0919319806069883)
1951 (4035, 2.0581370727974173)
1952 (5143, 2.0570142016493689)
1953 (2543, 2.0549796683460921)
1954 (5553, 2.0312558322054972)
1955 (3029, 2.0012105678446233)
1956 (888, 1.9733412866993714)
1957 (4818, 1.960540935785164)
1958 (3997, 1.9046296450651501)
1959 (4296, 1.875614152445225)
1960 (886, 1.8366737309182568)
1961 (3617, 1.7869275164567551)
1962 (3712, 1.786743748548357)
1963 (5003, 1.7821350761119084)
1964 (136, 1.7806593125081491)
1965 (2001, 1.7353097101149333)
1966 (4265, 1.7119372233648948)
1967 (4506, 1.6398028727312761)
1968 (5759, 1.6389429309843759)
1969 (499, 1.6296072797872518)
1970 (2634, 1.6184201644462242)
1971 (5273, 1.615391128682639)
1972 (5240, 1.5866046576372799)
1973 (3932, 1.5520322073853277)
1974 (5486, 1.550140000933057)
1975 (4746, 1.530019884626147)
1976 (3676, 1.5275755900622188)
1977 (5641, 1.5250501189603032)
1978 (714, 1.5161596439605072)
1979 (5560, 1.5047139451403773)
1980 (5464, 1.4714626645031283)
1981 (5207, 1.4552401302084477)
1982 (2586, 1.4389365583288569)
1983 (4901, 1.4331484517071462)
1984 (4854, 1.4266156938314181)
1985 (5135, 1.4144366040051661)
1986 (5250, 1.4138439895597152)
1987 (3006, 1.4125927448594862)
1988 (4768, 1.3628137921052716)
1989 (5421, 1.3297700015758236)
1990 (1994, 1.3283402531410557)
1991 (4065, 1.3129637218326178)
1992 (5080, 1.3037091762849613)
1993 (2830, 1.2893982597573719)
1994 (4516, 1.2278007778775937)
1995 (5639, 1.1859457940752018)
1996 (4470, 1.1668213179193436)
1997 (5670, 1.1023982856714671)
1998 (1965, 1.090569897853273)
1999 (2048, 1.0647725219671678)
2000 (224, 1.0592017519849648)
2001 (2491, 1.0327813882156693)
2002 (5622, 1.0053550304949574)
2003 (5092, 0.9761417379400168)
2004 (5583, 0.96865016883601551)
2005 (4614, 0.94890534621633971)
2006 (4696, 0.93133356181886273)
2007 (1571, 0.92306225375204387)
2008 (3345, 0.92272367815652412)
2009 (421, 0.88358742145534686)
2010 (5648, 0.87451545885190352)
2011 (4757, 0.80282520580686545)
2012 (5561, 0.77400478010715901)
2013 (2360, 0.75508258417021423)
2014 (5467, 0.75352458117194587)
2015 (4090, 0.74472559875291322)
2016 (2473, 0.73532766103243552)
2017 (4244, 0.73397829641860635)
2018 (4353, 0.63560642684621382)
2019 (4978, 0.60542778478719317)
2020 (3781, 0.59504797747290039)
2021 (4841, 0.59004411619813801)
2022 (3255, 0.5810465132294006)
2023 (5310, 0.57673949159014182)
2024 (4247, 0.56967675484618518)
2025 (5136, 0.52102984923353091)
2026 (2346, 0.49397001641159521)
2027 (3370, 0.46951477407945041)
2028 (5666, 0.44390572816053364)
2029 (4, 0.4306228979039588)
2030 (3302, 0.40207695189753068)
2031 (4748, 0.40054787318280721)
2032 (1438, 0.35325263374189436)
2033 (2393, 0.35213063533712891)
2034 (2029, 0.34372910656585376)
2035 (2399, 0.33640170027807154)
2036 (3131, 0.29971469544445972)
2037 (322, 0.29050518531574365)
2038 (4643, 0.2426223138440845)
2039 (5598, 0.23411363482723413)
2040 (5519, 0.2039588059208457)
2041 (5633, 0.17749790639714469)
2042 (3026, 0.17714070309077301)
2043 (5252, 0.15788122958137274)
2044 (4692, 0.12808701762749658)
2045 (1984, 0.10877219279701666)
2046 (2051, 0.106900624636147)
2047 (4455, 0.051754769014466184)
2048 (5183, 0.021657653092045592)
2049 (5438, 0.021620813775720116)
2050 (4240, 0.0047725057973673213)
2051 (5756, -0.025725686764515032)
2052 (5491, -0.072956568325318827)
2053 (2224, -0.092716384413370712)
2054 (5095, -0.13291734696126523)
2055 (5551, -0.18060974026021759)
2056 (4795, -0.18869716011348245)
2057 (4671, -0.20309189205791689)
2058 (5247, -0.261153708030605)
2059 (1708, -0.31007548659930684)
2060 (1941, -0.33289780913682776)
2061 (114, -0.33363983691359994)
2062 (3049, -0.34906798944419032)
2063 (5082, -0.34995765495612874)
2064 (4943, -0.38176302639685034)
2065 (4383, -0.39599653182013633)
2066 (4767, -0.40484375642916787)
2067 (3705, -0.41905934952329016)
2068 (619, -0.42097792414944402)
2069 (5458, -0.49850062275081131)
2070 (555, -0.52161407588653574)
2071 (5430, -0.53418942100861266)
2072 (4816, -0.5600048985580417)
2073 (2340, -0.58763011185029335)
2074 (4076, -0.65196111468747464)
2075 (3667, -0.66325879978475655)
2076 (5600, -0.6939566186094237)
2077 (3405, -0.69641124165258717)
2078 (5175, -0.7023231438383899)
2079 (2554, -0.71773346944042826)
2080 (4639, -0.88952670556392222)
2081 (5747, -0.89500791634394306)
2082 (2177, -0.97872065290881949)
2083 (5327, -1.0722682284577238)
2084 (3701, -1.1015037854017034)
2085 (3215, -1.137839151782627)
2086 (1954, -1.2110150334145859)
2087 (867, -1.2520942589985655)
2088 (5295, -1.2571771062365311)
2089 (1769, -1.2889849716059696)
2090 (2600, -1.2980531094685652)
2091 (2402, -1.3271804306614077)
2092 (702, -1.3319361071804292)
2093 (3184, -1.351575711435886)
2094 (4538, -1.4163971540511102)
2095 (4050, -1.4636790030704232)
2096 (2918, -1.4902582157364981)
2097 (3581, -1.5151767870730528)
2098 (5439, -1.5853247139904867)
2099 (5714, -1.5867780832793148)
2100 (5532, -1.6244607961837225)
2101 (840, -1.6988992355292591)
2102 (668, -1.7469720080000755)
2103 (5134, -1.751444574360183)
2104 (4507, -1.7589774507875013)
2105 (4111, -1.8220414181634954)
2106 (5004, -2.0065712363337953)
2107 (4015, -2.0362138680672066)
2108 (1566, -2.0695864220133715)
2109 (3482, -2.0981818433851744)
2110 (4466, -2.1127643414188801)
2111 (611, -2.2163320984137331)
2112 (3780, -2.226349661083546)
2113 (4019, -2.2273438443227018)
2114 (5205, -2.230134885626827)
2115 (647, -2.2400022134171582)
2116 (4730, -2.2602480183701097)
2117 (3655, -2.3305694608098957)
2118 (771, -2.3430935059703026)
2119 (5142, -2.3566268850034433)
2120 (2994, -2.3774185623726414)
2121 (751, -2.4273124414396365)
2122 (4574, -2.4918028221418438)
2123 (5150, -2.561177364672492)
2124 (5733, -2.6282695385970252)
2125 (4248, -2.6380690999748673)
2126 (2721, -2.6542972068470325)
2127 (4904, -2.6548016749417389)
2128 (2518, -2.6579648694692923)
2129 (3355, -2.7528315293680241)
2130 (5713, -2.766682055563467)
2131 (5347, -2.7714880064449332)
2132 (3212, -2.8792565205184353)
2133 (4517, -2.9088237460578235)
2134 (2517, -2.9257945394259051)
2135 (1108, -2.9313663581768266)
2136 (2485, -2.9349755872535885)
2137 (5412, -2.9815031126056084)
2138 (3591, -2.9972292804763634)
2139 (1847, -3.0000025909355545)
2140 (5161, -3.0158385352183785)
2141 (4842, -3.059026396632091)
2142 (4965, -3.112330220347594)
2143 (2093, -3.1399361151034957)
2144 (1450, -3.1700574134973847)
2145 (932, -3.2171394700113658)
2146 (5068, -3.251448014120383)
2147 (5654, -3.3031488071002291)
2148 (4964, -3.3602302648260802)
2149 (5663, -3.386158192785258)
2150 (5104, -3.454627759093805)
2151 (5323, -3.4779891630384032)
2152 (3204, -3.5148837498524035)
2153 (4835, -3.5384845206634195)
2154 (1398, -3.6177075500988787)
2155 (4226, -3.6181133040445976)
2156 (4140, -3.705421760723965)
2157 (5558, -3.8119715094366144)
2158 (4267, -3.8276445646769477)
2159 (5234, -3.8908257482084974)
2160 (5781, -3.9339003869431557)
2161 (3792, -3.9373485196064455)
2162 (2458, -3.9955960793539091)
2163 (4531, -3.996580181169505)
2164 (2264, -4.033056564008124)
2165 (2539, -4.112934324539955)
2166 (3846, -4.1501753752154844)
2167 (5233, -4.1842216305773121)
2168 (836, -4.2597765369843046)
2169 (3464, -4.2644411239355904)
2170 (5699, -4.3277385451333092)
2171 (1827, -4.3470836109079309)
2172 (3544, -4.4090657793669799)
2173 (3192, -4.4120840875025706)
2174 (3541, -4.4157668439706024)
2175 (2449, -4.4167589173219044)
2176 (1868, -4.5983617045101655)
2177 (5726, -4.6698648760063621)
2178 (2265, -4.7225930742201836)
2179 (4627, -4.752914102407293)
2180 (216, -4.7657849800324001)
2181 (5686, -4.8227216553570589)
2182 (3168, -4.8353710303150521)
2183 (2084, -4.9368330301579419)
2184 (4989, -4.978373990407686)
2185 (5762, -4.9835845744118004)
2186 (5546, -5.0262675882466166)
2187 (5527, -5.0374761431736772)
2188 (4990, -5.1100833957064697)
2189 (4762, -5.1455489972585147)
2190 (2978, -5.1510790800511268)
2191 (5775, -5.1755452384034095)
2192 (3607, -5.25442469221721)
2193 (4942, -5.2864572751665966)
2194 (5020, -5.521324413322783)
2195 (4338, -5.5276242049978359)
2196 (3680, -5.5373933748993105)
2197 (5542, -5.5377651549835942)
2198 (4153, -5.5426676387264635)
2199 (4987, -5.6683603138744338)
2200 (1027, -5.6803363876262569)
2201 (4830, -5.7548434993493363)
2202 (3516, -5.7751806075213734)
2203 (4955, -5.7769715666336863)
2204 (4405, -5.8318393032482447)
2205 (4501, -5.8721651467226632)
2206 (2927, -5.887759777504157)
2207 (3468, -5.9028875217862353)
2208 (5636, -5.9095506695055677)
2209 (5149, -5.973297071590304)
2210 (4490, -6.0895464779941246)
2211 (4628, -6.327595261061445)
2212 (2345, -6.6530454805753241)
2213 (3687, -6.6703101692716835)
2214 (3091, -6.8902256773708102)
2215 (4601, -6.9110338533227935)
2216 (4514, -6.9875467838791554)
2217 (4404, -7.1951300173719952)
2218 (4045, -7.5551472165230793)
2219 (3976, -7.5588837395043811)
2220 (5225, -7.567522309392178)
2221 (4299, -7.9082538364434409)
2222 (5242, -7.9293943886190421)
2223 (4953, -7.9870087768717317)
2224 (5212, -8.1847908478195244)
2225 (3651, -8.2384444689818821)
2226 (3949, -8.3554317408351366)
2227 (306, -8.4295302364900042)
2228 (1580, -8.6683542509161224)
2229 (4188, -8.8223765576794175)
2230 (1642, -8.8450525822860904)
2231 (3788, -8.8457378508845004)
2232 (5601, -8.9844145115363752)
2233 (5591, -9.243112898548878)
2234 (1468, -9.4538984125703749)
2235 (1818, -9.4628136601583428)
2236 (3104, -9.4737835118595886)
2237 (1625, -9.6972227598921439)
2238 (5151, -9.9385675430136349)
2239 (617, -10.151322803300785)
2240 (5646, -10.274041739561232)
2241 (4661, -10.560623902451077)
2242 (5452, -10.891845219201898)
2243 (5130, -12.327070764611266)
2244 (3975, -12.389703622210016)
2245 (3981, -12.429025986961294)
2246 (2973, -12.539331608387576)
2247 (4217, -14.394933572740818)
2248 (1138, -14.579713512391079)
2249 (256, -15.438268674725213)
2250 (2613, -16.231781671266916)
67.87user 0.10system 1:08.05elapsed 99%CPU (0avgtext+0avgdata 399012maxresident)k
0inputs+0outputs (0major+53269minor)pagefaults 0swaps
Unread 28-03-2015, 15:12
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
MikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond repute
Re: Analysis of team ranking
so is this just if all teams were at the DC regional based on their score?
It would put us in the top 30% of teams...
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
Unread 28-03-2015, 16:01
Originally Posted by dakaufma View Post
It finished in 68 seconds.
Try this instead:
1) compute N = AT∙A
2) compute d = AT∙b
3) compute teamscores = scipy.linalg.cho_solve(scipy.linalg.cho_factor(N), d)
... where A is np.array(matchdata) and b is np.array(matchscores)
The computation time should be reduced from 68 seconds to about 2 seconds or less.
Unread 28-03-2015, 16:09
dakaufma dakaufma is offline
AKA: David Kaufman
FRC #0449 (Blair Robot Project)
dakaufma is an unknown quantity at this point
No, not quite, this is a slightly different computation. I'm trying to answer the question "how much value does each robot contribute to its alliance?"
In most (qualification) matches robots operate reasonably independently from one another. This makes my question a lot easier to answer -- if robots don't influence each other's performance, then each robot should contribute (on average) the same score to any alliance it plays with. So I've got one variable per team -- how many points it contributes to its alliance -- and I'm trying to solve for the set of values for these variables that comes closest to predicting the actual match scores.
The listing above is my estimate of how many points each robot contributes to its alliance (given no interaction with other robots)
Unread 28-03-2015, 16:13
MikLast's Avatar
CAO/Drive Coach
I understand that, then this just means that the teams at the DC regional were skewed, or something else?
My script basically ran instantly on the DC regional alone, it just didn't scale well.
Unread 28-03-2015, 16:22
AKA: David Kaufman
I haven't done any in-depth analysis, but DC doesn't look too far out of line from the set of all regionals.
@MikLast I think I misinterpreted what you were saying. This would be a reasonable estimate of how well teams would do if each team played this game without an alliance. So congrats if you team is in the top 30%, you have a good robot
Unread 28-03-2015, 16:26
MikLast's Avatar
CAO/Drive Coach
Ah, i misunderstood you also then. Thank you for clarifying, and i cant wait to show my team this next week.
Unread 28-03-2015, 20:42
1) compute N = AT∙A
2) compute d = AT∙b
I'd run this test myself but I have Python2.7.5 installed and your Python3 code crashes when I try to run it. Not being very fluent in Python, I'm not in a good position to try to port it.
Based on some testing I did here, I'm fairly confident that your computation time can be dramatically reduced by making the small changes shown above.
