Thread Tools |
Rating:
Display Modes |
I would be willing to bet that the reason for the rust wasn't moisture working into the bag. More likely from being bagged in a warm environment then being put into a cooler environment causing the air in the bag to condense a bit. Doesn't take long for rust to start that is for sure.
Good luck to you guys today, and we will see you there! |
Re: Team 95 Hard At Work - 2015
I've got a few reasons why I think moisture intrusion might have been the case: First, it wasn't as if a few components just rusted, there was a concerning amount of condensed water inside the bag that did not evaporate when the bagged robot was warmed up again. This implies that extra moisture was inside the bag. Second, we have bagged in warm environments numerous times, passed through a cooling cycle, and never saw any moisture condense inside the robot bags before, let alone seen rusted components. Third, and most importantly, the bag had several small holes it in from being transported in the back of a truck. The robot was loaded into a truck while it was raining outside, and then driven for four hours (mostly covered in a tarp) while it was raining/snowing outside. This provided ample opportunity for moisture to get into the bag. It is possible, if not likely, that the cooling of the robot/bag drew moisture and cold air into the bag though. Fortunately we now have a trailer to transport everything with, so hopefully this occurrence will be a one-time fluke. |
It would be fun to bag the robot with giant packets of silica gel. You could even weigh the packets before and after to see how much moisture is adsorbed-- for science!
From what I saw this weekend 95 had another solid showing at Hartford. I really liked the 6 tote grab out of the landfill!
The 6x tote pull is a subset of what we've been working on. In theory, though we have yet to execute on the field, (read: take this with a huge grain of salt) we could collect 8-10 totes from the landfill and make two 4-high stacks, a 4-high and a 5-high stack, or (very optimistically) two 5-high stacks. Unfortunately this mechanism is very much secondary to our RC arm and thus is less robust, many things have to work out well to mine this many totes. The best we've done thus far is to pull a 4-stack and a 2-stack and cap both. Still, I consider this is a big step up from our 2x2 mining from GSDE. We're now right at 119.8-120.0lbs, which makes it quite difficult to add any more functionality to the totem! All we can do now is practice and refine code. Speaking of code and practice, a big thank you to 1519 for helping us with, and inspiring us to implement, an IR sensor array that has been key in making our robot more effective at RC mining. We spent much of our time at Hartford refining the control code for this and practicing using it. Here is a picture of the array installed on our lower-most totem bar. These four sensors allow the robot to automatically square itself to, and center upon, two totes end-on. It has worked well in tele-op, but not as well in auto, yet. ![]() We moved the air cylinders for our 'antennae' to be base of the arm and connect them via fiberglass push-pull rods to the antennae. This moved enough mass down off of the arm to dramatically improve arm performance with the antennae mounted. We also added a small plastic 'wheelie bar' on the front of the robot that lets us pull wheelies routinely when lifting RCs. Antennae cylinder mounted on the arm shoulder: ![]() Overview shot of the push-rod actuated antennae. The fiberglass push-pull rod is red, the carbon fiber antennae is black. ![]() The geometry for these work, and we've tested it in teleop. We just need a slightly more robust auto code to align properly to grab two RCs in auto. Currently we're brainstorming ways to make this happen. |
