Thread Tools |
Rating:
Display Modes |
Re: Eliminations replay card
That can lead to further problems, though, because even if it was only allowed to be used in case of a communication issue, it would be difficult to differentiate between a legitimate problem and a team pressing the "reboot roboRIO" button to allow a replay after they knocked over a stack.
That's the purpose of best 2 out of 3.
If you want one and done, then a replay might be ok. But, it is likely the loosing team will be requesting the replay for whatever reason. So, you end up back at best 2 out of 3 with no replay (A looses and requests a replay, B looses the 2nd game, so requests a replay, now you are down to the 3rd match - winner take all). |
Mulligans are good for teams with a high variance, and penalizes teams with low variance. |
What if a team is having a bad match so they decide to pull the Ethernet cord mid match causing them to "loose communications" should they get a replay for that. No.
Of course they don't deserve a replay for that. Such a scenario seems to be against the spirit of F.I.R.S.T. I'm pretty sure the FMS can detect which stations are plugged in and which aren't.
#7
It can detect if the DS is unplugged, but it cannot detect why it was unplugged.
#8
For this year's game, you could implement a similar "best 2 out of 3" in semi's by only taking the average of the alliances two highest scores (drop the lowest). This would allow for a single bad match without replays. It really comes down to what the GDC was trying to do with this scoring format. If reliability and consistency was important, then the current method works fine.
Mike |
#9
It would prevent the stupid failures, like 303 losing communication during their last semifinal at Tech Valley, and not making it to finals by one average point. It would also allow alliances to show their best stuff and have it count. Never before has an alliance put up the regional high score in their last semifinal match, then not moved on to finals, like the 1126 Alliance at the Finger Lakes Regional. That being said, a change like this would change the strategy of how the game is played. Right now depending on where your average score lies, you might choose to play a high risk or a low risk game. That would dissappear and make the preferred strategy in semis a high risk game. Other thoughts? |
#10
987 2826 4265 2512 277.0 avg 118 1678 1671 5012 242.5 avg 148 1114 1923 900 241.0 avg 1023 2338 3996 1089 226.0 avg Same result with a 1.5 point differential instead of a 1.7. The lesson here is that you have no idea of the effect on your team as a result of others replays. Your bad match because of a loose fuse may be balanced with someone elses bad match because an RC was stuck on their can grabber. |
#11
I heartily support the use of a replay card. When I was a student in 2014 there was a call that I think after review might have overturned a tech foul which would have won us a second SF match. Whether or not the refs made the right call I'm not going to argue because in the end its there call. But if we had a replay card there would have been some more clarification on the call so we understood the call better.
#12
I think this concept of a "redo card" for robot problems or operator error is a very bad idea. That's what this program is all about, design and build it well, robust, and consistent. It wouldn't be fair to the other teams who did their job.
As others have mentioned: Quote:
We wouldn't have had the 2013 World Champions is this were the case, among many others. |
#14
I see, I misinterpreted the redo card. You are right, my bad. In that case, I would've liked to see a crossover of the elimination format with the average system - basically, drop the lowest score out of three matches and average the rest.
