Go to Post Yes, in human nature we like to get rewarded/recognized for things we do; however, you should not have to rely on this to be "successful". Remember the purpose of FIRST - To change our culture. - tim-tim [more]
Unread 30-03-2015, 09:57
DonavanAnnalise DonavanAnnalise is offline
FRC #4284
DonavanAnnalise is an unknown quantity at this point
Only One side of the "mock elevator" is working
When we have one of the two mock sides commented out they work but when placed together they don't work only one dose
**This is on a prototype for testing code**
Jaguar E1 = new Jaguar(5);
Jaguar E2 = new Jaguar(4);
float Elivate = 1f;
float Elivate2 = 1f;
if(totestick.getRawButton(4)){
E1.set(-Elivate);
E2.set(Elivate2);
Relay1.set(Relay.Value.kForward);
Relay2.set(Relay.Value.kReverse);
}else if (totestick.getRawButton(1)){
// turns the elevator to Reverse
E1.set(Elivate);
E2.set(-Elivate2);
Relay1.set(Relay.Value.kOff);
Relay2.set(Relay.Value.kOn);
} else {
E1.set(0.0);
E2.set(0.0);
// else it is off
Unread 30-03-2015, 10:20
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Only One side of the "mock elevator" is working
I'm trying to figure out what you're doing here.
Do you have two separate sides of the elevator which run in opposite directions to lift, controlled by jaguars? If so, it would probably make more sense to have the Elevator2 "constant" equal -1, then when you set the speeds, the code inside the loop is either both positive or both negative.
Also, what is the function of the relays in your setup? Should you set them to some value when stopped?
Finally, just to verify that you are only declaring/assigning objects to E1 and E2 once in initialization, not once per loop? Re-declaring controller and sensor objects repeatedly can cause them to work inconsistently as they cycle through shutdown and startup. Re-declaring the floats would be a waste of CPU cycles, but is less likely to be noticeable in terms of performance.
Oh, also to verify -- java, right?
Unread 30-03-2015, 10:58
AnnaliseDonavan AnnaliseDonavan is offline
FRC #4284
AnnaliseDonavan is an unknown quantity at this point
The beginning part is set up during iterative robot then the if and else if loop is set up during the teleop Periodic the relays are for lights I just forgot to remove that part of the code
Unread 30-03-2015, 11:38
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is online now
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
Have you checked the motor/jag connections to make sure they are the same polarity?
If so, and it jams while lifting, remove the negation from the second elevator jag.
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
