Go to Post Take what you have learned, build on it and share it. Others will do the same. Enjoy the journey. - Bertman [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 30-03-2015, 13:30
WillNess's Avatar
WillNess WillNess is offline
Programmer
AKA: Will Ness
FRC #4944 (The Hi Fives)
WillNess is just really niceWillNess is just really niceWillNess is just really niceWillNess is just really nice
Re: PID & One Second Delay Between Auto and TeleOp
Originally Posted by MrRoboSteve View Post
I think this is closer to what you want. The logic is simpler if you move the timer check into disabledPeriodic(). The result of timer.getFPGATimestamp() is probably not what you want.
bool teleopAfterAutonomous = false;
autonomousInit() {
  teleopAfterAutonomous = true;
disabledInit(){
  disabledTimer.Reset();
  disabledTimer.Start();
disabledPeriodic(){
  if (disabledTimer.Get() > 1) {
    // If we're disabled for more than one second, assume that we are not in a match
    // Might be necessary to bump 1 above to a somewhat higher value.
teleopInit(){
   if(teleopAfterAutonomous || DriverStation.getInstance().isFMSAttached()){
      shoulder.set(shoulderDocked);
      elbow.set(elbowDocked);
Except during teleopInit() I think I'd have to set the teleopAfterAutonomous = false. Because if I do the practice mode and then I start teleop the teleopAfterAutonomous would be true and then would go to the docked positions so it would look like this: (Correct me if I'm wrong)
teleopInit(){
Outreach Lead // Lead Programmer // Junior
2014 FRC:
Rookie Allstar, Highest Rookie Seed & Semifinalist @ Utah
Rookie Allstar, Highest Rookie Seed & Semifinalist @ Colorado
2015 FRC:
Creativity In Engineering & Semifinalist @ Arizona West
Unread 30-03-2015, 16:22
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
teleopInit(){
Only if there's somewhere later in the code (e.g. in teleopPeriodic()) that uses teleopAfterAutonomous. As for what I see here, the variable is not going to be referenced again. That also means that it won't hurt anything...
Unread 30-03-2015, 17:00
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
WillNess, I think your change is a good one.
In my code, I assumed that you'd have at least a second of disabled between your practice runs. That delay causes teleopAfterAutonomous to become false. Your change resets things immediately.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 30-03-2015, 21:07
WillNess's Avatar
Programmer
AKA: Will Ness
Yes I don't think I'll ever be starting the robot within 1 second of code uploading or rebooting.
2014 FRC:
2015 FRC:
