Go to Post Yes, machining a dog profile into a steel sprocket on a manual mill was an experience filled with pain and regret. - Joe G. [more]
Unread 25-03-2015, 11:04
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Demonstration Robot Alternative to Spike Relay
We use a fair amount of Spikes in our builds, and we robbed our '13 and '14 robots for this year's build. We want to keep both of those bots for demonstrations, and they both have 4-slot CRios (so they make nice programming development platforms) but I'm having trouble justifying buying new spikes when I imagine there is another relay available that is much cheaper and would work just as well. 2013, for example, has three motors in the shooter that all have individual Spikes...for a bot that never has to pass another FRC inspection, is there a cheaper option?
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 25-03-2015, 11:10
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Demonstration Robot Alternative to Spike Relay
I've picked up relays at a local surplus store for various projects before. You can get them really cheap that way, but you have to stand in the isle a bit trying to google on your phone whatever model number you can find on the casing so you know it can handle the loads you'll pass through it. For the most part they probably wouldn't work as a direct, 1-1 replacement for a spike, but with some creative wiring you can get it to work without having to rework any code!
2016: Lake Superior WFFA
Unread 25-03-2015, 13:10
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Define "work just as well". If you're looking for something with the same current rating, 5V inputs, and you don't want to bodge 3-4 individual SPDT relays into something like an H-bridge, then I don't think there's actually anything available that's cheaper than the Spike. There's some multi-channel relay boards, but you'd have to rig up 4 of the channels on there to turn it into a Spike equivalent.
Unread 25-03-2015, 13:45
MamaSpoldi's Avatar
MamaSpoldi MamaSpoldi is offline
Programming Mentor
AKA: Laura Spoldi
FRC #0230 (Gaelhawks)
MamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant future
If you have spare ports on the pneumatic module they can be programmed in place of a spike. We did this on our bot last year to power/control our LEDs.
Unread 25-03-2015, 14:17
Qbot2640's Avatar
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Good point - For me I'd like it to operate without a code change...but I wouldn't mind possibly some wiring tweaks. 2013 we could run without pneumatics, because that was just used for the hang...and we won't demonstrate that, but the three motors on individual spikes would be nice to replace with a single, higher capacity relay. 2014 had only our pneumatics on spikes. We never bothered with the pneumatics breakout board...maybe now is the time (even though it's obsolete). I guess we're going to have to re-program anyway so we don't have to maintain old driver stations to run them.
Unread 25-03-2015, 14:44
You could run all 3 motors off one spike? If you're amenable to a small code change, you could probably run them all off a single Victor/Jaguar/Talon. Just grab an outdated speed controller you're not likely to use again and run them all off that. Provided the total current draw is less than 40A, anyways.
Unread 25-03-2015, 15:38
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Something like this http://www.ebay.com/itm/4-Channel-5V-Relay-Module-With-Optocoupler-For-Arduino-DSP-AVR-PIC-ARM-/221658808205?pt=LH_DefaultDomain_0&hash=item339be4 ff8d is good for 10 amps. That's halfway there to the current rating of a spike. There may be larger ones out there.
Brian K
Team 1225 Robotics Mentor
Unread 31-03-2015, 14:04
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
This should NOT be able to handle the current draw of motors. LEDs, relays, and solenoids, sure, but not motors.
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
