Go to Post This wins this week's award for "Most Bizarre Thread". Carry on. - DonRotolo [more]
Unread 12-03-2003, 00:00
Alex1072 Alex1072 is offline
AKA: Alex
#1072 (Harker Robotics Team)
Alex1072 is an unknown quantity at this point
Send a message via AIM to Alex1072 Send a message via Yahoo to Alex1072
Robot output torque
How much torque are robots outputing on average. We're getting 288 in-lb for both wheels. Which are 6 inch diameter. That makes about 96 lb linear force.
Unread 12-03-2003, 00:19
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
A better way to ask people is:
What's your gear ratio, wheel size, and speed?
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
Unread 12-03-2003, 00:21
AKA: Alex
Just to add to that, what drive motors are you using?
Unread 12-03-2003, 00:27
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
drills (in high) and chips reduced 2:1 using 4" wheels/pulleys.
Total linear force: 180 lbfs per side @ 13fps (assuming 100% eff).
Unread 12-03-2003, 01:07
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We have the Drills and Chippys (1 drill and one Chippy per side). The Chippys are geared 3.5:1 to match the high speed output of the drill, 1650 or so. That number is geared down 4.8:1. We are using 8.5 inch wheels. I forget all the numbers but we go about 9 fps in reality.
Unread 12-03-2003, 07:55
Matt Reiland's Avatar
'The' drive behind the drive
We are using the Drills (Just the motor) Geared Down about 4:1 to match the Chips then down to 50:16 and out of the main gearbox in High OR a further 4:1 in low. Then it is a 3:1 reduction to the driveshafts through sprockets (I told myslef no more chain and sprockets you would think I would listen) (Our main problem at Buckeye was HERE it will be fixed for GreatLakes to keep from throwing the chains on high speed impacts) and the Drive Pulleys are about 6" in Diameter.
For a tank it cooks in high about 9 ft/sec and little over 2 in low.
Unread 12-03-2003, 09:05
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Chips at 9.8:1 main reduction, with a 2:1 low gear, 1:2 high gear, and a final 3:1 sprocket reduction. That gives us:
58.8:1 Low Gear
14.7:1 High Gear
We're using 6" custom machined wheels, giving final theoretical speeds of 9 ft/sec in high, and a little under 2 ft/sec in low. It's essentially our same drivetrain from last year, which was one of the fastest and most powerful drivetrains around. We weren't the absolute best, but we were up there in the speed and power categories.
Jeff Waegelin
Unread 12-03-2003, 10:27
Onizuka's Avatar
Onizuka Onizuka is offline
Onizuka is an unknown quantity at this point
Using the drills in low with a main reduction of 42.67:1(through the gearbox) then a further reduction of 1.5:1 through chain. We are using ~8inch skyway wheels for a max speed of ~9-10fps.
otoko wa doko desu ka...
Unread 12-03-2003, 12:34
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Were using the Chips with a 10:1 sprocket reduction, at 40 amps
We're using 8" custom skid-steer pneumatic tires.
We had NO problem pushing around drill-drive bots.
We're around 8-9 fps
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 12-03-2003, 22:13
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
I will second that!!
We were fortunate enough to get the Tech Crew in our alliance in Cleveland. They have some of the best combination of speed and power that I have seen.
Matt B
Coach
Team 902
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
Friction, traction, torque - oh my... Gui Cavalcanti Technical Discussion 30 13-08-2002 18:01
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
Index of team's post about their robot... Ken Leung Robot Showcase 1 20-03-2002 17:10
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
