Go to Post It is great to be proud of the way you do things, but to imply that everyone should match your way of thinking, is ludicrous. - JVN [more]
Unread 31-03-2015, 23:00
orangemoore orangemoore is online now
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: Is this an FRC record?
Originally Posted by Thunderstorm View Post
We measured our robot DERP today and ended up with a 31' 9" total wingspan.
The field is only 54 feet wide so there is truly a maximum but for practical purposes you guys probably have reached the longest length.
Also it looks to be a very cool robot.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 31-03-2015, 23:11
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
FRC #4607 (C.I.S.)
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
Regardless of record - that is one heck of a robot! definitely one of my favorite robots this season!
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 31-03-2015, 23:16
Thunderstorm Thunderstorm is offline
FRC #1750
Thunderstorm will become famous soon enough
Originally Posted by CalTran View Post
That's pretty incredible. I like the casual reach-over-to-the-step-grab-container that you had going there. Are STEP containers the only containers that you can use, or if someone were to bring you another, could you direct the arm to grab it? Also, really clever to move the robot rather than the stack.
Yes, the end of our crane is actually a suction cup, we can grab containers on their side using that, however, we found that for upright containers it was easier to stick the whole suction cup inside the hole and pull it from there
Unread 01-04-2015, 00:42
The other Gabe's Avatar
The other Gabe The other Gabe is offline
Too many events, not enough time
AKA: I'm a volunteer now!
no team (2046 Bear Metal Alumn)
The other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud of
your robot is cool, and I have a question or two
why not set it up in the 60 seconds before the match instead of doing the things in auto? were you having trouble getting it down to just a minute? (it would let you canburgle in auto)
also how on earth did you get that under 120 lbs?
Do the best you can with what you are given
FRC 2046 2012-2015
Field Scout lead 2014-2015
Unread 01-04-2015, 00:47
AKA: Roger Moore
You cannot start in the auto zone, which they would be sitting in if they did expand before the start of the match.
Stronghold
Student 2013-2016
Unread 01-04-2015, 01:06
Originally Posted by ratdude747 View Post
I know in 2003 T3 (68) had a field-wide bot (unfolding blockade) that was ruled illegal... IIRC that was the record pre-2015 (if you want to count it, IIRC it didn't see competetion?)
It did, but not in that configuration. There were certain aspects of that robot that were very, very into a gray area that didn't really exist; some retooling would have probably made it legal in the field blockade configuration. The robot was retooled a bit into a non-blocking configuration.
I can't think of any other massive-expansion robots; you have to look prior to 2006 for them. Now, height of the robot is another story...
Unread 01-04-2015, 01:13
AdamHeard's Avatar
Lead Mentor
Originally Posted by Joe Ross View Post
While their wingspan isn't quite as large, 365 in 2002 reached across most of the width of the field and had a tether to cover the length. I don't remember if 71 had a tether that year.
http://www.chiefdelphi.com/media/photos/13784
http://www.chiefdelphi.com/media/photos/13623
71 had a tether
Unread 01-04-2015, 09:49
samfruth's Avatar
samfruth samfruth is offline
FRC #1710 (Ravonics Revolution)
Team Role: Driver
samfruth will become famous soon enough
1710 was around 8.5ft tall last year and that height was static. Haven't seen another bot yet that has matched it.
I kind of know programming
Unread 01-04-2015, 12:04
FRC #1750
Well, for starters, you'd be surprised what you have weight for when you get rid of a drive train and use no CIM motors. We could have reduced weight on the stacker but we wanted as much as we could afford in the stacker to counterbalance the crane. We also found that mangling a couple wal-mart ladders could give some decent structure on the conveyor for very low weight and the structure of the crane is almost entirely thin aluminum bent and riveted into rectangular tubes. There was alot of other stuff we wanted to add to our robot but did not have the weight for. We had a plan in the works to get the other 2 containers off the step using suction cup shooting crossbows.
Unread 01-04-2015, 12:08
Mastonevich's Avatar
Mastonevich Mastonevich is offline
Andrew
AKA: Andrew Elsen
FRC #1987 (BroncoBots)
Mastonevich is a jewel in the roughMastonevich is a jewel in the roughMastonevich is a jewel in the rough
This - Nicely done, but now I have a question. How does the robot move after creating the stack if you don't have a drivetrain?
~Andrew
Regional Chairman's: 2013-Alamo, 2010-Oklahoma, 2009-Colorado
Engineering Inspiration: 2016-Hub City, 2012-St. Louis, 2008-Minnesota
Regional Wins: 2010-Oklahoma
Unread 01-04-2015, 12:11
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
Academic Student (Forever)
Unread 01-04-2015, 12:12
CalTran's Avatar
MST Rolla Senior
Probably passive wheels/bearings and the same stack-pushing concept y'all had.
Unread 01-04-2015, 12:16
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Just so much Wow there, great design and execution to have a complex machine make weight and function.
The sooner we get behind schedule, the more time we have to catch up.
Unread 01-04-2015, 12:59
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Maybe build the first stack against the wall and then push against the stack to move yourself down?
Unread 01-04-2015, 16:35
Citrus Dad's Avatar
Citrus Dad Citrus Dad is offline
Business and Scouting Mentor
AKA: Richard McCann
FRC #1678 (Citrus Circuits)
Citrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond repute
I was just wondering if any of you know of an FRC robot that is larger than our robot this year. Since our 2015 season is done, we want to make some memorial plates commemorating our achievement and want to make sure it is a legitimate record. We measured our robot DERP today and ended up with a 31' 9" total wingspan. Here is a video of it competing at the Oklahoma Regional last weekend for those who havent seen it
#teamconveyor
#teamcrane
A creative response to the challenge. However, it's a bit like watching grass grow for excitement...
