Go to Post The first law of programming is that there are always ways of doing things quicker and in less space than you already are. - jgannon [more]
Unread 01-04-2015, 04:16
Jefferson Jefferson is offline
AKA: Jeff Clements
FRC #0016 (Bomb Squad)
Jefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant future
Re: I2C Rangefinders not working
Originally Posted by 2538Programming View Post
We are using maxbotics mb1212 I2C rangefinders and we have tested our rangefinders on an arduino but for some reason, the same approach to reading off the sensors seems to fail. I think our issue may be that it can't find the sensors, which it should totally be able to do, or that it has trouble accessing the command on the sensors. The documentation for the rangefinders is right here http://www.maxbotix.com/documents/I2..._Datasheet.pdf
,as well our Rangefinder code:
Any help we can get is much appreciated, thanks
Do you have pull down resistors on the data and clock wires? I believe the arduinos have them built into the board while the roborio needs them added to the bus.
We are using a similar sensor. I'd be happy to send you our C++ library for it.
Also, be careful if you are usng more than one. They can interfere with each other if the readings are sequenced properly.
