Go to Post Think about the other teams...today your opponent, today your teammate. - Al Skierkiewicz [more]
Unread 31-03-2015, 21:26
Professional Stat Padder
Re: alliances selection
The difference between a stack of six and a stack of five is only 6 points, and if the stack of six contains no litter, there is no difference in point value at all.
3 stacks of 5 with 2 containers and litter: 36*2+5*2=82
2 stacks of 6 with container and litter: 42*2=84
Only a 2 point difference between the 2 strategies executed perfectly.
Now,
3 stacks of 5 with 2 containers and litter at 97%: 82*.97= 79.5
2 stacks of 6 with containers and litter at 75%: 84*.75= 63
Therefore the more consistent stacks of 5 are generally the better option.
However, the number of containers your alliance is able to utilize can also factor in to what height you should be building stacks at. If your alliance only has the three containers available to use, stacks of 6 better utilize your containers than stacks of 5. But not much better in the long run if the 6 stacks is less consistent.
(2015-Present)
Unread 01-04-2015, 07:03
ATannahill ATannahill is offline
AKA: Alex Tannahill
Originally Posted by jlmcmchl View Post
I would expect so too, but we won't know until we see them again. Absolutely, I've seen cans decide matches. At the finals in livonia, the finalist alliance was effectively barred from scoring enough points when 548 beat them to the middle cans. This and next saturday are going to be great to watch for exactly these sort of matches.
That is not quite right. Team 503 (finalist) wanted to starve the winning alliance of containers, they were not necessarily interested in using them themselves. They realized that if they could get the four containers off the step (including winning the race in autonomous) than they limit the amount of points the winning alliance could get. The other two containers on the step were left untouched after 503 lost the autonomous race.
Unread 01-04-2015, 08:53
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
How is this any different then stopping them from scoring points? By 548 taking them, it pretty much put a seal on winning based off of what the number 1 alliances average score was. And I wouldn't say that they weren't interested, they still would of had to match the 1 alliance with stacks and then place up a 4th stack because they were behind from HOT's auto. Neither her nor there, the cans decided the outcome of that match.
-Ronnie
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 01-04-2015, 14:20
Bryce Paputa's Avatar
Happy Birthday! Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
Finals match one we fought for the cans with the intention of keeping the first alliance to three capped attacks (one five and two sixes most likely) while we would be able to put up two capped sixes from 3641, a five from us, a four using DHDC'S totes and our container, and possibly another short one if we got lucky with time. We lost the race and therefore could only get two sixes and a five. Finals match two we kept the same plan and lost again, but the other alliance was only able to get three stacks up. Of course we had no idea they would "mess up" so we raced. Had we known that they would only get three, we should've taken the two uncontested containers and then we would likely have gotten another cap and won the match. We were definitely planning on using four containers with five being a stretch goal.
Also, our mechanism was very hard to line up and we hadn't yet practiced lining it up with operator controls instead of by hand.
Last edited by Bryce Paputa : 01-04-2015 at 14:23. Reason: why we didn't go for the other ones in teleop
Unread 01-04-2015, 14:28
Gweiss96's Avatar
Gweiss96 Gweiss96 is offline
AKA: Garrett Weiss
FRC #3309 (Friarbots)
Team Role: Operator
Gweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to behold
Three stacks of 5 with 2 RCs is better. It is only 2 points less than 2 stacks of 6 with 2 RCs.
Nice try guy!
Unread 01-04-2015, 16:25
Citrus Dad's Avatar
Citrus Dad Citrus Dad is offline
Business and Scouting Mentor
AKA: Richard McCann
FRC #1678 (Citrus Circuits)
Citrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond repute
Originally Posted by Spartan710 View Post
I was wondering what teams would rather choose a team that puts up two six stacks and bin 75% of the time or a team the puts up three stacks of five with two bins third if it is available 97% of the time. The reason I am asking this is we are thinking about changing our robot and wondering if it is worth losing our consistency . Thanks for the help.
Consistency is generally more important. Plus your third uncapped stack might be capped by an alliance partner. Dropping one of your 6 stacks is a risk that is unattractive. We made the early decision to focus on 5-stacks for strategic reasons for which you can work out the math.
