Go to Post By the way why do all american's spell Colour wrong?!?!?!?!?!?!?!? - akoscielski3 [more]
Unread 01-04-2015, 07:59
Woodie Flowers Award
JDNovak JDNovak is offline
AKA: John Novak
FRC #0016 (Bomb Squad)
JDNovak has a reputation beyond reputeJDNovak has a reputation beyond reputeJDNovak has a reputation beyond reputeJDNovak has a reputation beyond reputeJDNovak has a reputation beyond reputeJDNovak has a reputation beyond reputeJDNovak has a reputation beyond reputeJDNovak has a reputation beyond reputeJDNovak has a reputation beyond reputeJDNovak has a reputation beyond reputeJDNovak has a reputation beyond repute
Re: I2C Rangefinders not working
For the RoboRio, the I2C library changed to 7 bit addressing so the range is 1 to 128 instead of 2 to 254. The default address is 112 to the RoboRio.
The Arduino library uses 8 bit addressing.
I don't think this is officially documented anywhere.
For example I used the Arduino example code to set the address to 4 and then accessed the sensor on address 2 from the RoboRio.
The clock and data do need external 120 ohm pullups also.
