| My motors are hot for you! |
basic stamp editor debug capture
The debug terminal window has a button on the bottom labelled 'capture'. The preferences 'debug port' tab has a 'capture directory' input box. Neither of these seem to be active - you can't enter a directory, and the capture button is greyed out.
Are these unimplimented functions, or is there some extra step needed to enable the debug capture function? If it's unimplimented, how can one capture a stream of debug output data? (I also tried Hyperterminal text capture, but that didn't work either) Thanks! |
What part of hyperterminal's capture didn't work? Did it not display the data, or did it just not capture it after it was displayed?
Re: basic stamp editor debug capture
Re: Re: basic stamp editor debug capture
A quick note on HyperTerminal: it probably won't work. HyperTerminal (and most other terminal emulation programs) set the DTR line as soon as you open the port. Unfortunately, this is how you signal the Basic Stamp that you are about to program it, so it will probably get rather confused.
I don't remember any options in HyperTerminal that let you disable this feature, but it may be there somewhere. Otherwise, you'll have to write your own program to do it. It's not overly complex, and I can help get you started if you're interested. I'd offer to write it myself, but RoboEmu 2.0 is already sucking the life out of me. ![]() --Rob |
I found a convenient serial VFD display that is quite handy for displaying info.
| Impending BASIC Stamp Editor Beta 2 release | Greg Ross | Programming | 9 | 19-09-2003 06:05 |
| Auxilliary Basic Stamp Chip | Kai Zhao | Technical Discussion | 9 | 07-01-2003 21:21 |
| no basic stamp found! | DLyons | Programming | 7 | 23-12-2002 22:17 |
| Is anyone using the BASIC Stamp Preprocessor? | Greg Ross | Programming | 4 | 12-02-2002 12:24 |
| Question about Basic Stamp | miketwalker | Programming | 3 | 14-01-2002 13:10 |
