Go to Post Remember this: A true leader needs no title to make a difference. - Molten [more]
Thread Tools Rating: Thread Rating: 2 votes, 4.00 average. Display Modes
Unread 16-01-2002, 13:44
tareyton
Posts: n/a
Talking O rings to lock drill in High
Does anyone know the exact size O ring needed to do this?
Unread 16-01-2002, 14:34
Matt Reiland's Avatar
'The' drive behind the drive
We always used a aluminum ring
I tried to find the O-rings but couldn't et the right ones, we ended up just making a slice of aluminum bent around the inside of the housing to lock it into gear, I can get the dimension in a few minutes when I take it apart.
Matt
Unread 16-01-2002, 17:46
Joseph F Joseph F is offline
#0506 (Steel Friars)
Joseph F is an unknown quantity at this point
Send a message via AIM to Joseph F
Talking zip ties. :)
drill a hole in the nearest piece of metal and run a zip tie from the little piece of metal used to switch gears to the hole. Then just pull tight. Its the one part of our drive that did work last year.
One Team, One Bot, One Fleet of Ambulances!
Unread 16-01-2002, 18:01
joe_balint joe_balint is offline
FRC #3324 (Metrobots)
joe_balint is an unknown quantity at this point
If I recall correctly, you can cut a slice of 1-1/2" PVC pipe and that will work. I can't remember the exact size because we just fiddled with it and a sander until it fit. That was a couple of years ago. -Joe
Engineer
joe.balint@gmail.com
http://www.OhioValleyTesting.com/
"The greatest enemy of a good plan is the dream of a perfect plan." -Clausewitz 1832
Unread 16-01-2002, 19:53
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
For high gear, just turn ring around...
There are only external teeth on the output shaft side of the ring that is used to shift from high to low. The motor side is smooth.
If you take the ring out and put it in smooth side toward the output shaft, the transmission cannot shift into low gear.
This is the easiest way to look the drill transmissions into high gear.
As to the right O-ring to buy from Small Parts to lock the ring in low gear, I THOUGHT that Chris Mikus had it posted on his Nuts4First.net site but I could not find it (actually, I may have the URL wrong, because I could not even find the site!).
If anybody finds Chris' site, let us know what the part number is.
Joe J.
Unread 17-01-2002, 09:53
President, VEX Robotics, Inc.
Use Aluminum Ring
To keep the drill motor in low use this:
1 1/4" aluminum pipe (that should be 1 1/4" inside diameter)
Turn the Outside diameter down to ~ 1.44"(36.6 mm)
Thickness should be ~ 0.173"(4.4 mm)
We have used this the last 2 years and it works.
-Paul
Unread 26-01-2002, 14:13
Nuts4FIRST Nuts4FIRST is offline
no team ("Independent FIRST Advocate")
Nuts4FIRST is an unknown quantity at this point
Answer from Chris Mikus
I'm not exactly sure which size O ring is needed to lock the gearbox in high gear. At the time I made the discovery I had a handful of rings and used what ever fit.
Here is what I think I used, Small Parts number: U-ORB-218 (1-1/4" ID x 1-1/2" OD x 1/8") use two of these stacked on top of one another.
I've recently found that metric sizes fit better (purchased at a local store) but Small Parts doesn't stock those, so they are against the rules.
Chris Mikus
robotics trivia kewlkid382 Chit-Chat 63 16-03-2004 09:50
What does the Chairman’s Award have to do with a robot contest? Ed Sparks Chairman's Award 32 15-02-2004 13:39
St. Louis anyone? Jeremy_Mc Regional Competitions 8 07-02-2003 12:06
KSC Results archiver 2000 2 23-06-2002 22:19
KSC awards archiver 1999 4 23-06-2002 21:59
