Go to Post But that deals with quantum phys-- ooh, shiny objects. - Otaku [more]
Thread Tools Rating: Thread Rating: 9 votes, 4.89 average. Display Modes
Unread 03-03-2015, 12:24
VEX_6333's Avatar
VEX_6333 VEX_6333 is offline
Captain, VEX Team 6333 CTRL_ALT_DEL
AKA: Thane McGarry
VRC #6333 (CTRL_ALT_DEL)
VEX_6333 is an unknown quantity at this point
Re: Remote command failed with exit status 1
So, you're saying that if we fix the package error, we'll be able to push code again?
Unread 03-03-2015, 12:36
Do you have a package error? You haven't provided any information that would lead to that conclusion, he just posted one example. Because there are many things that could cause this message, including many in which there isn't any problem, you need to post the entire build log as well as the riolog for anyone to give you any advice.
Unread 03-03-2015, 13:00
VEX_6333's Avatar
AKA: Thane McGarry
Okay, here is the build log:
Buildfile: C:\Users\DOC\workspace\DriveTrain\build.xml
Trying to override old definition of task classloader
clean:
[delete] Deleting directory C:\Users\DOC\workspace\DriveTrain\build
[delete] Deleting directory C:\Users\DOC\workspace\DriveTrain\dist
compile:
[mkdir] Created dir: C:\Users\DOC\workspace\DriveTrain\build
[echo] [athena-compile] Compiling src with classpath=C:\Users\DOC/wpilib/java/current/lib/WPILib.jar:C:\Users\DOC/wpilib/java/current/lib/NetworkTables.jar to build
[javac] Compiling 1 source file to C:\Users\DOC\workspace\DriveTrain\build
jar:
[echo] [athena-jar] Making jar dist/FRCUserProgram.jar.
[mkdir] Created dir: C:\Users\DOC\workspace\DriveTrain\dist
[mkdir] Created dir: C:\Users\DOC\workspace\DriveTrain\build\jars
[echo] [athena-jar] Copying jars from C:\Users\DOC/wpilib/java/current/lib/WPILib.jar:C:\Users\DOC/wpilib/java/current/lib/NetworkTables.jar to build/jars.
[copy] Copying 2 files to C:\Users\DOC\workspace\DriveTrain\build\jars
[jar] Building jar: C:\Users\DOC\workspace\DriveTrain\dist\FRCUserProg ram.jar
get-target-ip:
[echo] Trying Target: roboRIO-1765.local
[echo] roboRIO found via mDNS
dependencies:
[echo] roboRIO image version validated
[echo] Checking for JRE. If this fails install the JRE using these instructions: https://wpilib.screenstepslive.com/s...ller-java-only
[sshexec] Connecting to roboRIO-1765.local:22
[sshexec] cmd : test -d /usr/local/frc/JRE
deploy:
[echo] [athena-deploy] Copying code over.
[scp] Connecting to roboRIO-1765.local:22
[scp] done.
[sshexec] cmd : killall netconsole-host
[sshexec] killall: netconsole-host: no process killed
[sshexec] Remote command failed with exit status 1
[scp] done.
[scp] done.
[echo] [athena-deploy] Starting program.
[sshexec] cmd : . /etc/profile.d/natinst-path.sh; /usr/local/frc/bin/frcKillRobot.sh -t -r;
[sshexec] start-stop-daemon: warning: killing process 2831: No such process
BUILD SUCCESSFUL
Total time: 34 seconds
Does that help?
Unread 03-03-2015, 13:36
legts legts is offline
Autonomous Queen
FRC #2399 (The Fighting Unicorns)
legts is an unknown quantity at this point
clean:
compile:
jar:
get-target-ip:
dependencies:
deploy:
[scp] done.
[scp] done.
[scp] done.
BUILD SUCCESSFUL
Does that help?
That looks like it should have worked. Can you post what the package you're working out of is? For my team it is "package org.usfirst.frc.team2399.robot;" inside of OI and Robot.java
Unread 03-03-2015, 13:43
VEX_6333's Avatar
AKA: Thane McGarry
It's "org.usfirst.frc.team1765.robot" Does that help?
Unread 03-03-2015, 14:13
Does that help?
Like legts said, this doesn't show a problem, just that no robot code was running. To find out why the robot code isn't running, please post your riolog, which will hopefully have a stack trace.
Unread 03-03-2015, 14:21
VEX_6333's Avatar
AKA: Thane McGarry
I'm going to sound like a naive rookie, (which I kinda am) but how exactly do you do that?
Unread 05-03-2015, 16:43
http://wpilib.screenstepslive.com/s/...console-output
Unread 06-03-2015, 12:36
VEX_6333's Avatar
AKA: Thane McGarry
Exclamation Re: Remote command failed with exit status 1
Thanks Joe. We solved the problem on our own, it was actually a HARDWARE issue. If anyone else is having this problem, we may be able to help because the "Remote command failed with exit status 1" message is not what's making the code not push. If the build is successful, the problem is the roboRIO.
Unread 01-04-2015, 19:44
techplex's Avatar
techplex techplex is offline
Blake B
AKA: Blake
FRC #4909 (The Bionics)
techplex is just really nicetechplex is just really nicetechplex is just really nicetechplex is just really nice
--ONE SOLUTION--
If you are using JAVA make sure that you have installed the JRE as descrbed
Blake
Electrical, Programming and Design
Creator FRC Q&A 2017
Mass FRC Team 4909: The Bionics
Maine FRC Team 5122: The RobOTies (2014-2015)
Maine FRC Team 2648: Infinite Loop (2008-2011)
Unread 30-10-2015, 17:46
Mikey Richards's Avatar
Mikey Richards Mikey Richards is offline
FRC #3812 (Bits and Bots)
Rookie Year: 2015
Mikey Richards is an unknown quantity at this point
We have also had this problem on one of our test bench robots. After our RoboRio failed to run java code, we re-imaged it. Using the same java file that was being successfully sent to the robot earlier, we kept getting the same error with 2 different computers, both of which had eclipse mars and luna installed. How did you guys get the hardware fixed?
Unread 30-10-2015, 17:59
Sounds like you need to install the KRE as described in the post right above yours.
The FRC deployment scripts run something like a dozen remote commands on the roboRIO, this error by itself is fairly useless. If you are sure the JRE is loaded, post the whole deploy log.
Unread 31-10-2015, 13:41
Rookie Year: 2015
OK. We realized we had never installed the roboRio hardware updates, and once we updated that it works just fine.
Unfortunately, our code still won't control the motors, but that is a different problem.
