Go to Post Elevator speeches too - everyone should have one. - Swan217 [more]
Unread 02-04-2015, 14:31
Volunteer, WPILib Contributor
no team (Waiting for 2021)
FMS pre match disabled mode
Before a match starts, does the FMS give teleop disabled signals or auto disabled signals? We have some code running only in auto disabled, and it didn't run in our first practice match.
Team 4488 - Mentor 2013-2016
Unread 02-04-2015, 14:36
Re: FMS pre match disabled mode
Per the FMS whitepaper it goes
Autonomous Disable - state prior to match start
Autonomous Enable - Autonomous period
Autonomous Disable - end of Autonomous period
Teleop Disable - end of Autonomous period, prior to start of Teleop period
Teleop Enable - Teleop period
Teleop Disable - end of Teleop/match end
However, I don't believe any of the FRC frameworks distinguish between Autonomous Disable and Teleop disable
Unread 02-04-2015, 14:51
Thats what I thought. And LV can allow you to distinguish between the 2. We were using them for safety on our can grabber, so it only worked if it switch from auto disabled to auto enabled. But that does not seem to be working, so we are just going to have the code running all the time.
Unread 02-04-2015, 15:05
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
Just out of curiosity, what exactly were you trying to do?
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
Unread 02-04-2015, 15:17
Solve the delay from this thread.
http://www.chiefdelphi.com/forums/sh...&highlight=FMS
Unread 02-04-2015, 15:24
Ivan Helmrich's Avatar
Ivan Helmrich Ivan Helmrich is offline
FRC #1775 (Tigerbytes)
Ivan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to behold
We had a related, possibly same issue at the GKC regional. We use LabVIEW and had coded it to read our autonomous mode from the dashboard when the robot mode was set to Auton Disabled. This worked flawlessly in the shop. At the regional though we just stayed in the default auton mode (do nothing). I asked the same question you just did and I was told that the robot mode is Teleop Disabled before Autonomous. We changed the code to also read the variable when in Teleop Disabled and never had that problem again.
“The knowledge of what is relevant, what is not and the skill to cleverly work around or approximate solutions is the essence of engineering.” - James C. King
Unread 02-04-2015, 19:32
Jared's Avatar
Jared Jared is offline
This isn't right for 2015. The field starts in Teleop Disabled in normal competition and practice matches this year.
If the field has been e-stopped while in autonomous mode and reset, it will begin in autonomous disabled, so be sure to test that your code will still work in this situation.
Is there a way we can get the incorrect documentation corrected?
Unread 02-04-2015, 19:56
There is a report errors form at the bottom.
Unread 02-04-2015, 19:58
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
This is terrible. Any insight into why this is the case?
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 02-04-2015, 20:13
Jared's Avatar
I'm not sure, but it appeared that the field was e-stopped in autonomous mode, the field failed to fully reset itself for the next match. Several of us had to restart our network adapters, or change our team numbers in our driver station back and forth. A robot on the opposite side even had to restart their robot to get communications to start working.
My guess is that the e-stop procedure wasn't fully tested/updated for this year, and still has a few little glitches.
Unread 02-04-2015, 20:34
INTENSITY
Are you sure that whoever was running the field did it right? There's a procedure for when a match needs to be reset, but usually it doesn't happen until after autonomous ends.
Unread 06-04-2015, 16:52
Jared's Avatar
My reported error was deleted from the page, and I have received no response to the email I provided. Do you know of another way to get in touch with the people who maintain that website?
Unread 06-04-2015, 17:01
I believe the reported errors are private. Mine don't show up after I refresh, however they typically get incorporated within a few days. I noticed that it was updated today and removed the differentiation between teleop and autonomous disabled.
Unread 06-04-2015, 17:20
Jared's Avatar
Thanks - somehow I totally missed that the page had been changed when I went to go check.
