#16
Re: Canburglar Safety
I anxious to see if there will be a gentleman's agreement at the highest level in which each team gets two center bins, but that most likely won't happen. Citrus Curcuits, 1114, 2056, 254, 118, and many other elite teams will allow for einstein teams to have 2 canburglar robots and a 3 tote autonomous robot. |
#17
I think the danger is different this year: tip speeds are going to be much faster in general, because can burglars are usually long. From the videos I have analyzed, several canburglars go faster than 18 m/s [~40 miles per hour].
Canburglars also tend to reach out much farther from the robot that launchers did. Last year our ball shooter used 4x 180N [~40lbf] constant force springs, but our motor powered can burglar still concerns me more because it deploys a somewhat sharp metal hook at high speeds about 1.8m [~6 feet] from the robot. |
#18
Show me a robot that has an ultrafast canburglar and is always disabled or unpowered when it isn't on the field. |
#19
What we are making inherently is not safe. If making robots was a safe thing to do then we wouldn't have so many rules. In my opinion if your design is justified then safety in that situation is not only making the design as safe to handle as possible, but it also includes being around it. Securing springs, monitoring air pressure, safety isn't just making things not hurt, its about stopping the situations that get people hurt.
This is from the experience of having a can burglar on our robot that straight up scares me and being in charge of field reset for our teams drive practice. |
#20
Assuming you use one of those constant force springs: the torque would be 332.77 NM (that's metre), or for Americans: 1.2652092 x 10^-13 ounce-lightyears (running joke at my university, "how many ounce lightyears is that?)
#21
I would argue last year's bots were far more dangerous, as they had to launch heavy balls. Our burgulars are motor-powered, so no energy is stored on the bot.
Finding the correct rule to limit this would be tricky. |
#22
I don't know about you, but I'd much rather get hit by a ball than whipped by a fishing pole/hockey stick/piece of PVC. I'm not sure what more can be done than making sure anything that has the potential to move is locked in place as part of the transport configuration, and that the driveteam is ready and willing to E-Stop in auto should something go wrong. Definitely not my favorite part of this game.
#23
Very true. I was mostly referring to safety during a match, where canburglars pose a risk to people standing near the field due to their long reach should they get turned away from the step. In the pits, in the queue, and on the practice field, a dry-firing catapult could easily cause more damage.
#25
How did you come to the number 2? Why not 1, 3, 4, or even none. Do you plan on failing every team with less than 2 safety latches? What if the inspector beside you is requiring 1, or none?
#26
Robot inspectors have lead robot inspectors to turn to when it is not obvious how to decide what is or is not allowed by the rules. A team that does not agree with their robot inspector's decision can also turn to the lead robot inspector. Lead robot inspectors have weekly conference calls. The leader of all the lead robot inspectors reads CD frequently. As does the leader of the FRC. I count several layers of backup. Bring on those energetic burglars. |
#28
(Also, our robot tether isn't allowed in the auto zone pre-match, so the Batman as a Canburglar isn't really a thing.) |
#30
We can't have a canburglar either
There are pros and cons of having a tether.. Ratman is pretty much confined to the feeder area. |
