Go to Post I love pushing buttons!!! - Michelle Celio [more]
Unread 10-03-2003, 09:49
Jim Meyer's Avatar
Jim Meyer Jim Meyer is offline
Engineering Mentor
None #0067 (HOT)
Jim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond repute
Question Anyone know where to buy a spare yaw rate sensor?
We're having trouble finding a source to purchase them. A part number or vehicle this part is used in, would also help.
Thanks in advance!
Unread 11-03-2003, 07:44
Andrew Dahl's Avatar
Andrew Dahl Andrew Dahl is offline
#0497 (Orange Crush)
Andrew Dahl is an unknown quantity at this point
shoot me an email about it with a pic and ill see if we can send you one of ours- we have never used them in the last 4 years and have spares
dahl
team 497
2002 VCU Regional winner of the GM Industrial Design award
whooot!
Unread 11-03-2003, 08:07
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Note: this years gyro is different than past years. The packaging is different as well as the specifications.
Unread 11-03-2003, 08:21
Jim Meyer's Avatar
Engineering Mentor
None #0067 (HOT)
dahl
team 497
Thanks for the offer, but as Dave pointed out this year's are different. Buying these sure seems more difficult than it needs to be.
Maybe we should start a petition for FIRST to sell spare parts kits (basically a regular kit minus the RC, OI and radio modems). It sure would have made things easier this year!
Unread 11-03-2003, 08:24
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
data sheet
The datasheet is available at www.systron.com. There is a whitepaper for FIRST linked from the homepage . The part number and specs are listed on the last page of the PDF.
I didn't see anything about distributors though, maybe you'd have better luck borrowing one from a team that isn't using it.
Unread 11-03-2003, 10:23
Jim Meyer's Avatar
Engineering Mentor
None #0067 (HOT)
The part number (AQRS-00075-FIRST) for the sensor was created especially for FIRST. You can not get this part from just any vendor. The Systron Donner rep told us to contact FIRST about getting this part. We sent an e-mail to FRCParts@usfirst.org as reccommended in this thread on the jive forums. As you might expect we have not heard back from FIRST. We are trying to order a similar part from the supplier (Systron Donner).
I have received a couple of PM's about teams willing to give us theirs. If it turns out that we can't purchase one ourselves, we may just take you up on that offer.
Thanks for all the help!
Unread 12-03-2003, 10:49
Mr.G Mr.G is offline
AKA: Kevin
FRC #0326 (Xtreme Eagles / Romulus High School / General Motors)
Mr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond repute
Send a message via AIM to Mr.G
Did everyone receive there connector in the mail for the sensor.
We can't find ours, and don't remember seeing it.
Unread 12-03-2003, 10:52
None #0116
yep
Apparently the proper connector is no longer available, so they sent a 3x2 crimp connector housing instead. It fits but we had to tape it in place.
Unread 12-03-2003, 13:29
AKA: Kevin
Thanks for the responce. So what you are saying is the they want us to use 3 crimp type connector pins to wire it.
Unread 12-03-2003, 13:39
dhendrix's Avatar
dhendrix dhendrix is offline
#0538 (Dragon Slayers)
dhendrix is an unknown quantity at this point
We soldered our wires on, the taped around it.
Works good, passed inspection.
Unread 12-03-2003, 14:08
None #0116
connector
The connector they sent uses regular 0.1" female snap-in crimps. The 3x2 pin housing fits in the socket but it still wiggles a little. Solder and heat shrink would probably work fine in a pinch.
Unread 30-03-2003, 21:18
Jared Russell's Avatar
Taking a year (mostly) off
We cut away the black plastic sheath, soldered on the leads, then applied epoxy generously.
Zero problems.
Yaw rate sensor pin-out GregT Electrical 8 18-02-2003 00:07
Yaw Rate Sensor to 90 degrees? Bruce C. Programming 4 11-02-2003 00:36
yaw sensor CHSguard72 Electrical 1 06-02-2003 01:44
Yaw rate sensor (gyro for the layperson) Kris Verdeyen Rules/Strategy 4 14-01-2002 00:41
Yaw Rate Sensor ImmacGirl_03 Technical Discussion 2 10-12-2001 15:15
