Go to Post When everyone is exactly even, who do you look up to for ideas and inspiration? - artdutra04 [more]
Unread 02-04-2015, 21:28
stu54 stu54 is offline
None #2458
stu54 is an unknown quantity at this point
coiled tubing
at our last regional some teams used coiled pneumatic tubing. Any idea where we can get legal coiled tubing?
Unread 02-04-2015, 21:32
John Retkowski's Avatar
John Retkowski John Retkowski is offline
Team 316 mentor
AKA: Wyatt. Call me Wyatt.
FRC #0316 (LuNaTeCs)
John Retkowski is a glorious beacon of lightJohn Retkowski is a glorious beacon of lightJohn Retkowski is a glorious beacon of lightJohn Retkowski is a glorious beacon of lightJohn Retkowski is a glorious beacon of light
Re: coiled tubing
Looking for something like this?
http://www.freelin-wade.com/colored-...3368-l-en.html
2015 MAR District Championship #1 seed Winners (w 225 & 203)
2015 Upper Darby District #2 Seed Finalist(w 272 & 5420)
2015 NE Pioneer Valley District #3 Seed Finalists (w 61 & 663)
2014 Lenape Seneca District Champions (w 3929 & 2559)
2014 Springside Chestnut Hill District Champions (w 225 & 1495)
2013 Lenape Seneca District Champions
2013 Springside Chestnut Hill Finalists
Unread 02-04-2015, 21:36
SJaladi's Avatar
SJaladi SJaladi is offline
Mechanical Mentor
AKA: Sarath Jaladi
FRC #1923 (The MidKnight Inventors)
SJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond repute
Re: coiled tubing
McMaster also sells some. We've successfully used this tubing. If you search the site you can find more colors and lengths.
http://www.mcmaster.com/#9148t133/=wl1ao2
Unread 02-04-2015, 21:37
None #2458
Re: coiled tubing
yes I think that's what they used. Do you know if it press fits into the FRC supplied npt fittings? Is this tubing FRC legal?
Unread 02-04-2015, 21:39
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: coiled tubing
Both of the supplied links are 1/4" OD, so they will fit in the fittings.
Both are rated for 150psi, so they are FRC legal.
Unread 02-04-2015, 21:42
SJaladi's Avatar
Mechanical Mentor
AKA: Sarath Jaladi
Re: coiled tubing
One thing you do have to watch out for is if you cut the coiled part of the tubing and attempt to press fit it into the fittings, you have to make sure the cut is clean and flat otherwise it will pop out under pressure. It took us several tries to get it right, but we did get it to work reliably in the end.
Unread 02-04-2015, 21:53
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: coiled tubing
Do not cut the tubing on the coils, it is not designed for this and will not properly seat in the fitting. Purchase the appropriate length instead.
Unread 02-04-2015, 21:57
None #2458
Re: coiled tubing
thanks to everyone for your replies!
Unread 03-04-2015, 02:10
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Re: coiled tubing
There is one more spec to make it FRC legal and that is the ID which must me .160 or smaller. Didn't look at the link but just throwing it out there as I have had to have teams re-plumb their robots because the ID of the tubing they used was too large.
Unread 03-04-2015, 11:13
rfolea's Avatar
rfolea rfolea is offline
AKA: Rick Folea
no team (Forsyth Alliance)
rfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant future
Re: coiled tubing
Another source for coiled tubing:
Ships same day, free shipping if you spend over $49. Usually arrives at your place within two days anywhere in the US. If you are close to GA, one day.
They provided a $30 coupon in your KOP - use that if you haven't already.
Unread 12-04-2015, 23:35
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
Re: coiled tubing
Please make sure your tubing is exactly .160 or less and marked with the data on the outside of the tubing. It is not fun to fail inspecion and need to replace all your tubing at the last minute becuase it is 0.001 oversized.
This is one area where I would avoid any possible issues and double check any pneumatic tubing beforehand to make sure it is fully compliant.
Unread 13-04-2015, 04:56
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: coiled tubing
You must be joking? You actually failed inspection for tubing that was .001 oversized?
R.C.
MadTown Robotics Team 1323
Unread 13-04-2015, 06:16
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Re: coiled tubing
I agree with R.C. Was the tubing labeled with an ID of .161"? I have never seen tubing that size; not saying it doesn't exist, just never came across it.
In the situation you describe, was the ID of the tubing marked on the outside of the tubing? If so, what did it read?
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 13-04-2015, 08:19
Loose Screw's Avatar
Loose Screw Loose Screw is offline
A Loose Screw
AKA: Chris
FTC #5237 (Loose Screws)
Loose Screw is a jewel in the roughLoose Screw is a jewel in the roughLoose Screw is a jewel in the rough
Re: coiled tubing
If you need coiled tubing, please buy it from the sources listed in this thread. I've heated tubing up before (for non-pneumatic use), and it ruins the integrity of the tube. I've also seen teams that created their own coiled tubing that looks very professional, but that's just how it looks. As soon as you apply heat and tension, you compromise the rated pressure of the tube.
Please, just buy coiled tubing that's been rated by the manufactuer rather than saving time and making it yourself.
Unread 13-04-2015, 11:42
Mr V's Avatar
FRC #5588 (Reign)
Re: coiled tubing
No their team did not fail inspection because the tubing was .001 oversized, it was .010 oversized and it was clearly marked on the tubing with the OD, ID and wall thickness. It was only 1/2 of their tubing that failed, the other half had a .125 ID and was marked with the OD and wall thickness. The portion that failed was nylon which was a dead giveaway since Nylon tubing typically has a .035 or .040 wall.
Had it been .001 over then I certainly would have advocated that they were allowed to play as is with the LRI at that event.
