Go to Post This year's rules != last year's rules. - GaryVoshol [more]
Unread 03-04-2015, 11:15
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Adding, removing, then adding a part
Originally Posted by epylko View Post
According to our drive team, the rule is different here at Essex.
We have a ramp that we would potentially not use if 2 other alliance members needed to use the feed stations. The drive team is under the impression based on RI comments that the robot would have to be re-inspected if they unhooked the ramp from the robot and did not place the ramp on the field.
I pointed out rule T.10, section F to our drive team. If they are really concerned about the re-inspection they will get an official ruling. I would think the worst case scenario is get the robot inspected twice, once with the ramp and once without. I can't imagine the robot needs to be inspected every time the ramp is added/removed from the robot.
Or, it could just be their mis-understanding too
-Eric
If this really is a problem at Essex (shouldn't be, but should isn't always would), you could just include a mount for the ramp and tether on the robot that keeps it out of the way (e.g. in the transport configuration) and mount it there when you work the landfill, and place it on the floor when working the chute.
