Go to Post I can tell you for a fact that students don't need smartphones in order to unproductively entertain themselves in a robotics lab. - remulasce [more]
Unread 03-04-2015, 10:25
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
2015 Between-Match Delays
I may wrong, but it seems to me that the delays between matches can be particularly long this year. Before the season started, I anticipated field reset to be particularly difficult with the large number of game pieces and the mess they can create, but most events I've seen have handled this extremely well. However, there still seem to be some extremely long delays while everyone is just waiting for the match to start. Is my perception correct?
And if so...is there a reason for this?
I'm starting to give some thought to the schedule for our fall off-season, and just want to make sure I take everything I can possibly predict into account.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 03-04-2015, 10:28
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: 2015 Between-Match Delays
Transportation configuration is a big part of the delays. Some teams need to dis-assemble parts of their robot before they can remove their robot from the field and some robots in the next batch of teams need to get their robot ready for the start of the match.
Add in the usual field delays of getting robots connected and it gets hard to stick to the match schedule for time.
1058 PVC Pirates 2016 - xxxx
Unread 03-04-2015, 10:42
Jared's Avatar
Jared Jared is offline
I've experienced three or four delays on the field from our team so far, all of which were caused by issues with mDNS.
The laptop will say "FMS Connected, correct station", and our robot will show up as connected with the battery voltage and everything, but the field people cannot see that our laptop is connected. We must disable/enable the network adapter, restart the driver station software, and sometimes even restart the robot.
I've also noticed similar things happening to our alliance partners, where their laptops don't connect to the field, and they have to restart things or try connecting and disconnecting again and again to connect to the field.
The field seems to always connect to the robots in the end, but this year, it seems to take longer on average for all teams to get full communications.
Unread 03-04-2015, 10:46
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Yes, at Bayou we had a number of matches delayed for FMS connect issues, two our team, three or four others. I did not know whether they were robot or driver station end.
Unread 03-04-2015, 10:51
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Matches this year are generally 8 minutes in length (End to End, including the actual match). Most of the delays are due to the set up times required for the whole transportation configuration stuff. Field and connectivity issues are rare, but do occur.
Generally after everyone has been on the field once, schedule a 10 minute break, you'll use the time for sure and after that the schedule tends to stay true. Getting that first match out of the way is difficult, where to go, who does what and various other nonsense.
Other than that build 5 minutes for later in the morning issues and 5 minutes in the early afternoon and you'll be on schedule if you get lucky.
Unread 03-04-2015, 11:32
ayeckley's Avatar
ayeckley ayeckley is offline
AKA: Alex Yeckley
FRC #2252 (Mavericks)
ayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond repute
While this was generally true at Pittsburgh it was not the case at Buckeye. I'd estimate (based on my personal observation) that on Thursday less than 25% of Practice Matches required FTA/FTAA involvement including going out to the Alliance Stations. That rate shot up to over 80% for Qualification Matches on Friday, and back below 25% on Saturday.
Anyone know which field is at Windsor?. I'm tempted to say the field at Buckeye was #11 but there a >50% chance that I'm mistaken.
Unread 03-04-2015, 11:45
Jared Russell's Avatar
Taking a year (mostly) off
mDNS can make establishing the connection to the robot take for-freaking-ever. If anything, the large number of game pieces and long robot setup times help to mask just how long the delay can be.
Unread 03-04-2015, 12:24
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
We ran into a similar issue at Central Valley in Week 2. We were behind schedule quite a bit, so we had teams unplug their driver stations immediately after the match ended and the next match would plug their stations in as quickly as possible. The driver stations for the next match would connect to the FMS, but the next match wouldn't be pre-started yet, so they wouldn't see communications with their robot yet. Most of the time, we had to have teams restart the driver station application. But even then, the delay wasn't huge.
I think the biggest delays come during eliminations, because alliances will face back-to-back situations and this requires a field timeout. Tack on a timeout or two and there's a slightly longer today. Still, most regionals are ending on time or earlier than expected.
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
Unread 03-04-2015, 13:21
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
Once a good rhythm is established the various sources of delay tend to align, i.e. they all mask each other and it appears smooth and painless on the surface.
At a couple of my events we timed the inter-match delay and it was interesting to see how much perception and reality were uncorrelated.
no stranger to the working end of a pencil
Unread 03-04-2015, 13:29
epylko epylko is offline
Mentor!
AKA: Eric Pylko
FRC #3181 (Pittsford Panthers)
Rookie Year: 1970
epylko is an unknown quantity at this point
I'm at Windsor. How do you tell what field is here?
Unread 03-04-2015, 14:26
ayeckley's Avatar
AKA: Alex Yeckley
The road cases should have the number printed on them. I don't recall where they were stored last year; I think in the north-west corner of the gym near the mentor lounge.
Unread 03-04-2015, 19:13
Mentor!
AKA: Eric Pylko
Rookie Year: 1970
I'll check tomorrow. One of the volunteers said that the US kits stay in the US and the Canada kits stay in Canada. Either way, I'll try and verify tomorrow.
Unread 03-04-2015, 19:32
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Usually at Bayou, by the time the score had been settled, the robots cleared and replaced, and the field reset (which usually went pretty briskly considering that there are over 200 game pieces), the match was able to start within another minute or so; Chris Copleand often started announcing matchups before the last team was off the field to help achieve this.
About one match in four or five seemed to have extra delays. Of the ones where I could see or later heard the reason, two were improper robot placement (hanging over the landfill or auto zone) and the rest (about five or six) were connectivity issues (one robot, the rest driver station). I suspect most of the others were connectivity, as well; I could occasionally see one team working hard behind the polycarbonate while the others waited.
Unread 03-04-2015, 19:35
The "mDNS" issues are something that is still being investigated. The better name for it might be "slow DS-robot connection on field", because there are a few glitches here and there that show similar symptoms, but different reasons for the delay/breakage. Also, the necessary DS restarts are caused by a few error conditions that require the TCP comms between FMS and DS to restart. They weren't discovered during beta and show up more often on some laptops than on others.
Good news is that some fixes are being rolled out with field configuration. Others would require new DS or library releases, but there is considerable overhead with a mid-season release. So I guess the summary is that your perception is correct, and it is something that is being worked on more than it may appear.
Greg McKaskle
Unread 03-04-2015, 20:24
Don't rely on the road case number: 11 is the ref case, 19 is spare FMS console, 07 is field supplies IIRC. The small tags might or might not have anything regarding which field.
You want the case COLOR. All the cases in one field match in color--and one or more of them are generally kept right next to the field. Example: Gold field is currently in SVR, after trekking to Inland Empire, CVR, Los Angeles, Sacramento, and Ventura. (Though, I think Gold field is #6, at least it uses radio set #6.)
