Go to Post I think that if you're using semantics to pass inspection you're trying hard to be lazy (Trust me I'm really good at doing it). - Thayer McCollum [more]
Unread 03-04-2015, 15:48
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Open top recyling container?
Originally Posted by cglrcng View Post
I wondered afterwards here on CD how it would play out IF someone actually attempted to use one of those after it was empty, or even w/ 1 litter still left in the container carefully entered over the wall top to a waiting forklift bot, whether the head ref would count it (since there is no actual rule against doing so), since it really isn't supposed to be an official arena pc. in the actual game setup.
I suspect it would be called as a G16 once the robot took possession of it. FIELD elements are never clearly defined, and in this case it isn't a RECYCLE CONTAINER, it's the Litter Bin.
I am surprised that there's no general prohibition against introducing anything other than litter and totes into the FIELD during the match.
