Go to Post You don't need to be on a team to be involved with FIRST. - Koko Ed [more]
Unread 03-04-2015, 16:38
MasterSon MasterSon is offline
MasterSon is an unknown quantity at this point
IP Camera use in robotics
I have a general question for members who are using a axis camera. Are you getting delay free video? meaning if you move your hands infront of the camera, does it appear on your computer screen instantly?
Unread 03-04-2015, 16:42
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: IP Camera use in robotics
There has been a noticeable delay in all of the camera feeds I've seen.
Unread 03-04-2015, 17:01
cjster's Avatar
cjster cjster is offline
Team 1322 electrical
AKA: CJ Mervyn
FRC #1322 (G.R.A.Y.T. Leviathons)
cjster will become famous soon enoughcjster will become famous soon enough
Last year, we had an enormous delay, about 4 seconds.
Team 1322, the G.R.A.Y.T. Leviathons
2015 FiM Kettering Spirit Award winners
2015 FiM Escanaba District Chairman's Award winners
2015 Michigan State Championship
2015 World Championship
2016 FiM Kettering Week 1 Chairman's Award winners
2016 Michigan State Championship
http://www.team1322.org
FEAR OUR BUBBLES!
Unread 03-04-2015, 17:05
dawonn's Avatar
dawonn dawonn is offline
AKA: Dereck
FRC #2586 (Calumet Copperbots)
dawonn is an unknown quantity at this point
We have been connecting directly to the camera in a web browser and using the mjpg stream for the lowest latency for us.
Unread 03-04-2015, 20:08
I generally see a delay of at least 60ms, but it can be more. Four seconds is basically broken.
The delay can come from a number of places, so it is hard to give a single solution to the problem, but it can be fixed.
Things that can affect camera performance/latency:
Lighting -- low light will often cause the camera to extend the exposure, possibly changing camera frame rate from what you asked it to be.
Fast producer/slow consumer -- the camera pumps N frames into the stream and the client consumes M. When N is bigger than M, the latency grows very quickly. When equal, small delays can accumulate latency.
Network buffering -- in any driver, switch, or router. This would show up in the DS log because the traffic follows the same path and is treated the same.
I generally measure this by making a counter display that updates quickly and displays a ms counter. In LV, this is an indicator that displays i inside of a loop that sleeps for 1ms. You then point the camera at the display and display that next to the original. So adjacent to each other on the screen is the true counter display and a camera display of the counter. They are both flickering away. Then take a screenshot and you'll see that the camera display lags the counter by some amount. You can do this a few times if you want to average for a more precise lag measurement.
It has been a few years since I've made accurate measurements, and for this year, I just did the snap test. Snap your fingers or make some other hand transition such as finger-counting at a fixed rate. Modify it until you can estimate the lag.
Greg McKaskle
Unread 03-04-2015, 23:23
I have tested some different ip camera brands and it was suggested to me that axis may have the lowest delay rates. For those who are noticing a delay, are you using an axis ip camera?
Can you tell me the model and the resolution of the camera?
What software do you use to view the camera?
