Go to Post You can't lose if you submit an animation. Even if you don't win an award, your team wins by just doing it. - David Brinza [more]
Unread 04-04-2015, 11:01
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Xbox Controllers
Drop of the DS to robot connection always disables robot. Loss of a controller disables the robot when not connected to FMS. The windows controller driver assumes the analogs are centered when the controller connects to window. So if you have an intermittent controller connection & you reconnect with the joysticks off center, you will get strange results.
