Go to Post Who cares about the score? The score is just numbers on a board, the exciting part is watching the robots interact and seeing robots( and more importantly, people) do the impossible. - Herodotus [more]
Unread 05-04-2015, 09:35
Lij2015's Avatar
Lij2015 Lij2015 is offline
I like turtles
AKA: Elijah Steele
FRC #2363 (Triple Helix)
Lij2015 has a spectacular aura aboutLij2015 has a spectacular aura about
Send a message via MSN to Lij2015
Re: More Finesse as a Driver
I was driver during 2014 like you and was super aggressive and loved to play defense.
I think however what toned me down is our team's robot this year only goes like 5 feet a second in low gear whichiis its default. That kinda forced me to drive with more finesse.
Make one of the triggers on the gamepad reduce the speed by 40 percent when held if you don't have a shifting drive train.
Alumni turned volunteer!
2016 Chesapeake District volunteer, Scorekeeper/Game announcer.
Team 2363 Proud Alumni, Programmer/Driver 2013, 2014, 2015(Captain)
2016 Northern Virginia Winners (1418 and 2421)
2016 Hampton Roads Finalists(1885 and 5954)
2015 Chesapeake Regional Winners(1690 and 4050)
2015 Virginia Regional Winners(384 and 1610)
2014 Chesapeake Regional Winners(1629 and 623)
2013 Virginia Regional Finalists (3015 and 2053)
Unread 05-04-2015, 09:44
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Originally Posted by cjster View Post
Any suggestions on how I can have more finesse as a robot driver?
It's like how you get to Carnegie hall. Practice, practice, practice.
___________________
- Tennyson, Ulysses
Unread 05-04-2015, 10:07
Samwaldo's Avatar
Samwaldo Samwaldo is offline
College Student / Between Teams
Samwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to behold
Last year as driver I drove with two joysticks in a tank drive configuration (hands near the base of the controller) AND then i added a 3D printed pedal that i wired that when pushed the speed would become ~40% of what the controllers said.
Team 1099, The DiscoTechs, 10' - 14'
Driver 11' - 14'................Team Captain 13' - 14'
University of Hartford Class of 2018, Mechanical Engineer
2015 & 2016 NE District Volunteer
Unread 05-04-2015, 10:09
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
There are several things you can do to make it easier to drive. The code can be changed to make the joystick controls exponential (multiply the joystick value times the absolute value of itself). how is the controller set up? steering on one stick, throttle on the other, to make it "split arcade" seems to be more controllable than tank or arcade drive. And you can try an alternate type of controller, such as an RC car control with a small steering wheel and throttle trigger, wired into the guts of a normal USB controller. Also the robot drivetrain design has a lot to do with it, as well as the gear ratios. I've seen a few excellent teams using only one CIM per side on the robot drive this year. Omni wheels are pretty forgiving when turning the robot just a little bit.
We got lucky this year, our driver has fantastic control over the robot...and he sure needed it.
Unread 05-04-2015, 11:18
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
I know it's been said, but above all, try switching to regular joysticks, and grip them at the base. I've driven robots with both styles, though the xox controller robots were at college, not FIRST bots, but as someone who has used both, I'd say traditional joysticks are leaps and bounds more accurate for precision driving. At least give it a try, you may like what you find.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 05-04-2015, 15:29
cjster's Avatar
cjster cjster is offline
Team 1322 electrical
AKA: CJ Mervyn
FRC #1322 (G.R.A.Y.T. Leviathons)
cjster will become famous soon enoughcjster will become famous soon enough
We have mecanum wheels and one motor per wheel, 4 wheels. The throttle and strafing is the same stick and turning the robot is the other stick.
Team 1322, the G.R.A.Y.T. Leviathons
2015 FiM Kettering Spirit Award winners
2015 FiM Escanaba District Chairman's Award winners
2015 Michigan State Championship
2015 World Championship
2016 FiM Kettering Week 1 Chairman's Award winners
2016 Michigan State Championship
http://www.team1322.org
FEAR OUR BUBBLES!
Unread 05-04-2015, 16:14
MrForbes's Avatar
AKA: Jim
842 was having similar troubles. Maybe they will chime in
Unread 05-04-2015, 16:20
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
I would recommend scaling down the default mecanum turn rate in the code. I found that multiplying the rotation value by 0.4 worked for us. Anything more had us accidentally throwing totes. It increases your robot's stability by a lot without reducing your overall mobility. Also, if you don't use field-oriented drive, it will help a lot to simplify driving so you can better focus on being precise.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 05-04-2015, 16:46
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
Are we the same team?
In all seriousness, we had our programmer do exactly this after the Center Line quarterfinals, where turning from the feeder station would fling totes everywhere, and because of this change, during Windsor (our next event), the only times we lost a stack while driving was if the stack was already incredibly unstable.
For reference, for chassis driving we are using Logitech F310 game pads. Our driver found it much easier to drive mecanum than the Attack 3D Pro, because the twist axis would give unintended values when trying to simply drive forward or strafe.
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 05-04-2015, 17:05
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
The two current games I have for fine motor control both are available on steam and don't break the bank too much.
1. Geometry Wars 3D
2. Waves
Things you can do with the xbox controller. Buy or print control freaks/joystick extensions for a controller. It feels weird at first but the longer the thumb stick the more control you have over it.
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
Unread 05-04-2015, 17:09
cjster's Avatar
AKA: CJ Mervyn
1. Geometry Wars 3D
2. Waves
I've been thinking of buying control freaks for my Xbox at home. Is it against FIRST rules to attach them to a driver's station controller?
FEAR OUR BUBBLES!
Unread 05-04-2015, 17:13
Not much regulation on what can be put on the driver station.
Question 155
Q. Do motors that are connected with the Operator console need to follow all rules that apply to motors mounted on the robot?
FRC1339 on 2015-01-13 | 3 Followers
A. No, there are no rules that explicitly legislate motors used in the OPERATOR CONSOLE, however please consider T1 and make sure that the implementation doesn't pose risk to people.
This was prompted in response to wondering if you could add kinetic feedback to driver station controllers through motors.
Unread 05-04-2015, 17:15
cjster's Avatar
AKA: CJ Mervyn
Question 155
So, to make it clear, I can? Thanks! I think you may have solved my problem once and for all. I'll also try those two games.
FEAR OUR BUBBLES!
Unread 05-04-2015, 23:07
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #5827 (Code Purple)
zinthorne will become famous soon enough
Have a slow gearing of your robot. I was a very aggressive driver last year and so this year came as a big change. I think the greatest thing I learned is "Drive slower to go faster." I tried going as fast as I can and i would dump stacks or make stupid mistakes. Practice, Practice, Practice! We had the opportunity to go to three district events this year and then district championships. As i got more practice things got much easier. The first two events I was 50-75% on our stacks. In the third It went well other than dropping two stacks of 6 in the same match In PNW championship we were 100% dropping no stacks. (This is excluding the match where a few zip ties were cut and our tower fell not letting us be able to stack)
I would also say to develop a routine. If you watch our playoff matches I did almost the same exact movements every match. This helps me to keep my nerves down and know the speed I have to go and have confidence that i do not have to rush. Since this years game is generally the same thing every match for a team, building a routine of the movements that you make can help with finesse a lot!
Unread 05-04-2015, 23:16
Here's a good example: http://www.chiefdelphi.com/forums/sh...ad.php?t=94981
