Go to Post My father taught me long ago that how we respond to adversity is what defines us as human beings. Let's all keep this definition in mind as we move forward to change a culture. - Rich Kressly [more]
Unread 26-03-2015, 21:54
rainbowbear998's Avatar
rainbowbear998 rainbowbear998 is offline
FRC #4739 (Thunderbolts Robotics)
rainbowbear998 is an unknown quantity at this point
Issues with Drivebase
After competing at the Australia regional, my team realised how difficult it is to get over the scoring platforms with the kit drivebase in the long configuration. As a result, we have now replaced our six 4" wheels with four 6" wheels on the ends. However, our robot now struggles to turn on the spot. At this point, we're pretty sure that the fault isn't in the code or electronics, but we've seen plenty of other teams use this setup with no problems. Has anyone else had the same issue? How did you solve it?
Unread 26-03-2015, 21:56
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Re: Issues with Drivebase
Your wheels are creating too much friction when you try to turn. Replacing two or four wheels with omni wheels will help greatly.
Unread 26-03-2015, 22:09
That's what I was afraid of. I've seen teams make this modification with no problems at all though. Would we get fishtailing if we only replaced one set with omni wheels?
Unread 26-03-2015, 22:28
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
If you only replace one pair, replace the one with less weight (away from the center of gravity). For most robots this year with a convex rectangular base, this would be the rear wheels. We used this configuration for Ultimate Ascent, and we had the two solid wheels in the front and two (idle) omni wheels in the rear. Our CoG was quite near the center of volume. We did have a bit of fishtailing at high speed going forward, but at low to moderate speed, we were fine; I don't imagine you'll be doing much sprinting in Recycle Rush. Interestingly, we had less fishtailing in reverse. This was presumably because more of the weight was over our solid driven wheels.
A better solution is to use six solid 6" wheels as the chassis was designed to use. The center wheels are dropped by 1/8", so the wheelbase is only one half or the other for purposes of "tank mode" turns, but full length for purposes of not falling over forwards or backwards.
Unread 26-03-2015, 23:57
That's our other option, but the other reason that we only used four wheels was to eliminate rocking in our drivebase, which is caused by the drop centre. I think omni wheels are our best choice at the moment.
Unread 27-03-2015, 10:02
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Opening with some quotes from another thread...
Originally Posted by NathanCJohnson View Post
But we're using 6" traction wheels in the front and 6" omniwheels in the back (the middle wheels are the 4" wheels that came with the KOP drivetrain).
You said the middle wheels are 4" and the front/back are 6". Have you geared them in the proper 6:4 ratio so they are going the same tangential speed?
The center axle on the AM14U2 is only dropped 1/8". Since the corner wheels are 2" larger diameter, the 4" center wheels float 7/8" off the carpet. In effect, the 4" wheels are just a spacer for the belt sheaves.
Except when going over the platform.
Yes, that would be a literal speed bump.
There was a robot at Bayou with a KOP chassis, 6" omnis on the corners, and 4" KOP wheels in the direct drive positions. I asked the driver how it handled, and he said that the 4" wheel actually helped getting onto and over the platforms, though he wasn't very articulate as to how or why. I'm guessing that the lower gear ratio and higher CoF turned the robot so that it was attacking the slope more directly, and gave a bit of a boost on the lift. The undersized middle wheel would produce less rocking as the weight shifted to a different pair of axles, reducing the likelihood of spilling a stack.
Unread 27-03-2015, 10:49
String String is offline
String will become famous soon enoughString will become famous soon enough
If you don't want to risk fishtailing and can't have any rock, consider using 4 omni wheels at the cost of some precision in driving. My advice is to reconsider using drop center, and if your team decides that the rock would negatively affect performance, use 4 omni wheels. In all honesty, Recycle Rush does not require a ton of precision unless you're running out of space on the SPs. I would avoid running only 2 omni wheels because it becomes difficult to drive.
Unread 05-04-2015, 20:29
daliberator's Avatar
daliberator daliberator is offline
Ace Machinist
AKA: Henry O'Callaghan
FRC #4536 (MinuteBots)
daliberator will become famous soon enoughdaliberator will become famous soon enough
I have to disagree. At my regional, it seemed when teams rushed things and were less precise with placement, things tended to go wrong, especially when moving stacks to the SC. However, I agree with your 2 omni advice.
4536 Team Captain
www.minutebots.org
Unread 06-04-2015, 00:11
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
If precision is required to that extent, you're building robots wrong.
(2015-?): 973
(2012-2015): 955
Unread 06-04-2015, 00:17
If I might make a suggestion:
You're a little worried about fishtailing, so why not NOT put omnis on only one end, or traction wheels only on one end? Why not put one omni on one end, and one omni on the opposite corner, and do the same with the traction wheels?
See: FRC494 in 2006.
This gives less fishtailing than two omnis on one end, similar stability to a 4WD with all traction wheels, and easier turning than said 4WD all-traction.
Unread 06-04-2015, 00:24
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We might all be overthinking this? Our team used the kit chassis, long configuration, with 6" wheels that are just like the 4" kit wheels. We notched the ends of the chassis for wheel clearance, so we could use the normal length belts. We competed in two regionals, and were semifinalists in one, and finalists in the other. No issues with driving. The rocking is a feature, not a problem, it allows the robot to turn easily on carpet. The 6" wheels let us go over the scoring platforms ok.
Unread 06-04-2015, 00:41
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
If you're holding the stack firmly enough, rocking is a feature that helps you drive. If the stack is being supported from the bottom, rocking is a problem that may well be worse than the problem it solves. The ability to turn while maintaining full traction is nice, but not if it means that you regularly drop a bunch of totes on the carpet in essentially random orientations.
Unread 06-04-2015, 00:46
Ace Machinist
To what extent are you referring? I was commenting on what I read as a rather broad statement about the game in general. I agree with MrForbes and String that a drop-center chassis is a viable option that may be worth re-considering, and was merely concurring with String that dual omnis on a 4-wheel drivebase may make the robot unnecessarily more difficult to drive.
4536 Team Captain
www.minutebots.org
Unread 06-04-2015, 00:48
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
To verify my understanding before I do an analysis - are you advising four wheels, with traction wheels on one diagonal and omnis on the other diagonal?
And oh, yes - what was the aspect ratio (track to wheelbase ratio) of that robot? Where was the CoG? Well, now I've got a nice problem to work on in the evenings as I travel this week, If I actually have any spare time.
Unread 06-04-2015, 00:53
MrForbes's Avatar
AKA: Jim
The design of the rest of the robot may make it so that some specific type of drivetrain is more better than another. Having a robot that cannot carry a stack of totes without dropping them seems to be a common problem this year...I don't know if modifying the drivetrain is enough to overcome this? Driver practice is helpful, and making changes to the control system can help, too. It could be that using omni wheels is a good way to deal with it. We did have some problems with dropping totes, but I really can't blame the drivetrain, since we didn't design our robot to restrain the totes. For our RC operations, the 6wd kit chassis worked just fine. We were able to move and place stacks of two totes successfully many times, with the top tote just resting on the bottom one.
