Go to Post Our robot throws custom $5.50 FIRST Frisbees at a rate of 75 discs per minute and a speed of ~32 feet per second. It costs over $80 to feed our robot for 12 seconds. - Woolly [more]
Unread 05-04-2015, 22:18
pwnageNick's Avatar
pwnageNick pwnageNick is offline
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
pwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond repute
pic: 2451 PWNAGE 2015 Driver Station
This is our new driver station for the 2015 season. The projector projects our live camera feed from the robot onto the white screen which reflects onto the angled poly-carbonate panel. Our driver looks through this panel to see the camera image. This allows him to see the feed from the camera without having to look away from the robot to the laptop.
Unread 05-04-2015, 22:19
maxxman maxxman is offline
maxxman is on a distinguished road
Re: pic: 2451 PWNAGE 2015 Driver Station
What exactly is the projector used for? A heads up display?
Unread 05-04-2015, 23:30
AlexanderTheOK AlexanderTheOK is offline
Guy
AlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really nice
That's a very interesting method for making a hud. Any reason you didn't just set up a second monitor? Or was there no way to properly fit that?
Unread 05-04-2015, 23:42
pwnageNick's Avatar
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
Our driver would not be able to look through a monitor at the robot on the field.. that's the point of a Heads Up Display.
FRC 2451: PWNAGE, Student/Team President (2009-2012)
FRC/VEX 2451: PWNAGE, Strategy/Design Mentor (2013-)
VEXU NAR: North American Robotics, Student/Chapter President (2013-)
Unread 06-04-2015, 00:02
Guy
Sorry. I thought it obvious I was saying to replace that paper with a monitor. That way you keep the polycarbonate but you don't have the operators hands wiggling on your hud.
Unread 06-04-2015, 00:07
NWChen's Avatar
NWChen NWChen is offline
Alum
NWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to behold
Can we get an image of what the HUD/camera feed would look like to the driver? Do you superimpose anything (sensor data, etc.) on top of that feed?
2012 - 2015 • Team 2601
Unread 06-04-2015, 00:12
pwnageNick's Avatar
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
We tried using a smaller projector but it was not bright enough. I think adding a monitor mounted up high like that was complexity we were trying to avoid. The driver station weighs a lot as is as well. Having that kind of weight mounted up high didn't seem worth it.
I do not believe we superimpose anything. Our driver doesn't really need to look at anything other than the camera feed and the robot itself on the field as most of the functions that need sensor input is automated. I don't believe we have a picture showing the display from the drivers perspective but we will try to get one.
Unread 06-04-2015, 00:18
Pretzel Pretzel is offline
Ex-Driver
AKA: Tyler
FRC #1619 (Up-A-Creek Robotics)
Pretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to behold
This makes me want to install a camera on our robot just to put something like this on the driver station. It's a truly awesome setup, well done!
It's not done until it's overdone!
Unread 06-04-2015, 01:03
GarrettF2395's Avatar
GarrettF2395 GarrettF2395 is offline
AKA: Sierra 117
FRC #2395
Team Role: RoboCoach
GarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of light
Send a message via Yahoo to GarrettF2395
I've wanted to use a H.U.D. on our driver station for years, but I could never justify the purchase of the projector.
I had always thought that the miniature size of a "pico" projector would work best but it sounds like you tried that or something similar? Did the projector set up need to be super bright for this to work?
Did you all like this set up?
Wish I had checked this out at Arkansas. Opportunity missed
https://twitter.com/TeamNinjaMunkee
FRC 2395: Team captain 2008-2009, Design mentor 2010-2011, Lead design and strategy mentor 2012-Present
Unread 06-04-2015, 09:40
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Does your driver have any issues looking to the left with this configuration? It seems like it would be a problem to me.
Ideally you would probably want the projector mounted on the bottom facing up like aircraft usually do, but in this case it looks like space is an issue without getting really creative with some mirrors or a smaller projector that isn't as bright.
Unread 06-04-2015, 23:10
YAK'ker's Avatar
YAK'ker YAK'ker is offline
FRC #2192 (YAK Attack)
YAK'ker has a spectacular aura aboutYAK'ker has a spectacular aura about
is there really enough room to set this up at the competition? And how do you handle the power for the projector? It's a cool idea, reminds me of the camera lucida set up we used to use for drawing...
“Wisdom comes from experience. Experience is often a result of lack of wisdom.”
― Terry Pratchett
Unread 06-04-2015, 23:26
Joseph DeRoest's Avatar
Joseph DeRoest Joseph DeRoest is offline
FRC #2990 (Hotwire Robotics)
Joseph DeRoest is a jewel in the roughJoseph DeRoest is a jewel in the roughJoseph DeRoest is a jewel in the rough
Thumbs up Re: pic: 2451 PWNAGE 2015 Driver Station
Love the idea! There was another team that did something similar to this, but used a product similar to Google Glass instead of a bulky projector, and I believe the right glasses lens was used for projecting the image onto, but the other one was unoccupied so that the driver could properly see through it.
Unread 06-04-2015, 23:55
AutodeskGeek's Avatar
AutodeskGeek AutodeskGeek is offline
FRC #2062 (C.O.R.E. - Community Of Robotic Engineers)
Team Role: Driver
AutodeskGeek is an unknown quantity at this point
I remember questioning one of your drivers when we were allied together at Midwest - I love the idea! Looking forward a picture of it from the driver's perspective.
¤ Autodesk Geek
Unread 07-04-2015, 11:04
elfenari elfenari is offline
1099 Discotechs Captain
AKA: Ari Elfenbein
FRC #1099 (Discotechs)
elfenari is an unknown quantity at this point
I would love to get Google glass for our driver with a ported smartdashboard/ camera view for our driver, maybe also showing a game clock. I could probably justify the expense for the team, but I think it would end up being more of a novelty than helpful, and it would be a lot of work to get all of the stuff ported correctly.
