Go to Post ... the real mark of integrity is doing the right thing even when nobody is watching. - DonRotolo [more]
Unread 04-01-2015, 03:53 AM
2538Programming 2538Programming is offline
FRC #2538
2538Programming is an unknown quantity at this point
I2C Rangefinders not working
We are using maxbotics mb1212 I2C rangefinders and we have tested our rangefinders on an arduino but for some reason, the same approach to reading off the sensors seems to fail. I think our issue may be that it can't find the sensors, which it should totally be able to do, or that it has trouble accessing the command on the sensors. The documentation for the rangefinders is right here http://www.maxbotix.com/documents/I2..._Datasheet.pdf
,as well our Rangefinder code:
package org.usfirst.frc2538.RecycleRush2538.subsystems;
import edu.wpi.first.wpilibj.I2C;
public class RangeFinder {
private I2C newRangeFinder;
private byte[] buffer = new byte[2];
private static int count = 2;
private static long echoTime = 0;
private int rangeCM;
// diagnostic
public boolean successfulWrite;
public boolean successfulRead;
// register addresses, must be in hexadecimle
private static int writeRegisterAddress = 0xE0; //224
private static int readRegisterAddress = 0xE1; //225
// write commands
private static int writeData = 81;
private static int writeDataHex = 0x51;
public RangeFinder(int hexAddress) {
newRangeFinder = new I2C(I2C.Port.kOnboard, hexAddress);
public void startSensor() {
successfulWrite = !newRangeFinder.write(writeRegisterAddress, writeDataHex);
echoTime = System.currentTimeMillis() + 100;
public int getRangeCM() {
if (System.currentTimeMillis() >= echoTime) {
successfulRead = !newRangeFinder.read(readRegisterAddress, count, buffer);
rangeCM = buffer[0] * 256 + buffer[1];
return rangeCM;
Any help we can get is much appreciated, thanks
Unread 04-01-2015, 04:16 AM
Jefferson Jefferson is offline
AKA: Jeff Clements
FRC #0016 (Bomb Squad)
Jefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant future
Re: I2C Rangefinders not working
Do you have pull down resistors on the data and clock wires? I believe the arduinos have them built into the board while the roborio needs them added to the bus.
We are using a similar sensor. I'd be happy to send you our C++ library for it.
Also, be careful if you are usng more than one. They can interfere with each other if the readings are sequenced properly.
Unread 04-01-2015, 07:59 AM
Woodie Flowers Award
JDNovak JDNovak is offline
AKA: John Novak
JDNovak has a reputation beyond reputeJDNovak has a reputation beyond reputeJDNovak has a reputation beyond reputeJDNovak has a reputation beyond reputeJDNovak has a reputation beyond reputeJDNovak has a reputation beyond reputeJDNovak has a reputation beyond reputeJDNovak has a reputation beyond reputeJDNovak has a reputation beyond reputeJDNovak has a reputation beyond reputeJDNovak has a reputation beyond repute
For the RoboRio, the I2C library changed to 7 bit addressing so the range is 1 to 128 instead of 2 to 254. The default address is 112 to the RoboRio.
The Arduino library uses 8 bit addressing.
I don't think this is officially documented anywhere.
For example I used the Arduino example code to set the address to 4 and then accessed the sensor on address 2 from the RoboRio.
The clock and data do need external 120 ohm pullups also.
Unread 04-01-2015, 10:53 AM
FRC #2538
We have resisters going from 3.5/5 V to SCL and SDA. We are using three of the rangefinders but I am pretty sure they are wired correctly as we were able to get all three values from the Arduino. If you are willing to send me your library, I would love to check it out, thanks!
This might be the issue, our sensors are addressed at 200, 202, and 204. I will try changing those and get back to you guys. Thanks for responding, I would have never been able to figure that out, why on earth would they do that?
Unread 04-01-2015, 11:10 AM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
According to page 15 of the RoboRIO user manual,
DIO <15..14> on the MXP and the two lines on the I2C port all have 2.2 kΩ pullup resistors to 3.3 V, as shown in Figure 17.
Unread 04-02-2015, 10:56 AM
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Perhaps you are mixing up this value with CAN termination resistors? That's a very strong pull for I2C. Also, not needed on roboRIO for I2C.
Unread 04-06-2015, 01:27 AM
AKA: John Novak
The Arduino I2C library doesn't enable internal pullups so I had to install them to test and set the addresses. I think they are 1.2K instead of 120 ohm. My mistake.
I left them installed on the network when I moved to the roboRIO and they worked with both the main and MXP I2C ports. I had a scope on them at some point and the roboRIO drove the lines low enough.
Somehow I missed the users manual so thanks for the link.
