Go to Post I hate that every year people turn this competition into whining rather than winning. - Akash Rastogi [more]
Unread 06-04-2015, 15:01
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
USB ports going away during match
We had an interesting issue this weekend with our driver controls dropping out. Things had been working well previously, we attended the San Antonio regional and had only one instance that I can remember of the controllers (Logitech Gamepads) not working, we unplugged them and plugged them back in and they were fine. But this weekend at Arizona, they started acting up Friday afternoon, where they would appear to be connected, then just after the match started one or both would "go away". Sometimes they came back with a USB Rescan, other times they needed to both be unplugged and reconnected.
The problem got worse late Saturday, in our final few matches we had to Rescan several times during the match to keep driving.
There was one code change before the issue started Friday, we added a vi module to make one of the buttons act as a toggle.
Each gamepad is connected to a "real" USB port on the DS laptop, there is no external hub. The laptop is on it's 3rd year, and has been working well.
Unread 06-04-2015, 15:14
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
Re: USB ports going away during match
This has happened to our team multiple times. Twice at AZ East this year. Numerous times in previous years.
We were fortunate enough not to have this happen to us at San Diego last week. However, I was volunteering as a CSA at the event and fixed a number of teams during matches.
It seems to manifest itself during the autonomous to teleoperated control transition.
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
Unread 06-04-2015, 15:16
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
We have seen a similar issue. Every time it has happened to us it has been because of a fault in the cable for the Logitech gamepad controllers. We do our best to have the students treat them with a bit of respect but they just get beat up.
Unread 06-04-2015, 15:21
angelah angelah is offline
FRC #3547
angelah has a spectacular aura aboutangelah has a spectacular aura about
That's how we spent last year. This year we switched to joysticks because of that problem. A more extreme solution, but it worked for us.
Unread 06-04-2015, 15:22
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
BitTwiddler is on a distinguished road
Not sure if it makes a difference but we use two Logitech controllers, one for the driver and one for the operator. As far as I know, they both drop out at the same time.
Unread 06-04-2015, 15:26
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
We fixed our usb issues in Ventura with simple "Power Option" setting changes on the windows laptop there are main ones and ones specific to USB ports in the advanced area.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
marshall's Avatar
That's interesting and useful info. If that is the case then that to me points to either a software fault or a more upstream hardware fault like the USB controller within the laptop.
As I said though, we've seen it happen to us and it is typically one controller that drops and it is because of a faulty cable. I've been able to repair a handful of the controllers but it is typically more cost effective to recycle it and then buy a new one.
Unread 06-04-2015, 16:12
kiettyyyy's Avatar
Most of the fixes that I've done for teams was to change the power settings for the USB port.
To clarify, the issue is not isolated to gamepad controllers of a specific brand. This can happen to ANY joystick device.
-Kiet Chau
www.team1538.com
Unread 06-04-2015, 16:24
MrForbes's Avatar
AKA: Jim
Actually one of the controllers was dropping, and the other stayed "lit up" on the DS display. And we changed the dropping controller with another one during one of the last matches, and the problem persisted, with no apparent change.
We can look at power settings, but I'm a bit confused why something like that would make the USB port come and go several times during a match, while the control is being used continuously? Although I do understand that Windows works in strange and mysterious ways.
I wonder if this is the advanced setting? btw this is on my desktop, which also runs Windows 7. I could probably end global climate change by leaving the setting as is, rather than allowing the pesky USB hub to run all the time!
Unread 06-04-2015, 16:41
kuraikou's Avatar
kuraikou kuraikou is offline
AKA: Alex
FRC #4183 (Bit Buckets)
kuraikou is an unknown quantity at this point
We were having the same issue at AZ East but we fixed the issue by triple checking the connection before every match and being ready to replug and rescan at the beginning of each match. Our issue was caused by bad USB ports and cables on our ps4 controllers, so we got new cables and that helped significantly.
2012 Utah regional Rookie All Star
2013 Phoenix regional Judges Award
2014 Hub City Quality Award
2014 Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award
2015 Arizona East Regional winning alliance captain
Unread 06-04-2015, 16:44
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Correct me if I am wrong, but I believe 2451 may have been having a similar problem at Midwest, that caused them to withdraw from alliance selections.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 06-04-2015, 16:58
Jared's Avatar
Jared Jared is offline
Here's a few ideas:
-Turn off the power save setting. This has caused similar problems for some teams in the past
-Uninstall and reinstall the USB driver
-Make sure that there is no other USB device that could be shorting the USB 5V supply.
-Make sure the contacts on the USB connectors are not corroded or dirty
-Make sure the USB cable fits snugly. If it doesn't, you can try gently crushing the joystick connector so that it has a better fit.
-Make sure the laptop is plugged in when you're driving.
-Make sure the laptop battery is healthy. Bad batteries can cause really weird things to happen.
-Uninstall/Reinstall the USB driver
-Disable your wireless adapter and bluetooth (if you have it). Sometimes the bluetooth adapter connects to an internal usb port, and may be causing issues.
Unread 06-04-2015, 16:59
kiettyyyy's Avatar
Jim, this is the setting that you'd be looking for.
-Kiet Chau
www.team1538.com
Unread 06-04-2015, 17:05
MrForbes's Avatar
AKA: Jim
Thanks for all the suggestions, everyone!
We have several things to check. We have not been plugging in the DS laptop charger during matches, it's been running on battery all the time.
I don't have the laptop here, hopefully it made it home on the bus Saturday night, and I can check it in an hour or so when I drop off the robot at school.
Unread 06-04-2015, 19:16
Failing to take advantage of the provided power at the field is not a good idea. It's too easy for Windows to kick in power-saving features if you're not plugged in. And if you do successfully disable them all, you're going to run down the battery much faster than "normal".
