Go to Post Just like any good hardware or software product, "insert foot before putting mouth in gear"..... - dhitchco [more]
Unread 07-04-2015, 14:38
Team3844's Avatar
Team3844 Team3844 is offline
AKA: Arthur Canada
FRC #3844 (Kentucky Wildbots)
Team3844 has a spectacular aura aboutTeam3844 has a spectacular aura about
Invacare wheelchair motor
Our team had a power wheel chair donated last year. We would like to use it as a chassis for a t shirt cannon. the chair has 2 invacare hub motors that I am pretty sure are 24 volt.
Part # 1079291
we have tried to run it hooking two 12 volt batteries in series to make 24 volt, but it just jerks.
Unread 07-04-2015, 14:43
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Re: Invacare wheelchair motor
They usually also have an electric brake built into the motor that needs to be energized to release. Make sure you are doing that as well.
Unread 07-04-2015, 17:47
chapman1's Avatar
chapman1 chapman1 is offline
FRC #3688 (Suttons Bay Norsemen Robotics)
chapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond repute
If you don't need the brake, then that mechanism can be quite easily removed
Unread 07-04-2015, 20:29
Do you know whether it's a brushless motor that requires a special controller?
Unread 07-04-2015, 20:41
Team3844's Avatar
AKA: Arthur Canada
It has 3 leads red, black and blue. Then a separate grouping of 5 wires. I guess the 5 may be for built in positioning sensors.
Unread 07-04-2015, 22:11
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
The motor is brushless. As Alan suggested it will require a special controller, and will definitely NOT run from a battery, dc supply, or one of the dc motor speed controllers used in FRC.
Richard Wallace
since 2003
Unread 07-04-2015, 22:31
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
That sounds like a brushless motor. You could buy a brushless ESC from a place like hobbyking for cheap, but I urge you to look for documentation first. There are several types of brushless motors, and I wouldn't know what those 5 extra wires are for.
Unread 07-04-2015, 22:36
TheHolyHades1 TheHolyHades1 is offline
TheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the rough
If I had to guess, I'd say that the extra wires are for some sort of sensor feedback - likely encoder data, current sensing, or something similar. I suppose there's also a small chance that there's an ESC built into the motor itself, and those wires are for the signal data. In other words, I've got absolutely no idea, and this is a case where documentation is a must .
