Go to Post EVERYONE on the team is offered the same opportunities to be a team player, it is up to each person to step up and play the game. - MariaCastro [more]
Unread 08-04-2015, 10:26
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Vex VersaFrame
Originally Posted by Chris is me View Post
We've never had rivets come loose, except for 5/32nd rivets installed on areas exposed to robot impacts. We use a mixture of 3/16th aluminum and 3/16th "high strength" aluminum rivets on our robots. Ensuring proper installation (properly drilled holes, rivets as flush with the plate as possible, installation of several rivets per part) is a big help, and creates a joint that is both more rigid and lighter than some bolted joints can be.
I assume your "high strength" rivets are the interlock style like these from McMaster. We use 5/32 most places, and those 3/16 where we want a bit more strength. The nice thing about those high strength ones is they'll provide a bit of pull-up and clamping when you set them. The hardest thing to get through to my students and other mentors was that rivets won't always clamp a joint together for you, and a gap between the two surfaces is a common cause for joints loosening.
Unread 08-04-2015, 10:32
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Re: Vex VersaFrame
It takes way more effort to CNC plasma cut gussets than it does to drill out COTS gussets for a larger hole size. Especially because you'll probably already have to drill the plasma cut gussets out to get the hole size just right. We just have new students drill out gussets for us when we use COTS gussets.
We're lucky to have a sponsor with a sheet metal laser cutter and CNC brake, so all of our flat parts this year that were 1/8" thick or less were cut by them. Saved us a little money in exchange for a week of turnaround time.
My team has the cnc plasma in shop so for us it ends up being fairly fast compared to delivery. As for drilling them out, it is a fast process, all you need to do is clear it with the right size bit and a hand drill.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
