Go to Post Achieving a goal by merely finishing, or reaching mediocrity is not acceptable; Excellence is the only satisfactory result. - AdamHeard [more]
Unread 13-03-2003, 14:16
David Bing David Bing is offline
David Bing is an unknown quantity at this point
Powering with the Competition Port
I was just wondering something. How would you go about powering the OI with the competition port, like they do at the competitions?
Unread 13-03-2003, 14:42
Innovation FIRST has never officially said, but several people have discovered, accidentally or otherwise, that pin 1 is what carries power.
I don't know if it is 9 volts or 5 volts (or something else). All I know is what other people have posted here.
Unread 14-03-2003, 20:45
So...I'd connect the positive end to pin 1 and the negative to any of the grounds?
Unread 14-03-2003, 22:14
correct...but by doing so, you void your warranty, yadda, yadda, yadda.
You should definitely check the voltage at pin 1 both when it is plugged into the wall and when it is plugged into the robot via tether. That should give you an idea of what is the correct voltage to apply. Remember that pin 8 is ground.
Unread 17-03-2003, 19:30
Umm Errr...
This is probbly true but not necessarily depending on the internal circuitry of the OI.
Please post whatever you find out.
1139 Alumni
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
Looking from a different point at "Fixing" punarhero General Forum 27 18-03-2003 18:41
Change to Initializing Inputs and Outputs Jferrante Programming 4 07-01-2003 11:36
How well did the regional competition help preparing? archiver 2001 3 24-06-2002 02:33
