Thread Tools |
Rating:
Display Modes |
Re: Responsible disclosure practices
That would only apply to exploits of the wireless network itself, though.
What if someone loaded arbitrary firmware on the RoboRIO, for example? (Version numbers or even hashes can be spoofed if you're running arbitrary code, so how would the FMS know?) |
Given that FIRST does not restrict roboRIO software in any way (other than disabling motors in particular modes), and that you can put coprocessors on board, it's hard to imagine why one would bother with such a thing. |
Really? You can't think of anything? I don't want to list stuff explicitly, but this doesn't take a whole lot of imagination.
The only thing that I can think of would be enabling yourself prematurely, or keeping yourself enabled after the match is over. However, either of these would be pretty easy for someone to spot if you gave yourself more than half a second. And, as I pointed out above, you don't need to modify firmware (and it's much less risky!) to accomplish either of these.
I'm not sure why messing with the driver station would be easier. Wouldn't the team who wanted to do this then have to conceal the modified communication to the robot? |
I would hope that the teams who would be capable of this would all think better of it, but I bet multiple teams per division at championships would have an unbeatable can-burgler if the FMS started them 1/4 second early every time. And I bet one of them would win. On the other hand, everything's on camera and the movements of most can-burgler mechanisms are not subtle. |
#8
Right, totally forgot about the can burglers. That's somewhere that 1/4 second could definitely make a difference if you're facing another can burgler.
#9
I'm not certain whether the original question was more about securing your device from external entry, or about teams looking for an advantage. But either way, the link given by Joe would work. It is also a good place to send safety concerns.
Just to comment a bit on the topics... Quote:
There are many ways to cheat in FRC, but there are also many deterrents. I don't think cheating takes place in FRC very often, and I don't think it would be as easy as presented. I ask that you not speculate or scheme online because information that you discover but are above using as a cheat may be just what someone else is looking for. That is why the link exists. Do your part to show how a community should deal with security. A few more thoughts... Robots that gain weight, grow a new limb, or move when they shouldn't can be reinspected. Students who impale an opposing robot with a pool noodle may be checked for performance enhancing compounds. Robots that don't obey the laws of physics will be checked for alien technology and magic. And yes, we think about it. Greg McKaskle Last edited by Greg McKaskle : 13-04-2015 at 08:22. |
#10
Getting an edge through cheating can be tempting, and it's easy to only think about the upside -- the glory of winning. Those feeling tempted should also imagine the incredible shame that would be brought upon their friends and teammates should their actions be discovered. Think about an article on Frank's Blog describing the situation in detail, and the 200 post thread that would ensue on CD. Think about the likelihood that your name would be associated with the cheating. Picture what it would be like to tell your parents about it. Imagine explaining to employers your involvement, or failing a background check for your new job due to "trustworthiness" issues. |
#11
If I had thought there was a risk of someone cheating using the method I mentioned, then I would have sent an email to FIRST long ago, and wouldn't have mentioned it in a public forum. But the risk is minimal, the gain is minimal except in very subtle circumstances, and the downside from it is too great as MrRoboSteve mentions. I'm not convinced that speculating in a public forum on the ways one could cheat is necessarily a bad thing either. The more ways that are publicly known, the more they will be watched for, and the harder it will be to actually do any of them -- which is a good thing. I suspect if people intentionally cheat in FIRST, they almost certainly do it via some mechanical cheating mechanism or violation of materials rules. I stand by my assertion that cheating via software that only affects your robot in a non-mechanical way is mostly useless. [Edit: with the exception of methods that provide human input to autonomous mode, but even then, mostly useless in this year's game] Last edited by virtuald : 13-04-2015 at 11:30. |
#12
Even this is tough. There are a bunch of people with a good view of you if you try to do this, including the referee who is standing at the end of the white line.
#13
One problem with enabling your robot early is you don't know when the game is going to start. If you have a reliable way of predict that, then you are slumming & probably should be doing something other than FRC.
Everything is over managed switches so should be difficult to directly interfere with another robot. Although certain combinations of robots play havoc with the FMS system. Keep in mind network traffic is monitored. Consequences for being found out is likely to be severe for the team & individual. |
#14
Agreed. And given there aren't any dynamic elements this year, there's not significant benefit either.
#15
R55 also applies in this situation, particularly point (a)
Remember that the FMS talks only to the DS, which in turn controls the robot. The DS and the robot are inside the same security boundary, so code on those two would only be a vulnerability to the extent that they impacted the operation of the FMS, other robots, or other driver stations. What Raymond Chen says about the airtight hatchway applies here as well. |
