Go to Post there should be a continuous cascade of knowledge spilling over to the less experienced team members and and continuous upward flow of members gaining experience. - ebarker [more]
Unread 22-03-2015, 22:04
cbf cbf is offline
FRC #2877
cbf is just really nicecbf is just really nicecbf is just really nicecbf is just really nicecbf is just really nice
Re: mjpg-streamer running on roboRIO
It's worse than I thought. My earlier comparison was with the MJPG streamer at 10 fsp and my robot program at 24fps. The MJPG streamer uses about 3 times the bandwidth as the WPILib streamer running on the robot.
It looks like I'm getting an MJPEG stream from my Logitech P930e (similar to the Logitech P920 but with a wider field of view), rather than an H.264 stream.
Do you know if there's any way I can persuade input_uvc.so to get an H.264 or MPEG-4 stream from the camera?
Unread 22-03-2015, 22:06
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
What quality setting are you using? That could affect it. (-q option). Also, I'm curious, what are you using to measure the bandwidth usage?
Unread 12-04-2015, 11:00
virtuald's Avatar
RobotPy Guy
For anyone who wants to read data from mjpg-streamer, I've posted python code that can read from the stream using urllib + opencv.
http://www.virtualroadside.com/blog/...-using-opencv/
We ended up not using any image processing at our competition, but because our dashboard was created using HTML/js, it was trivially easy to connect to the camera and display its output. Highly recommend mjpg-streamer as a solution if you're only needing to display output on the Driver Station.
Unread 12-04-2015, 14:39
cbf cbf is offline
FRC #2877
I believe I tried a few -q choices, but it was a while ago now.
I measured the bandwidth using the Windows task manager. Since there was nothing else on the WiFi between the laptop and the robot router (usual DLink 1522B), I believe the bandwidth measurements are reliable.
Unread 14-01-2016, 01:55
virtuald's Avatar
RobotPy Guy
FYI, I packaged mjpg-streamer into an IPK file that can be installed by opkg. It includes an init script that automatically starts mjpg-streamer when the RoboRIO starts.
Installation: https://github.com/robotpy/roborio-packages
Notes: https://github.com/robotpy/roborio-p.../mjpg-streamer
Unread 14-01-2016, 07:21
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Thanks! This is a big help.
MikeA
FRC #116
Unread 14-01-2016, 18:57
team-4480's Avatar
team-4480 team-4480 is offline
Debug? What's that?
FRC #4480
team-4480 will become famous soon enoughteam-4480 will become famous soon enough
I am trying to install it on our RIO, but I get this message: http://imgur.com/wzr8bJj
I did update to the latest version of RobotPy on the robot.
Thanks!
Unread 15-01-2016, 10:03
virtuald's Avatar
RobotPy Guy
The opkg architecture has changed from 2015 to 2016, so if you don't have the 2016 image installed, then you will get that error.
Unread 15-01-2016, 10:17
team-4480's Avatar
Debug? What's that?
FRC #4480
Oh yea, I still have to update. So once I get it installed, do I just plug in the webcam and I will see it on the driver station? Or is there some other setup I have to do yet?
Unread 15-01-2016, 10:20
virtuald's Avatar
RobotPy Guy
I haven't tried to integrate mjpg-streamer with the LabVIEW dashboard (and it's not really something I'm planning to do).
To see the camera feed, point a web browser at http://roborio-4480-frc.local:5800/ and it should show up there. If it doesn't, then reboot your roboRIO with the camera plugged in.
Unread 15-01-2016, 10:28
team-4480's Avatar
Debug? What's that?
FRC #4480
Awesome! Is it possible to connect two cameras with this or would that eat up too much bandwidth?
Unread 15-01-2016, 11:16
virtuald's Avatar
RobotPy Guy
This package supports launching up to 4 instances of mjpg streamer (the second would be at :5801 instead of :5800). You'll need to edit /etc/default/mjpg-streamer on the roborio, followed by '/etc/init.d/mjpg-streamer restart' or a robot reboot to enable this.
Refer to the FMS Whitepaper for bandwidth approximations. Last year we were able to run two 120x160 streams at 10fps with no complaints from the FTAA (we doubled the display size of the image on our HTML dashboard).
Unread 15-01-2016, 11:47
team-4480's Avatar
Debug? What's that?
FRC #4480
I am not able to see the page, firefox just says unable to connect when I try "roborio-4480-frc.local:5800". I did reboot so I am wondering if the config file is off because I set it up over USB using 172.... instead of Wifi. I imagine there is a setting in the config file, but I don't know how to get into it since my favorite editor is not installed(nano).
Unread 15-01-2016, 12:23
virtuald's Avatar
RobotPy Guy
To diagnose you'll need to SSH into the roborio (user: admin, password: just hit enter).
  • Does /dev/video0 exist? If not, then your camera isn't recognized by the roboRIO and mjpg-streamer won't be running. You can use 'dmesg' to look at the kernel messages and try to divine what happened. Not all cameras will be supported -- but I'm not 100% sure what ones are supported, or how to get the list (probably some linux magic)
  • Is mjpg-streamer running or did it die? "ps -Af | grep mjpg" will show you
  • If it's running, is it listening on the right port? "netstat -ln" can show you what ports are being listened on, 5800 should be in the list.
  • If /dev/video0 exists and mjpg-streamer dies, then there's something else wrong and you'll need to run mjpg-streamer on the command line. Unfortunately, I haven't put anything in the package to do this using the settings, so it's a bit verbose...
Unread 15-01-2016, 12:32
team-4480's Avatar
Debug? What's that?
FRC #4480
Alright, so there is video zero
With the "ps -Af | grep mjpg", I get
1602 admin {grep} /bin/busybox.nosuid /bin/grep mjpg
There is not 5800 on the port list
Thanks for all the support!
