Go to Post When I'm asked the question, "What is the most important computer language to learn to prepare me for a programming career?"; my answer is, "Your second one." - Greg McKaskle [more]
Unread 13-04-2015, 15:17
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
Re: coiled tubing
I stand corrected on the size difference error. I spent the evening making a round trip to our shop for more tubing. The valuable lesson to share is still to double check your pneumatic tubing size before it's installed & purge non-compliant tubing from your build space.
Thank you for volunteering at the PNW events.
Unread 13-04-2015, 16:26
rocknthehawk's Avatar
rocknthehawk rocknthehawk is offline
AKA: Aaron
FRC #1768 (Robo Chiefs)
rocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to behold
Re: coiled tubing
Originally Posted by rfolea View Post
Another source for coiled tubing:
Ships same day, free shipping if you spend over $49. Usually arrives at your place within two days anywhere in the US. If you are close to GA, one day.
They provided a $30 coupon in your KOP - use that if you haven't already.
The coiled tubing from here is super cheap and gets the job done.
Unread 13-04-2015, 16:40
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Re: coiled tubing
Also don't let the quick-connect fitting take the force of pulling on the tube. Zip tie it to a structural member just beyond the quick connect and let that take the forces. Don't want the tubing getting shaken around in its fitting.
