Go to Post Sometimes it is more appropriate for an individual to listen than it is for him to speak. - JVN [more]
Go Back   Chief Delphi > Competition > Championship Event
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
  #61   Spotlight this post!
Unread 16-04-2015, 13:25
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Re: 2015 Champs Predictions
Originally Posted by MrJohnston View Post
The fact of the matter is: That first pick in alliance selection is, in all likelihood, going to be the fastest and most accurate can grabber available. With countless teams developing grabbers right now, it is impossible to know who that will actually be.
It's not quite so simple. Let me give the example from MSC. 1023, a HP bot, seeded first and had three realistic choices:
  • 33 - Best landfill bot
  • 548 - Most consistent 2-can grabber, very capable HP stacker
  • 469 - Arguably a better can grabber than 548 when functioning, similar speed for 4 cans. Caveats: only used once in a match, takes a bit too long to set up
No single team, even with a little help, can put up enough points to win, no matter how many cans are available. Picking the team with the best can grabber available might have worked at MSC, because a team like 1023 plus 469 (not that great a stacker) plus the last pick of the draft could probably have put up enough points. But 1023 made the obvious choice in picking an arguably worse can-grabber but better stacker in 548, because 2 cans is enough if you can put up the stacks.
Fast-forward to CMP, there's no guarantee a great stacker seeding 1st will have a 548 available to them (except in Hopper, I suppose). Picking a dedicated can-grabber could work if there's a good enough stacker coming back around, but the last picks at MSC were higher quality than they will be at CMP, and even at MSC this was barely a viable strategy*. Maybe they'll be able to rely on one stack from their 3rd bot.
But a top alliance knows they need to win their division before they win Einstein. Picking a can grabber that can't do much else will result in that alliance doing neither, because one team, with a little help, simply can't create enough stacks to win.
tl;dr Even can grabbers need to score stacks if they want to be picked first
*573, as the 5th captain, took a big gamble picking 27, a dedicated canburglar/capper, as their first pick. But it paid off like crazy because they were able to get a phenomenal 3rd bot, 3098 (Watch them score 20 totes). It should not have worked, 3098 should've been picked way earlier.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
  #62   Spotlight this post!
Unread 16-04-2015, 13:26
Loose Screw's Avatar
Loose Screw Loose Screw is offline
A Loose Screw
AKA: Chris
FTC #5237 (Loose Screws)
Loose Screw is a jewel in the roughLoose Screw is a jewel in the roughLoose Screw is a jewel in the rough
Originally Posted by FIMAlumni View Post
Can you explain to me why you would split the RCs 2-2? If I have the faster can grabbers, I'm going to grab all 4 to lower your alliance score even if I can only score two of them. This elimination structure is brutal and 1 bad match by 2 teams in the QFs (from my alliance stealing the RCs) is two less teams I have to beat to move on. By splitting the RCs, you may move on to the SF while I'm stuck trying to find a good seat for the next round.
If you can beat that alliance so easily, wouldn't you want to play against them in the finals? If you help an alliance that you know you could beat advance, then they're knocking out an alliance that could beat you.
Using rock-paper-scissors as a guide;
You (rock) could easily beat scissors (slow RC grabber). However, there's another alliance that has quicker RC grabbers than you, but can't score as many 6-stacks as you. They'll be paper. If you can help scissors improve their average (sharing RCs), then there's a chance they'll knock paper out of elims. Then when Finals come, you could easily beat scissors.
It's a different strategy, but you can see why you'd do it.
  #63   Spotlight this post!
Unread 16-04-2015, 13:29
FIMAlumni's Avatar
FIMAlumni FIMAlumni is offline
FIMAlumni has a spectacular aura aboutFIMAlumni has a spectacular aura aboutFIMAlumni has a spectacular aura about
Archimedes: 1023-314-3602
Carson: 67-85-3604
Carver: 4967-66-2834
Curie: 5046-107- 70
Galileo: 1189-494-3618
Hopper: 548-33-4362
Newton: 1918-3641-3539
Tesla: 2137-2959-226
I started making this as a joke, but some of these have a legitimate chance to form and win their division.
  #64   Spotlight this post!
Unread 16-04-2015, 13:31
CaityDawh's Avatar
CaityDawh CaityDawh is offline
Ms. Smiley
AKA: Caitlin Brailsford
FRC #1730 (Team Driven)
CaityDawh is an unknown quantity at this point
I am very well aware that this will never happen. But just out of curiosity how do you all think the divisions would do in Einstein if the top 4 teams from each division was in an alliance. I am basing the top 4 teams off of OPR. OPR isn't the most accurate when it combines multiple events, but still is accurate enough that I am using it.
Archimedes:
1023, 2338, 314, 1538
Carson:
254, 1519, 1730, 4488
Carver:
368, 1986, 2852, 1768
Curie:
1114, 148, 4143, 3309
Galileo:
2056, 1619, 330, 525
Hopper:
2826, 987, 33, 3683
Newton:
118, 1678, 1756, 3130
Tesla:
2481, 2122, 3824, 1806
  #65   Spotlight this post!
Unread 16-04-2015, 13:47
Pretzel Pretzel is offline
Ex-Driver
AKA: Tyler
FRC #1619 (Up-A-Creek Robotics)
Pretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to behold
Carver:
Curie:
Galileo:
Hopper:
2826, 987, 33, 3683
Newton:
Tesla:
I would predict Newton winning in that scenario with their canburglars by starving the other teams of cans while still being able to put up a large number of stacks.
It's not done until it's overdone!
  #66   Spotlight this post!
Unread 16-04-2015, 14:02
MrJohnston MrJohnston is offline
FRC #0948 (Newport Robotics Group (NRG))
MrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond repute
I do disagree. If you are a great stacker (such as 4488) as the #1 captain and pick a great robot - whose not a can grabber, by the time you get your second pick you may not have any good can grabbers left. You have now limited yourself to 3 RC's for elimination rounds: A formula for an exit in the quarter finals. Sure, you might have the worlds fastest piece of cheesecake, but that will still limit you to getting two additional RC's - assuming your cheesecake truly is the fastest.
Nay... Unless that #1 captain is an autonomous RC grabber or has some very fast cheesecake waiting, it needs to choose an RC grabber.
  #67   Spotlight this post!
Unread 16-04-2015, 14:03
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Carver:
Curie:
Galileo:
Hopper:
2826, 987, 33, 3683
Newton:
Tesla:
I can tell you now, there is 0% chance of any of those happening.
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
  #68   Spotlight this post!
Unread 16-04-2015, 14:05
Gweiss96's Avatar
Gweiss96 Gweiss96 is offline
AKA: Garrett Weiss
FRC #3309 (Friarbots)
Team Role: Operator
Gweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to behold
Never say never
Nice try guy!
  #69   Spotlight this post!
I do agree with this... If the can grabber is truly so good it will get 2 every time and winning every possible match, I would want it to be able to put up at least 40 points on its own...
  #70   Spotlight this post!
Unread 16-04-2015, 14:10
CaityDawh's Avatar
Ms. Smiley
I know this will never happen. I was just curious. That would be a really exciting Einstein if it did. Lol
  #71   Spotlight this post!
Unread 16-04-2015, 14:14
Professional Stat Padder
He literally listed the 4 best teams in each division and asked which would win if they had to face off. No where did he say those were anywhere near realistic.
And he didn't list all the divisions. What?
(2015-Present)
  #72   Spotlight this post!
Unread 16-04-2015, 14:28
Gweiss96's Avatar
AKA: Garrett Weiss
Team Role: Operator
Carver:
Curie:
Galileo:
Hopper:
2826, 987, 33, 3683
Newton:
Tesla:
Not to be biased, but I think Curie would win.
Nice try guy!
  #73   Spotlight this post!
Unread 16-04-2015, 14:44
CaityDawh's Avatar
Ms. Smiley
I had them all typed out but apparently they were lost... I'm going to edit that.
  #74   Spotlight this post!
Unread 16-04-2015, 14:55
CaptainKirby's Avatar
CaptainKirby CaptainKirby is offline
AKA: Jake Olkin
CaptainKirby is on a distinguished road
Carver:
Curie:
Galileo:
Hopper:
2826, 987, 33, 3683
Newton:
Tesla:
We would have an amazing set of quarterfinal rounds, where five teams would be eliminated instead of the usual 4. In the slot left open the Woodie Flowers, Dean Kamen and Donald Bossi alliance would enter and sweep through to win the whole thing.
But on a more serious note, most of teams would be much less effective than they look. Even if they manage to get all the bins off the step, most have the capacity to stack more than seven 6 stacks. We would have probably one of the least exciting einsteins ever because they would finish stacking way before the time is up (except for when Dean Kamen lobs a game winning noodle into an unfinished six stack).
"It's not done until it's over-done" - 1619 motto
FIRST - the best thing I've spent a decent fraction of my life doing
  #75   Spotlight this post!
Unread 16-04-2015, 15:01
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
And I guarantee 1114 has a fast canburglar by now.
So there's that.
http://www.simbotics.org/files/photo...ssex2015_0.jpg
From 1114's website, it looks like they had a cool canburglar from windsor essex. I can't find any video though.
Originally Posted by Greg Needel View Post
Assuming your team can use all the cans look at the point potentials
step cans         Points (all 42 point stacks)
0	              126
1	              168
2	              210
3	              252
4	              294
0 step cans means 126 points?
In QF8 at NECMP, our canburglars missed, so all four went to the other side.
With 0 step cans, we (1519-195-2067) scored 214 points.
Head Programmer / Driver
