Go to Post For every hour you spend screwing pieces of your robot together, 20 hours of important stuff goes on behind your back. - Eric Bareiss [more]
Unread 16-04-2015, 15:19
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Need assistance finding bearing housing for thunderhex bearings.
My team needs to use a pillow block or something similar to hold a thunder hex bearing. We can't use the clamp on bearing block because it is much too big. An alternate that would still allow the use of a hex shaft would also work. Thanks.
Unread 16-04-2015, 15:23
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Need assistance finding bearing housing for thunderhex bearings.
The thunderhex bearing has the same outer diameter as the 1/2" round bearing. Any of the numerous housings designed for these bearings, including the VexPro versadrive clamp on bearing block or the versaframe side bearing mount, should work fine.
Unread 16-04-2015, 15:25
Bob Steele's Avatar
AKA: Bob Steele
What do you wish to mount the bearing to? tubing? plate? block?
Simplest solution is to use the flanged bearing and make a plate that it presses into. Which thunderhex bearing do you have? radial or flanged?
You can hold the flanged bearing in by putting three small screws around the outside (tapped into the plate) if you have a load which would push it out of a simple hole. Usually they will hold pretty well.
You can also hold the bearing in by using shaft collars...
Unread 16-04-2015, 15:31
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
If you have a 3d printer that's something that could be modeled and printed pretty easily
Unread 18-04-2015, 17:38
AKA: Ahad Bawany
no team (None)
Thanks for the help, we're looking into maybe using it in a press-fit situation. 3d printing is an option, but we've had bad luck with it in the past.
