Go to Post The biggest thing is you don't have to make your robot like another teams. Come up with something unique and go from there. RAISE THE BAR..... - camtunkpa [more]
Unread 16-04-2015, 17:19
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
Re: FRC Blog - Championship: Info Session, 608, & Wednesday Priorities
Originally Posted by Kevin Sevcik View Post
Super ditto for torches (in the non-British sense); pretty sure open flames are banned in the pits.
One of the sources of endless amusement for my team, along with the name of the element with an atomic number of 13...
no stranger to the working end of a pencil
Unread 16-04-2015, 17:25
Nate Laverdure's Avatar
FRC #2363
Dimly labelled to the upper left of Registration in this pic from the blog:
The comments under the blog entry also linked to the full sized version of the venue layout, posted on the CMP page. Please use that for further commentary.
Unread 16-04-2015, 17:26
MikeE's Avatar
no team (Volunteer)
I'm kinda curious what those squares in the corners of each division's pits are, however.
In the full sized plan they are marked as "INSP" so presumably Inspection areas.
Unread 16-04-2015, 17:28
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I'm assuming the practice field closure is to reduce distractions from getting inspected, but you would think they'd just restrict the practice fields to only fully inspected teams instead. and if they're worried about fairness in inspection order, then keep them closed (and unreservable) for the first 3 hours. I mean seriously. 75% of teams will be twiddling their thumbs after 5PM.
Unread 16-04-2015, 18:07
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Maybe they should attend some of the conferences?
Unread 16-04-2015, 18:32
I'm guessing pre-scouting, actually. Most of the conference rooms aren't nearly big enough to handle all the people that won't have much to do after inspection and between their 2(?) practice matches.
Unread 16-04-2015, 21:54
FRC #2363
...the people that won't have much to do after inspection and between their 2(?) practice matches.
Most teams will probably have only 1 practice match. Source:
The goal on Wednesday night is for your team to make sure it completes robot inspection, sends their drive team to the Drivers’ Meeting, and also participates in its assigned practice match on the your sub-division Dome field.
Emphasis mine. Also (2 hours)*(6 team appearances per match)/(76 team appearances) = approximately 9.5 minutes per match which seems like an appropriate cycle time for practice rounds.
Unread 16-04-2015, 22:00
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
You guys ready to be at the event at 6:45 in the morning?
Also, make sure you clear out a space for your crate Friday afternoon in the pits.
Unread 16-04-2015, 22:25
Sunshine's Avatar
Sunshine Sunshine is offline
Mr. S
FRC #2062 (C.O.R.E)
Sunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to behold
No practice fields and one practice match? Not a very good idea in my opinion.
C.O.R.E. Community Of Robotic Engineers
2015 Wisconsin Regional Champs, Safety Award
2015 Midwest Regional Champs, Safety Award, Industrial Controls Award
2014 Midwest Regional Judges Award
2013 Lake Superior Champs
2012 World Championship Safety Award, World Finalist for the Autodesk Award
2011 Wisconsin Regional - Website Award 10,000 Lakes - Innovation in Control, Safety Award
2010 World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
2010 10,000 Lakes Regional Champs, Entrepreneurship Award; Wisconsin Regional- Entrepreneurship Award, Safety Award
2009 WI Regional- Quality Award, Safety Award 10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008 World Championship Safety Award
2008 Wisconsin Regional Champs, Safety Award
2008 St. Louis Regional Entrepreneurship Award, Safety Award, Website Award
2007 Wisconsin Regional All-Star Rookie Award
Unread 16-04-2015, 22:30
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Gonna be a lot of bad first and second quals.
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 16-04-2015, 22:33
PayneTrain's Avatar
PayneTrain PayneTrain is offline
no
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
You mean at 6AM or earlier. You'll want great seats after teams who have had the same seats for the last 4 years come to claim their rightful location
Unread 16-04-2015, 22:49
wilsonmw04's Avatar
Coach
That reminds me of a conversation I was witness to at VA. But that's for another time.
