correct...but by doing so, you void your warranty, yadda, yadda, yadda.
You should definitely check the voltage at pin 1 both when it is plugged into the wall and when it is plugged into the robot via tether. That should give you an idea of what is the correct voltage to apply. Remember that pin 8 is ground. |
| Fried program slots? | Jeff Waegelin | Programming | 18 | 19-03-2003 18:08 |
| Looking from a different point at "Fixing" | punarhero | General Forum | 27 | 18-03-2003 18:41 |
| Change to Initializing Inputs and Outputs | Jferrante | Programming | 4 | 07-01-2003 11:36 |
| How well did the regional competition help preparing? | archiver | 2001 | 3 | 24-06-2002 02:33 |
