Go to Post If you are stupid about this and violate the rules, and thereby cause your alliance to lose a match, then your alliance partners will gang up on you and violate your robot. - dlavery [more]
Unread 15-03-2003, 06:29
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
Secure the connectors
Recent past experience alows me to validate that those connectors do come apart under certain impact circumstances. I'd have given alot for one at the Buckeye regional.
My advice: Tie wrap or velco wrap them and be sure to have with you a small set of snippers to cut them off afterwards. Tie wrapped or NOT doesn't assure the result from DJ's photo will or won't happen. If the connector does start burning up, tie wrapped or not - make sure you have quick access to the circuit breaker.
power connector for 2004 EDU controller kc8nod Robotics Education and Curriculum 6 25-11-2003 16:59
