Go to Post Side effect include: Hearing loss, splinters, blisters, extreme sprit, uncontrollable urges to scream "GO MOE", and bright green fashion sense - The Lucas [more]
Unread 17-02-2015, 12:51
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Re: voltage loss over long runs
Originally Posted by GeeTwo View Post
This falls under the heading of sprawl.
Or you get a number using 30' and divide by 5 or 10 - you get a better number for the shorter run that way.
Unread 17-02-2015, 13:28
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Unread 17-02-2015, 13:53
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
The relationship of the effect on a longer run scales (almost linearly) to a shorter run - not true? Impedance per unit length is a key component of the equation, correct?
Unread 17-02-2015, 14:14
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Originally Posted by rich2202 View Post
Not tall, but go look at Team 148 (batman thread). They have a 30 foot or longer tether. Drive wheels are on the robot with the battery, but the tethered piece has motors for lift.
This is true, and I wasn't arguing that it wasn't. I was just having difficulty parsing your earlier quote, and especially how that might not mean that the Batman and Robin tether was a case of sprawl.
Unread 17-02-2015, 14:27
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
No worries, several different contexts here I reckon - your OP used 3' and 6' as examples thus the 5 and 10 divisor.
Unread 18-04-2015, 23:59
John_freemen John_freemen is offline
John_freemen is an unknown quantity at this point
Coming back and reading this thread I can't help but laugh at the fact that 1296 ended up having a tethered bot.
Unread 19-04-2015, 01:55
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
I get teased about it quite often. ;o)
Unread 19-04-2015, 10:46
philso philso is offline
FRC #2587
With some of the long wire runs we are seeing this year, you may also want to watch out for the weight of your wiring. We have been through multiple cycles of weight reduction and I have concluded that we could have laid out our electronics better and dropped some excess weight. I used a kitchen scale and found that 18 feet of 12AWG wire weighed 0.494 pounds. That was about how much wire we would have needed to add a pair of motors up front for an active intake mechanism.
