Go to Post The future is a dark and mysterious place, and trying to force our current methods on that are patently absurd. - Taylor [more]
Unread 19-04-2015, 23:01
WillNess's Avatar
WillNess WillNess is offline
Programmer
AKA: Will Ness
FRC #4944 (The Hi Fives)
WillNess is just really niceWillNess is just really niceWillNess is just really niceWillNess is just really nice
Re: Getting Gyro Working w/ Mecanum Drive
Like this:
Sorry but that doesn't really help me. Like I understand how it works but I don't know how I would implement this in Java.
Outreach Lead // Lead Programmer // Junior
2014 FRC:
Rookie Allstar, Highest Rookie Seed & Semifinalist @ Utah
Rookie Allstar, Highest Rookie Seed & Semifinalist @ Colorado
2015 FRC:
Creativity In Engineering & Semifinalist @ Arizona West
Unread 19-04-2015, 23:18
Why? What part is not clear?
Unread 19-04-2015, 23:30
WillNess's Avatar
Programmer
AKA: Will Ness
The actual code I would write.
2014 FRC:
2015 FRC:
Unread 21-04-2015, 07:51
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I recommend using one of the WPIlib MecanumDrive methods, and just make corrections to the "twist" input when you want to go straight based on the error. Do not use the fourth "gyroscope" input to MecanumDrive_cartesian; this is only used for "field coordinates".
The correction could be a full PID, but because of the amount of friction in a mecanum drive system, you should be able to get away with a simple proportional correction; D will be mechanical, and I is usually not needed when seeking a position.
To do this, you will need to create a numeric variable to hold the desired heading, say azi.
In your joystick-reading loop:
  • When the joystick values indicate that you do not wish to hold a constant facing, set azi to NaN, or some number outside of the valid range.
  • When the joystick values indicate that you do wish to hold a constant facing:
    • If isnan(azi), set azi =gyro.getAngle()
    • otherwise, add a correction of the form prop * (azi - gyro.getAngle()) to the "twist" value. You will have to tune the value of prop.
Debugging tip: If the robot starts spinning faster and faster, do a quick shut down, change the sign of "prop" and try again.
Unread 21-04-2015, 19:05
WillNess's Avatar
Programmer
AKA: Will Ness
How do I set the robotdrive to the MecanumDrive method?
2014 FRC:
2015 FRC:
Unread 22-04-2015, 03:00
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
mecanumDrive_cartesian() is a method within the standard RobotDrive class in both C++ and java WPIlibs. For what are hopefully obvious reasons, you must use one of the four-controller forms of the new RobotDrive() constructor in order to use the mecanum methods.
Unread 26-04-2015, 00:20
WillNess's Avatar
Programmer
AKA: Will Ness
So in my teleopPeriodic would I put:
RobotMap.driveRobotDrive41.mecanumDrive_Cartesian(OI.joystick0.getX(), OI.joystick0.getY(), OI.joystick0.getZ(), 0);
or where should I do that? Also, should I set the fourth variable to my Gyro Angle or to 0?
2014 FRC:
2015 FRC:
Unread 26-04-2015, 08:48
As explained in earlier posts in this thread, passing the gyro angle to the fourth parameter gives you field-centric control. You said that's not what you want.
What you described above will make the driver interface field-centric
See the note "Optional Input for field-centric control of XY motion" in the code diagram linked in this post:
if your goal is to make the bot drive straight when the driver is commanding zero rotation, you could do something like this:
http://www.chiefdelphi.com/forums/at...4&d=1420598437
Unread 26-04-2015, 11:04
dawonn's Avatar
dawonn dawonn is offline
AKA: Dereck
FRC #2586 (Calumet Copperbots)
dawonn is an unknown quantity at this point
Talking Re: Getting Gyro Working w/ Mecanum Drive
The code is not particularly well documented, but here's the code we used this year:
https://github.com/CopperBots/Copper...obot.java#L632
We pass in the rotation joystick value that has already been deadband'ed.
If the joystick is at zero rotation, we use a proportional controller to keep the robot straight.
If the joystick is not at zero, we update the current heading of the robot and pass the joystick value back to the drive system unchanged.
We also have the option to disable gyro mode at any time in case something goes wrong like a bad calibration, or a loose cable.
There is also an option to update the kP value from the smart dashboard and some diagnostic information sent back to help troubleshoot when things go wrong.
Unread 26-04-2015, 13:01
WillNess's Avatar
Programmer
AKA: Will Ness
Thanks, this helps a BUNCH! The problem is mixing mecanum drive with your code
2014 FRC:
2015 FRC:
Unread 26-04-2015, 13:16
Sounds just like the note in the lower left corner of this code diagram
Unread 26-04-2015, 12:31
WillNess's Avatar
Programmer
AKA: Will Ness
Well what I'm asking is what do I put in for the fourth parameter, because I have to put something in it.
2014 FRC:
2015 FRC:
Unread 26-04-2015, 13:28
Look at the WPILib code for mecanumDrive_Cartesian():
    public void mecanumDrive_Cartesian(double x, double y, double rotation, double gyroAngle) {
        if(!kMecanumCartesian_Reported) {
            UsageReporting.report(tResourceType.kResourceType_RobotDrive, getNumMotors(), tInstances.kRobotDrive_MecanumCartesian);
            kMecanumCartesian_Reported = true;
        double xIn = x;
        double yIn = y;
        // Negate y for the joystick.
        yIn = -yIn;
        // Compenstate for gyro angle.
        double rotated[] = rotateVector(xIn, yIn, gyroAngle);
Now look at the WPILib code for rotateVector():
     * Rotate a vector in Cartesian space.
    protected static double[] rotateVector(double x, double y, double angle) {
        double cosA = Math.cos(angle * (3.14159 / 180.0));
        double sinA = Math.sin(angle * (3.14159 / 180.0));
        double out[] = new double[2];
        out[0] = x * cosA - y * sinA;
        out[1] = x * sinA + y * cosA;
        return out;
The cosine of zero is 1. The sign of zero is 0. So passing zero as the fourth parameter to mecanumDrive_Cartesian() will result in no rotation of the vector, which is what you said you want.
Unread 26-04-2015, 13:35
WillNess's Avatar
Programmer
AKA: Will Ness
Thank you Ether, that helps tons.
        double xIn = x;
        double yIn = y;
        yIn = -yIn;
        return out;
2014 FRC:
2015 FRC:
Unread 26-04-2015, 13:40
WillNess's Avatar
Programmer
AKA: Will Ness
Do you think this will work? (I only included the drive code)
public void teleopInit(){
	gyroMode = true;
public void teleopPeriodic() {
        Jx = OI.joystick0.getX(); //Drive Joystick X
        Jy = OI.joystick0.getY(); //Drive Joystick Y
        Jz = OI.joystick0.getZ(); //Drive Joystick Z
        rotationSpeedForError = RobotMap.GyroMod(Jz);
        RobotMap.driveRobotDrive41.mecanumDrive_Cartesian(Jx, Jy, Jz + rotationSpeedForError, 0);
public double GyroMod(double rotation){
	if (gyroMode == true) {
		double error = gyro.getAngle() - gyroHeading;
		double kP = .05;
		if (rotation == 0) {
			rotation = rotation + kP * error;
		} else {
			gyroHeading = gyro.getAngle();
	return rotation;
2014 FRC:
2015 FRC:
